what did you do to your 914 today |
friethmiller |
Aug 7 2024, 05:46 AM
Senior Member Group: Members Posts: 634 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
New 19mm URO master cylinder, old one was leaking out the back and couldn’t get a firm pedal no matter how much I bled or adjusted. Installation was straightforward and the reservoir lines didn’t fight me much at all. Bled the system (love my speedbleeders) now full, hard pedal. Nice car, @Arfrombama! Theres nothing like a “hard peddle” (IMG:style_emoticons/default/biggrin.gif) My 74 was originally just like yours, no fog lights,1.8L but Bahia Red |
Geezer914 |
Aug 7 2024, 05:48 AM
Geezer914 Group: Members Posts: 1,658 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Fixed my no start issue, 6v Ford hot start relay took a dump . Replaced with a new 12v relay. All good! (IMG:style_emoticons/default/beerchug.gif)
NotLance |
Aug 8 2024, 08:43 PM
Member Group: Members Posts: 80 Joined: 4-February 21 From: Northern California Member No.: 25,165 Region Association: Northern California |
Repaired a cracked decklid tab at the Red Barn. Huge thanks to Chris for letting me use his welder. (IMG:style_emoticons/default/biggrin.gif) Gap is perfect.
(Pre-welding - forgot to take photos of the finished repair but it turned out good) While at it we slotted the decklid tabs so now it's super easy to take on and off - big improvement! Attached thumbnail(s) |
Artfrombama |
Aug 9 2024, 12:38 PM
Member Group: Members Posts: 166 Joined: 21-January 24 From: Alabama Member No.: 27,870 Region Association: South East States |
New 19mm URO master cylinder, old one was leaking out the back and couldn’t get a firm pedal no matter how much I bled or adjusted. Installation was straightforward and the reservoir lines didn’t fight me much at all. Bled the system (love my speedbleeders) now full, hard pedal. Nice car, @Arfrombama! Theres nothing like a “hard peddle” (IMG:style_emoticons/default/biggrin.gif) My 74 was originally just like yours, no fog lights,1.8L but Bahia Red @friethmiller Yes but you have the coveted LE, I have the lowly garden variety. I always drop by your restoration thread daily to check your progress, amazing work my friend! |
SKL1 |
Aug 9 2024, 12:40 PM
Senior Member Group: Members Posts: 1,625 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
friethmiller |
Aug 9 2024, 01:19 PM
New 19mm URO master cylinder, old one was leaking out the back and couldn’t get a firm pedal no matter how much I bled or adjusted. Installation was straightforward and the reservoir lines didn’t fight me much at all. Bled the system (love my speedbleeders) now full, hard pedal. Nice car, @Arfrombama! Theres nothing like a “hard peddle” (IMG:style_emoticons/default/biggrin.gif) My 74 was originally just like yours, no fog lights,1.8L but Bahia Red @friethmiller Yes but you have the coveted LE, I have the lowly garden variety. I always drop by your restoration thread daily to check your progress, amazing work my friend! Thanks! It's coming along. BTW, the LE is my 2nd 914. My red '74 is just like yours (IMG:style_emoticons/default/first.gif) |
Artfrombama |
Aug 9 2024, 05:33 PM
New 19mm URO master cylinder, old one was leaking out the back and couldn’t get a firm pedal no matter how much I bled or adjusted. Installation was straightforward and the reservoir lines didn’t fight me much at all. Bled the system (love my speedbleeders) now full, hard pedal. Nice car, @Arfrombama! Theres nothing like a “hard peddle” (IMG:style_emoticons/default/biggrin.gif) My 74 was originally just like yours, no fog lights,1.8L but Bahia Red @friethmiller Yes but you have the coveted LE, I have the lowly garden variety. I always drop by your restoration thread daily to check your progress, amazing work my friend! Thanks! It's coming along. BTW, the LE is my 2nd 914. My red '74 is just like yours (IMG:style_emoticons/default/first.gif) Lovely!!! |
Chaznaster |
Aug 9 2024, 06:08 PM
Member Group: Members Posts: 322 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States |
Replaced the gaskets on top of the fuel tank. Replumbed the tiny tubes that daisy chain between the filler neck, condensation tank, etc.
