what did you do to your 914 today |
cassmcentee |
Aug 30 2024, 12:50 PM
Member Group: Members Posts: 185 Joined: 12-July 18 From: Squaw Valley, CA Member No.: 22,304 Region Association: Central California |
SKL1 |
Sep 4 2024, 04:09 PM
Senior Member Group: Members Posts: 1,625 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
930cabman |
Sep 4 2024, 05:53 PM
Advanced Member Group: Members Posts: 3,544 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Celebrating the car's 54th birthday this month (9/70) with a trip to Stalltek Restorations in eastern Iowa this weekend. Loading it up in the new aerovault trailer compliments of the one and only Peter Brock!! Don't think the wife is looking forward to a 2 day road trip in the F150... Mix in a special fun thing for her, she probably won't forget it (IMG:style_emoticons/default/wub.gif) |
FlacaProductions |
Sep 4 2024, 06:25 PM
Senior Member Group: Members Posts: 1,737 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Oh, a trip to Iowa is ALWAY special!!
sixnotfour |
Sep 4 2024, 06:48 PM
914 Wizard Group: Members Posts: 10,524 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
New Battery, Premium Gasoline, Cleaned Windshield...Drove it like I stole it... (IMG:style_emoticons/default/driving.gif)
mgp4591 |
Sep 4 2024, 10:02 PM
914 Guru Group: Members Posts: 5,457 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Finished rerouting coolant lines, redesigned the front spoiler and air intake, bled the coolant system, changed a light bulb, and drove it like I stole it....
mate914 |
Sep 5 2024, 04:25 AM
Matt Group: Members Posts: 782 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
cassmcentee |
Sep 5 2024, 06:23 AM
Thanks Matt!
I have a MSD unit and a 123dizzy on it's way. Want to make sure I have everything hooked and working before I wrap it up. |
brant |
Sep 5 2024, 08:26 AM
914 Wizard Group: Members Posts: 11,739 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Fresh accelerator pump diaphragms on the race car webers.
Was getting a hiccup out of corners on the track Diaphragms were intact but heat hardened Hoping this cures the stumble |
sixnotfour |
Sep 5 2024, 10:16 AM
RDRUM , got rejected carbs ,, runs great top end,, I have old clewett twin plug crank fire set up..maybe an issue.. tictok.. Cutting Fire Wall to check trigger wheel timing and or 12 plug distributor install...
930cabman |
Sep 5 2024, 04:09 PM
New Battery, Premium Gasoline, Cleaned Windshield...Drove it like I stole it... (IMG:style_emoticons/default/driving.gif) The way life should be, and you lived through it (IMG:style_emoticons/default/beerchug.gif) |
Artfrombama |
Sep 6 2024, 10:05 PM
Member Group: Members Posts: 166 Joined: 21-January 24 From: Alabama Member No.: 27,870 Region Association: South East States |
Neither heater/fan blower worked. Was able to remove the ashtray and access the filthy, corroded fan contacts. Cleaned the contacts with 320 paper on the end of long needle nose pliers. Success!
Rear fan is controlled by a relay which tested good, traced the problem to disconnected spade connector on the lower side of the heater control lever. Both fans now operate like new! Ready for winter! |
Artfrombama |
Sep 6 2024, 10:08 PM
Duplicate
ctc911ctc |
Sep 9 2024, 12:58 PM
Senior Member Group: Members Posts: 917 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Before you move the car - clear the work area!
(IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/blink.gif) |
SKL1 |
Sep 10 2024, 02:02 PM
Dropped off the '71 at Stalltek in eastern Iowa for an extended stay... hopefully it will look like the fashion grey pre A coupe they're finishing now... |
ThinAir |
Sep 10 2024, 10:28 PM
Best friends Group: Members Posts: 2,553 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
It's been a week for patient puttering.
Adjusted Windows so doors shut properly Reglued vinyl on door cards Fixed carpet hold-down for passenger carpet Sorted and organized front trunk supplies and spares Replaced valve cover gaskets to fix Oil leak Ran wire for Holley display through center tunnel Washed and waxed All ready for Thursday morning departure for Red Rocks Classic! |
Shivers |
Sep 12 2024, 03:45 PM
Senior Member Group: Members Posts: 2,674 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
@Eric_Shea
I was hoping for the best. In the picture the engine mount on the left, I modified so I could run an oil line out of the side of the oil pump cover. I added a gusset on the bottom and was a bit concerned about the nylon part fitting the base of the steel engine mount. It was smaller than the stock ones which made it perfect. Not sure who made these, but PMB had a good price and they are here. Thank you Eric and the fore sightedness of the manufacture. |
Cairo94507 |
Sep 16 2024, 07:38 AM
Michael Group: Members Posts: 10,022 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
The other day I went to drive my car and when I turned on the headlights the passenger side headlight was waving to everyone, up, down, up, down... then it stayed up and all was good for the drive.
Yesterday I checked out the problem and the first thing I did was pull the relay and clean the contacts on the relay and the socket. Plugged it back in and the problem was better, but still the headlight went up and down a couple times. I adjusted the headlight stop about 1/8 of a turn out and checked the headlight operation- problem solved. I turned them on and off several times and the headlight mechanism functions as intended. In thinking about it, I had not used the headlights since before we embarked on the 3.6 swap which included the significant oil cooler upgrade. We did a bit of work in the front trunk and I believe it is possible from leaning on the nose, (we had no bumper installed at the time) as we were doing oil lines, etc., we may have slightly changed the adjustment of the headlight. Anyway, all is good now. My brother was cracking up when the headlight was just cycling up and down. Me, not so much - but it did look cool to see the car waving. (IMG:style_emoticons/default/beerchug.gif) OH, my car has been sitting for a couple of weeks now, (been stupid busy) and I was so totally happy to look under it yesterday and she is dry as can be; no leaks at all. Before the swap, I would get 1 drop of oil and 2 drips of transaxle lube on the ground. The 3.6 solved the engine drip and we addressed both of the transaxle issues while doing the swap. The Speed Sleeve solved the stub axle leak, (we replaced the seal 3 times with no success) and a new aluminum washer solved the detent nut leak on the transaxle. (IMG:style_emoticons/default/beerchug.gif) |
Artfrombama |
Sep 19 2024, 04:08 PM
Marcel Aircooled |
Sep 22 2024, 01:20 PM
Newbie Group: Members Posts: 42 Joined: 28-April 24 From: The Netherlands Member No.: 28,087 Region Association: Europe |
Lo-Fi Version | Time is now: 26th September 2024 - 11:15 PM |
