what did you do to your 914 today |
Outbackskip |
Jan 6 2012, 01:21 PM
Newbie Group: Members Posts: 14 Joined: 13-December 11 From: Gassel, The Netherlands Member No.: 13,893 Region Association: Germany |
JawjaPorsche |
Jan 6 2012, 03:10 PM
Removed back pad to send to get recovered.
Installed brand new driver's seat belt that my daughter and son-in-law gave me for Christmas. It is awesome. And it catches when you jerk on it. My old one would not and probably would not catch in accident which is not good! I also purchased today FI fuel lines for my fuel pump replacement project next week. I have done it before when I could use a lift but I ain't climbing under a car with gas leaking in my eyes. Too old! Been there, done that! I will let my mechanic do it for me. |
poorsche914 |
Jan 6 2012, 03:43 PM
T4 Supercharged Group: Members Posts: 3,122 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Took the top off and went on a ~50 mile drive with my granddaughter with a stop at McD's for lunch. She laughed as we drove the twisty, hilly roads and called it a "roller coaster".
(IMG:style_emoticons/default/driving.gif) |
0396 |
Jan 6 2012, 09:15 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Bought parts for it.
oldschool |
Jan 6 2012, 10:22 PM
Advanced Member Group: Members Posts: 3,372 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
Drove out to L.A......my old Hood
Porschef |
Jan 7 2012, 07:50 AM
How you doin' Group: Members Posts: 2,178 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
More like what I hope to do today; some new super white LED's for the instrument panel came yesterday maybe I'll get a chance this weekend...last week I installed a Sparco steering wheel that gives a ton of legroom..even if Andy thinks its ugly...
TargaToy |
Jan 7 2012, 08:46 AM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 705 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
Started refurbing the tail light socket of a donor fender so that I can cut out a good whole section and graft into my driver's fender. Check out the gnarly braze patch and the ball peen hammer blows I found under loads of filler. (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) I have been around a long time and that is AMAZING!!!!!!! (IMG:style_emoticons/default/pray.gif) Cant wait to see it with paint! Thanks! I assure you that nobody is more amazed than I am. (IMG:style_emoticons/default/biggrin.gif) |
TargaToy |
Jan 7 2012, 08:50 AM
Started refurbing the tail light socket of a donor fender so that I can cut out a good whole section and graft into my driver's fender. What gauge metal are you using for that work? I've got some sail panel area work and some rubber seal tracts to do some repairs on. That's 18g steel which is pretty close to what I'm measuring as the stock thickness--maybe just a hair thicker. I think stock measures between 18-20g (19?). |
TargaToy |
Jan 7 2012, 08:53 AM
QUOTE Milled a hole in the top chrome targa-strip for my 36 LED 3rd brakelight and installed it on the 914, I think it worked out pretty well. At least it makes it more visable now. Later Skip That's just beautiful. The LED's will blend in nicely until you hit that pedal. I'm thinking about doing the same thing. |
Harpo |
Jan 7 2012, 11:18 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
mrbubblehead |
Jan 7 2012, 11:45 AM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
mrbubblehead |
Jan 7 2012, 02:49 PM
the post man just dropped off my inner door seals from 914rubber.com (IMG:style_emoticons/default/piratenanner.gif) and of course another perfect fit. i cant wait to order my new door rubber and window felt.....
tradisrad |
Jan 7 2012, 02:58 PM
replaced both seals on the speedo drive and changed the gear oil.
ClayPerrine |
Jan 7 2012, 04:50 PM
Life's been good to me so far..... Group: Admin Posts: 15,901 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Milled a hole in the top chrome targa-strip for my 36 LED 3rd brakelight and installed it on the 914, I think it worked out pretty well. At least it makes it more visable now. Later Skip Now that is a COOL addition! (IMG:style_emoticons/default/smilie_pokal.gif) Where did you get the led assembly? I want to do this to my car. |
flipb |
Jan 7 2012, 05:01 PM
Senior Member Group: Members Posts: 1,766 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
Drove it!!
On twisty roads!! With the roof stowed!! In 65 degree temps!! In early January!! (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) Just got her back from getting new wheel bearings, replacing inner & outer driver's door handles, and radio wiring de-fuched-up so it works again. Driving great and now has the addition of Mikey914's wheel center caps on my Mahles... I should get to drive it a few more times this week. Might try to clean it up a bit. |
djm914-6 |
Jan 7 2012, 05:07 PM
Happiness is: Getting on the road Group: Members Posts: 1,864 Joined: 6-February 03 From: Burlington MA Member No.: 248 Region Association: None |
Picked up my Mini from the bodyshop today. Took thr 914 out for a fill up and a new bottle of sta-bil for a short winters sleep... I hope.
sfrenck |
Jan 7 2012, 05:29 PM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
Dropped the engine and transmission to clean up the hellhole (IMG:style_emoticons/default/sad.gif)
Thanks to Brenz and Mepstein for helping a brother out. (IMG:style_emoticons/default/beerchug.gif) |
914dave |
Jan 7 2012, 05:38 PM
914 Addict Group: Members Posts: 720 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
Mounted a new firewall shift linkage bushing. Laying out an aluminum dash to replace the vinyl dash face. Covering the radio hole to run a Secret Audio system in the car.
hot_shoe914 |
Jan 7 2012, 05:42 PM
on ramp passer Group: Members Posts: 3,806 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Ignored the two that I can drive and thought about the one I can't.
AndyB |
Jan 7 2012, 07:05 PM
The Governor is watching me Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States |
Installed some loud a$$ air horns from Harbor Freight no more meeeeep
Lo-Fi Version | Time is now: 23rd November 2024 - 10:34 AM |