I do not have the charcoal canister so just ran the outlet out below the tank, where the filler overflow tube comes out. I am hoping the air passing over it will help clear any fumes. I read somewhere on this forum that this was how it was done before the charcoal canisters were introduced. I am crossing fingers that this will cure the gas smell I get when the tank is full and I corner hard. |
chriselkjar |
Aug 9 2024, 10:39 PM
Newbie Group: Members Posts: 3 Joined: 15-June 23 From: California Member No.: 27,415 Region Association: Southern California |
Geezer914 |
Aug 10 2024, 02:10 AM
Replaced the gaskets on top of the fuel tank. Replumbed the tiny tubes that daisy chain between the filler neck, condensation tank, etc. I do not have the charcoal canister so just ran the outlet out below the tank, where the filler overflow tube comes out. I am hoping the air passing over it will help clear any fumes. I read somewhere on this forum that this was how it was done before the charcoal canisters were introduced. I am crossing fingers that this will cure the gas smell I get when the tank is full and I corner hard. I did the same thing, no gas fumes. |
Craigers17 |
Aug 10 2024, 10:04 AM
Senior Member Group: Members Posts: 785 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
Installed one of Spoke's E26 flasher relays. I have recently fixed my horn and replaced the turn signal apparatus, so now I finally have both turn signals working again, as well as the cancelling function on the stalk, and my horn works......the simple pleasures! Also washed and drove it!
FlacaProductions |
Aug 10 2024, 01:55 PM
Senior Member Group: Members Posts: 1,737 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Got back to Indiana and the 914 so first order of business was a drive. Then wired up a phone charger and removed and reinstalled the speedo since i'm not getting speed readings but both odometers are reading fine and accurate. Strange....especially since I have had it checked by North Hollywood and it spins up and indicates speed just fine for them. The investigation continues...
burton73 |
Aug 10 2024, 02:21 PM
burton73 Group: Members Posts: 3,655 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Got back to Indiana and the 914 so first order of business was a drive. Then wired up a phone charger and removed and reinstalled the speedo since i'm not getting speed readings but both odometers are reading fine and accurate. Strange....especially since I have had it checked by North Hollywood and it spins up and indicates speed just fine for them. The investigation continues... Brian, how did you get this shot? Best Bob B |
FlacaProductions |
Aug 10 2024, 02:36 PM
Hey Bob - @burton73 - it's an Insta360 X3 camera on a short pole that has been suction-cupped to the inside of the rear window.
It's sitting about 10" above the top of the targa bar. you can see the shadow of it on my right ear. The camera tech "paints" itself out of the shot and you can pan it 360. pretty cool. This is a frame grab from a video. If you want, we can do it with your car sometime - but i'm not great on the editing side of this. Cameras are available on Amazon...let me know if i can help. |
sb914 |
Aug 11 2024, 06:28 AM
Surf Guru Group: Members Posts: 4,365 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
drove it !
Geezer914 |
Aug 11 2024, 08:14 AM
Very nice (IMG:style_emoticons/default/driving.gif)
Artfrombama |
Aug 11 2024, 09:32 PM
wonkipop |
Aug 11 2024, 10:27 PM
Advanced Member Group: Members Posts: 4,624 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
Drove over to GA. and toured the Savoy auto museum. 280 miles RT, no problems (except we felt like cooked sausages). the twin sister in north antarctica sends her greetings to the other side of the planet. spring has almost sprung down here after 2 months of antarctic polar air mass bombardment. i get three months of top off pleasure before it gets hotter than the surface of the moon at lunar midday. (IMG:style_emoticons/default/biggrin.gif) |
Artfrombama |
Aug 11 2024, 11:05 PM
Drove over to GA. and toured the Savoy auto museum. 280 miles RT, no problems (except we felt like cooked sausages). the twin sister in north antarctica sends her greetings to the other side of the planet. spring has almost sprung down here after 2 months of antarctic polar air mass bombardment. i get three months of top off pleasure before it gets hotter than the surface of the moon at lunar midday. (IMG:style_emoticons/default/biggrin.gif) Ran into a rather friendly ol’ boy in the parking lot with some euro Limber weenie or some obscure brand. |
Stef914 |
Aug 12 2024, 12:24 AM
human Group: Members Posts: 89 Joined: 21-July 21 From: Los Angeles Member No.: 25,745 Region Association: Southern California |
Lo-Fi Version | Time is now: 27th September 2024 - 01:35 AM |
