what did you do to your 914 today |
mmichalik |
Jan 9 2021, 06:11 PM
MikeM Group: Members Posts: 732 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
Today was a fun filled 914 day. Drove the 74 this morning, replaced the pedal assembly on the 75 this afternoon. @bdstone914 the core will be sent back to you on Monday. It looks pretty good.
Out with the old, in with the new! Attached thumbnail(s) |
Jan 9 2021, 07:08 PM
Resident German Group: Admin Posts: 41,890 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
mb911 |
Jan 9 2021, 07:17 PM
914 Guru Group: Members Posts: 7,252 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
914forme |
Jan 9 2021, 07:23 PM
Thats a nice looking shark @MB911 , thinking that one was a steal.
I also looked at my 914-6, then went back to work on the 7 series. |
Morph914 |
Jan 9 2021, 07:54 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
rbzymek |
Jan 9 2021, 08:20 PM
Member Group: Members Posts: 199 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest |
Well sunny day, dry roads and no salt in Michigan yet so I went for a ride. Only the parking lot at the Metropark had snow.
mb911 |
Jan 10 2021, 07:48 AM
Thats a nice looking shark @MB911 , thinking that one was a steal. I also looked at my 914-6, then went back to work on the 7 series. Thanks @914forme for the price of a set of my -6 heat exchangers its a fantastic deal.. it does need a hood and a bunch of wiring and accessories in the engine compartment but still likely have less then 6k in this car total done |
double-a |
Jan 10 2021, 06:12 PM
Senior Member Group: Members Posts: 989 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
SO.O.C914er |
Jan 10 2021, 08:08 PM
Senior Member Group: Members Posts: 1,427 Joined: 18-July 16 From: Mission Viejo Ca Member No.: 20,199 Region Association: Southern California |
Really nice looking car well done (IMG:style_emoticons/default/shades.gif)
CHIZ 914 |
Jan 10 2021, 08:16 PM
Member Group: Members Posts: 203 Joined: 14-May 18 From: Mountlake Terrace, Wa Member No.: 22,118 Region Association: None |
Getting ready to install after I get a nice muffler from Ben (IMG:style_emoticons/default/piratenanner.gif)
double-a |
Jan 10 2021, 08:58 PM
i remember the day i installed my shiny-clean SSIs. by the next day they were covered in oil (IMG:style_emoticons/default/biggrin.gif)
SKL1 |
Jan 10 2021, 09:57 PM
Senior Member Group: Members Posts: 1,637 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Drove the '73 today from my shop home. Nice drive, in the 60's and sunny. Oil temp barely made it to 180!
Taking engine sheet metal to powdercoater tomorrow for the '71... |
Cairo94507 |
Jan 12 2021, 04:32 PM
Michael Group: Members Posts: 10,092 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Been wanting a set of these for my Six since Jim put one of his on my car.....I will put them on this weekend. Thanks to @Mike Fitton
930cabman |
Jan 12 2021, 04:48 PM
Advanced Member Group: Members Posts: 3,695 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Clean/nice tail lamps always make a great impact
Mueller |
Jan 12 2021, 04:56 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Installed some rear trunk gas struts, these happen to be used units from our Volvo since I put brand new ones on that car.
brant |
Jan 12 2021, 04:57 PM
914 Wizard Group: Members Posts: 11,794 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Nice work Mike !
Cairo94507 |
Jan 12 2021, 05:38 PM
That is looking like you are almost done with the drive train work. Very nice. (IMG:style_emoticons/default/beerchug.gif)
SKL1 |
Jan 12 2021, 06:05 PM
Cairo94507 |
Jan 13 2021, 05:23 PM
Olympic 914 |
Jan 13 2021, 05:30 PM
Group: Members Posts: 1,707 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Finished the first of my winter projects,
Ran new 12ga wiring to the front mounted fuel pump. Replacing the 16ga wiring I had installed back in the early 80’s when I originally moved the fuel pump to the front. For years it worked flawlessly but about 2 months ago I had an issue where the fuel pump quit, and I had to ride a flatbed home. When I got it into the garage I went through the usual litany of tests, suspecting a failure in the harness, relay or relay board. When I originally did the wiring I had put male/female spade connectors in the wiring running along the tunnel. This would allow me to test the fuel pump or run it to empty the tank etc. all the positive leads tested good, BUT the failure point was the spade connector on the Negative side. Anyways today I ran a new 12ga wire from the rear through the passenger comp to the fuel pump and instead of going back to the original neg wire in the engine comp, I ran another 12ga brown wire to the ground point near the fuse box. Tomorrow I will take it for a test ride but I expect to have no more problems with this. Next I'll be waiting on the FI harness I ordered from Jeff Bowlsby. and when it arrives, that will be my 2nd winter project. I have had a couple minor electrical issues last year and although each time I suspected the FI harness it turned out to be something else. So this new FI harness will ease my mind and eliminate a future failure point. |
Lo-Fi Version | Time is now: 23rd November 2024 - 12:46 PM |
