861 Pages V « < 10 11 12 13 14 > »
AndyB
post Jan 15 2012, 07:02 PM
Post #221
The Governor is watching me
Finally completed my 5 guage center console cluster (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/drunk.gif)
914-300Hemi
Post #222
I finished the electrical, charged the battery, connected the fuel line, and put gas in the gas tank. The next thing I did was look for the key and turned over the engine and got it started. (IMG:style_emoticons/default/piratenanner.gif)
ELLIOTT
post Jan 15 2012, 07:22 PM
Post #223
Fixed the drivers side window, now I can roll it up , wooohooo
Bob L.
post Jan 15 2012, 08:01 PM
Post #224
Got it started again after cleaning out the fuel system. (IMG:style_emoticons/default/piratenanner.gif)
jimkelly
post Jan 15 2012, 08:03 PM
Post #225
Delaware USA
looked at it and cried (IMG:style_emoticons/default/hissyfit.gif)
DRPHIL914
post Jan 15 2012, 08:06 PM
Post #226
Dr. Phil
Put new outer door seals on both doors
sixaddict
Post #227
Removed front wall/bulkhead and one headlight light bucket so body man can install new one. Minor damage major workk. I am whipped ...body panel removal for kids
I am happy (IMG:style_emoticons/default/smoke.gif)
hot_shoe914
post Jan 15 2012, 08:18 PM
Post #228
on ramp passer
Tore down the motor from my parts car to see if the heads were any good. (IMG:style_emoticons/default/ar15.gif)
montoya 73 2.0
post Jan 15 2012, 08:59 PM
Post #229
Lack of consideration to others, and Selfish!
Talked with McMark about building my motor! Hey, thats more than I have done in the last 4 months.
nsr-jamie
post Jan 15 2012, 09:45 PM
Post #230
914 guy in Japan
Finally added a fire extinguisher
Black22
post Jan 15 2012, 09:56 PM
Post #231
Started to install a front sway bar and then found some rust. I then treated the rust (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) , degreased my trans and cleaned out my gas tank all at the same time. (IMG:style_emoticons/default/wacko.gif)
I get side tracked easily, so I ended up only installing one sway bar mount! (IMG:style_emoticons/default/headbang.gif)
slimeygecko
post Jan 15 2012, 11:14 PM
Post #232
I completed my first engine drop to get at the tranny! It's gonna get rebuilt in the next couple of weeks while the wife is gone (IMG:style_emoticons/default/biggrin.gif)
Mike
65tuxedo
post Jan 15 2012, 11:21 PM
Post #233
While trying to get my 72. 1.7. To start, I pulled the points, bent them into shape, cleaned and set them. This didn't make it start but it did fix the tach which was going crazy when I drove it. Fixed the starting with a new fuse under the hood.
aharder
post Jan 15 2012, 11:23 PM
Post #234
Pulled the rear trunk hinges, cleaned and painted, Getting her ready for
a JWest Pivot Kit (IMG:style_emoticons/default/biggrin.gif)
pilothyer
post Jan 15 2012, 11:29 PM
Post #235
Removed the rear brake calipers to rebuild, replaced rear rubber brake lines (PITA) Then disassembled the calipers to clean up and rebuild tomorrow...........Not alot but a little every day will help me run out of things to do on this one........ eventually........I hope..........Jerry
aharder
post Jan 16 2012, 05:03 PM
Post #236
QUOTE(Scarlet75 @ Jan 15 2012, 07:02 PM) *
Andy,
Do we get to see this 5 guage cluster (IMG:style_emoticons/default/huh.gif)
effutuo101
post Jan 16 2012, 05:26 PM
Post #237
Built intake scoops for my rocker panels to feed the rear brakes.
Built side intake scoops for my rear quarters to feed the beast with a little forced air induction.
Made an absolute mess of my garage with fiberglass debris, wax paper and discarded mold materials.
Got side panel marked for potential placement of air scoop.
Realized that I have a Vespa in my garage.
Realized that both of my bikes haven't been ridden in months.
Watched some Dakar Rally.
tonight, sand scoops, cut fenders and rockers.
PeeGreen 914
post Jan 16 2012, 05:53 PM
Post #238
Nice (IMG:style_emoticons/default/smile.gif) Sounds like your car is coming along Chris. I didn't know you were back.
timofly
post Jan 16 2012, 06:48 PM
Post #239
Repaired the horn, put on better sail panel trim pieces, boxed up a bunch of parts for Bill, thought about all the other shit I should be doing, said "the hell with it" and took it out to run the "mountain". I think this was it for winter, since the morons in town started putting salt down for a 1/2 inch snowfall last week!
Man, this car loves the cold weather, but salt is a killer, so into the barn he goes, covered with plastic, tank with almost full fuel and stabilizer and 35 psi in the tires. Sigh...see you in April.
raw1298
post Jan 16 2012, 08:21 PM
Post #240
Adjusted the valve using the Capn' method. Replaced a few connecters in the wiring harness. Chased down a couple of vacume leaks. Car is running much smoother now.
- Lo-Fi Version Time is now: 23rd November 2024 - 03:50 PM
