what did you do to your 914 today |
DRPHIL914 |
May 19 2021, 05:59 AM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
finally cut into the rear fiberglass valance for the twin out exhaust pipes , test fit was good so Wurth Stone Guard was sprayed on, 2 coats, i like it! should be cured and dry enough for installation tonight- has to be done tonight Friday is Werks Reunion Amelia Island. !!!
Attached thumbnail(s) |
Cairo94507 |
May 19 2021, 07:19 AM
Michael Group: Members Posts: 10,092 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
@DrPhil914 That look nice. (IMG:style_emoticons/default/beerchug.gif)
DRPHIL914 |
May 19 2021, 09:41 AM
trying to clean up the engine bay, i removed the charcoal box to clean and polish it and the strap, it looked horrible , then relocated it to the battery hold down mount. it was on the fan shroud. then go rid of the wires foe the heated seats. don’t need that now i will later relocate them. but also removing the air hose for heat, it just looks cluttered badly
TX914 |
May 19 2021, 09:52 AM
Alan-B Group: Members Posts: 177 Joined: 27-July 14 From: USA Member No.: 17,689 Region Association: None |
@DRPHIL914 Looks nice. Where does the front hose on the charcoal canister go? (on that GC? motor)
Does the extra throttle return spring do much? Red plug wire to #1 is a nice touch. Just curious why your MPS is mounted backwards - is there an advantage? Cheers |
DRPHIL914 |
May 19 2021, 10:15 AM
@DRPHIL914 Looks nice. Where does the front hose on the charcoal canister go? (on that GC? motor) Does the extra throttle return spring do much? Cheers @TX914 the hose on bottom of page, the out, goes to the air box. on the other side close to firewall is air in and the small gas vent tube coming all the way back from the tank. The spring i probably dont really need anymore after having the throttle body rebuilt and new cable, but it used to not pull back far enough and idle would not come back to normal with slightly open butterfly valve.. Phil |
Costa05 |
May 19 2021, 11:10 AM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
Decided to take on installing perlon carpeting with back pad glued to it on the floor boards. Another one of those I can save a few $ and do it myself kind of things. Reoccurring theme. Looks good to me. Now to finish the rest of the inside panels.
DRPHIL914 |
May 19 2021, 12:38 PM
Decided to take on installing perlon carpeting with back pad glued to it on the floor boards. Another one of those I can save a few $ and do it myself kind of things. Reoccurring theme. Looks good to me. Now to finish the rest of the inside panels. @Costa05 i like the center console nice clean look. cable shifter? what's it attached to, boxster trans? |
Costa05 |
May 19 2021, 03:06 PM
Decided to take on installing perlon carpeting with back pad glued to it on the floor boards. Another one of those I can save a few $ and do it myself kind of things. Reoccurring theme. Looks good to me. Now to finish the rest of the inside panels. @Costa05 i like the center console nice clean look. cable shifter? what's it attached to, boxster trans? Thanks @drphil914 . Yes cable shifter to Subaru 5mt trans. Cup holder will be added soon. |
dlee6204 |
May 19 2021, 04:51 PM
I bought another one. It was a pretty smoking deal on a '73 2.0L. Very solid car with minimal rust. (IMG:style_emoticons/default/driving.gif)
BillJ |
May 21 2021, 02:18 PM
Senior Member Group: Members Posts: 1,188 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
Installed my newly recovered center console and test fit the gauges. Had the shop do stitching to match exterior color for subtle custom touch.
Jett |
May 21 2021, 02:38 PM
Senior Member Group: Members Posts: 1,670 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
BillJ |
May 21 2021, 02:44 PM
Installed my newly recovered center console and test fit the gauges. Had the shop do stitching to match exterior color for subtle custom touch. Looks great Thanks! It isn't perfect (but neither am i) and I think it really dresses up the interior while getting me some better gauges to monitor the engine. |
Costa05 |
May 21 2021, 06:04 PM
Installed my newly recovered center console and test fit the gauges. Had the shop do stitching to match exterior color for subtle custom touch. Wow. Nice job. @BillJ |
KaptKaos |
May 22 2021, 03:29 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Took the tarp off, put air in the tires, took her off the jack stands, and took her for the first ride of the year. Felt good (IMG:style_emoticons/default/smile.gif) Need a new muffler (IMG:style_emoticons/default/sad.gif)
warpig |
May 22 2021, 06:46 PM
Member Group: Members Posts: 290 Joined: 2-August 10 From: Portland OR Member No.: 12,002 Region Association: Pacific Northwest |
Parts have started arriving for building the engine in my red car. (IMG:style_emoticons/default/piratenanner.gif)
Took them over and put them on my rack at Middle Motors. 2270cc build to commence shortly. (IMG:style_emoticons/default/evilgrin.gif) |
FlacaProductions |
May 23 2021, 08:00 AM
Senior Member Group: Members Posts: 1,799 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
It's been a busy week - two attempts at the main targa seal with the second one being successful - some window adjustment still needs to be done.
Swapped in a combo temp gauge that I've added numbers to - but I think it needs a different sender from the one I have in the console - will investigate that later. oh - and the EZ-Car Lift arrived but FedEx was a day later than scheduled so I was only able to get it assembled but didn't try it out yet. Most importantly, I got nearly 150 miles on it with a couple good stops for pictures and some drone work. |
Jett |
May 23 2021, 08:55 AM
Parts have started arriving for building the engine in my red car. (IMG:style_emoticons/default/piratenanner.gif) Took them over and put them on my rack at Middle Motors. 2270cc build to commence shortly. (IMG:style_emoticons/default/evilgrin.gif) Who’s Delphi car on the hoist? |
Jett |
May 23 2021, 08:57 AM
It's been a busy week - two attempts at the main targa seal with the second one being successful - some window adjustment still needs to be done. Swapped in a combo temp gauge that I've added numbers to - but I think it needs a different sender from the one I have in the console - will investigate that later. oh - and the EZ-Car Lift arrived but FedEx was a day later than scheduled so I was only able to get it assembled but didn't try it out yet. Most importantly, I got nearly 150 miles on it with a couple good stops for pictures and some drone work. Looks great. For the second pic, was the drone in chase mode? I have a Mavic Air but have not tried the chase mode. |
FlacaProductions |
May 23 2021, 09:31 AM
930cabman |
May 23 2021, 12:40 PM
Advanced Member Group: Members Posts: 3,695 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Flushed out the gas tank with fresh fuel, first flush was crappy, mostly a mud like mixture, second was filterable with an old shirt and third was even better. I left a gallon or so in the bottom of the tank and will repeat tomorrow. My gut tells me another flush and keeping an eye on the filter should be just fine.
I read a few threads about tank cleaning and was not crazy about vinegar or POR or any other concoction. I did not see any signs or internal or external rusting. This baby will be rolling down the road soon |
Lo-Fi Version | Time is now: 23rd November 2024 - 10:55 AM |
