861 Pages V « < 705 706 707 708 709 > »
mmichalik
post Feb 22 2021, 11:04 AM
Post #14121
MikeM
sprayed the longs body color this weekend and started hanging the new rocker panels. Also put a new headliner on the targa, installed a radio antenna (purely aesthetic) worked on a few other little things.
All of which I didn't finish for one reason or another so, they are 1/2 done. (IMG:style_emoticons/default/smile.gif)
post Feb 22 2021, 12:34 PM
Post #14122
Resident German
ndfrigi
post Feb 22 2021, 01:15 PM
Post #14123
picked up some interior door parts from David @Beach914 . thank you again David!
Chris914n6
post Feb 24 2021, 03:33 PM
Post #14124
Jackstands are my life.
I got an email from Craig this morning asking if I wanted a Boxster suspension for $75.
Fuch yeah I do. (IMG:style_emoticons/default/piratenanner.gif)
Thanks Craig with the list.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1614202424.1.jpg)
anderssj
post Feb 24 2021, 09:42 PM
Post #14125
Dog is my copilot...
First decent top-off day this year, so checked it over, kicked the tires, lit the fires...and drove it for about 50 miles. (IMG:style_emoticons/default/piratenanner.gif)
Bucci
post Feb 25 2021, 03:25 AM
Post #14126
Bucci
Did a little bit of cleaning inside the engine bay and as always checking for rust under the battery tray. Also, dropping off gas tank cap parts for cad plating.
Cairo94507
post Feb 25 2021, 06:06 AM
Post #14127
Michael
That looks like a nice hell hole. (IMG:style_emoticons/default/beerchug.gif)
930cabman
post Feb 25 2021, 07:11 AM
Post #14128
Looks like one nice 914/3.2 well sorted, keep it goin
ClayPerrine
post Feb 25 2021, 07:50 AM
Post #14129
QUOTE(Cairo94507 @ Feb 25 2021, 06:06 AM) *
That is not a hell hole. That is a heaven hole. No rust!
Bucci
post Feb 25 2021, 01:51 PM
Post #14130
Bucci
QUOTE(ClayPerrine @ Feb 25 2021, 05:50 AM) *
By the way, there’s always rust. I’ve had this car since 1988 and if I’ve learned something over the years. I would not wash the engine bay out too regularly. I’ve gotten much better by using petroleum and paraffin spray lubricant/sealer‘s. Almost like a cosmoline undercoating where the oxygen and water cannot penetrate..!
Mark Henry
post Feb 25 2021, 02:10 PM
Post #14131
that's what I do!
I sent off my SDS EFI ECU for a connector and the install of the data logger daughter board and cable. More importantly this allows me to download software updates.
930cabman
post Feb 25 2021, 02:13 PM
Post #14132
QUOTE(Bucci @ Feb 25 2021, 02:51 PM) *
Yes, our beloved 914's were standard with rust. My thought is to not feed it, always garage and never take out in the rail. This will minimize it's growth.
I suppose it's possible to drill holes in the hollow sections and inject some product to slow the rust
Bucci
post Feb 25 2021, 02:56 PM
Post #14133
Bucci
QUOTE(930cabman @ Feb 25 2021, 12:13 PM) *
By the way, my opinion.
Never store your car in a heated garage that makes rust grow faster.
Frozen or cold slows everything down..!
raynekat
post Feb 25 2021, 09:30 PM
Post #14134
Switching out my Dansk single outlet sport exhaust for a more factory style quieter Leistritz muffler.
In order to fit under the valance panel, will need to cut off the outlet and re-weld in a different orientation.
Dropped it off at the local muffler shop here in Boring.
SKL1
post Feb 25 2021, 09:44 PM
Post #14135
Had the '73 out with my older son (who is visiting from SD) also driving a friend's F355 spider. Something inviting about an older car and the old saying it's more fun to go fast in a slow car than slow in a fast car. He'd taken another friend's 488 out yesterday and preferred the F355. I would too...
mgp4591
post Feb 25 2021, 09:50 PM
Post #14136
Picked up another Subaru fuel pump assy and cut out the center so I can use the outer ring as an inside tank support for the bolts that will be welded to it to come through the top assy and tightened to help prevent leakage. With 2 gaskets, one in and one out, I'll be able to seal the two and won't have fumes coming up to attack us. Hopefully. Sometimes the rivnuts will make for a good sealing platform but I want to minimize my chances of chemical pneumonia...again.
Arno914
post Feb 26 2021, 06:43 AM
Post #14137
Region Association: Germany
Had a 4-wheel alignement done this morning. Toe-in was out of spec what explains the rather "spongy" feeling while travelling on the Autobahn. (IMG:style_emoticons/default/smile.gif)
(Pictures where taken during setup, measurement was done with the wheels sitting on the ground, off course.)
(IMG:http://www.914world.com/bbs2/uploads_offsite/up.picr.de-24260-1614343416.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/up.picr.de-24260-1614343417.2.jpg)
rbzymek
post Feb 27 2021, 03:44 PM
Post #14138
At long last I changed out the throttle body on my 2056 for a Vanagon 2.1L version. My first impression is that it revs much more freely especially from 4000 rpm to 5000rpm. That makes sense since the 1.8 TB choked it a bit at the higher flows. Well worth the effort plus I only paid $25 for the new TB.
I don't have a mill like some of you but I was able to rig one with an x-y table and my cheap drill press. I needed to modify the old shaft for the larger plate. Took it slow and easy so it wouldn't blow up.
913B
post Feb 27 2021, 04:24 PM
Post #14139
QUOTE(rbzymek @ Feb 27 2021, 01:44 PM) *
That is cool where did you get the new TB?
Why do you need to modify the old shaft.
Why can't just use the new TB as is?
rbzymek
post Feb 27 2021, 05:24 PM
Post #14140
There was a guy on Samba that had some TB’s. The throttle switch geometry is different on the Vanagon part so you need to use the 1.8 shaft. Then you have to machine the shaft so the larger plate will fit.
- Lo-Fi Version Time is now: 23rd November 2024 - 04:25 AM
