what did you do to your 914 today |
Andyrew |
Dec 19 2011, 10:40 AM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
tradisrad |
Dec 19 2011, 11:47 AM
mrbubblehead |
Dec 19 2011, 11:56 AM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
wow tradisrad, thats pretty crazy. luckily it happened in the driveway.
i was able to take my car out this morning on my 20 mile test loop. and it is shifting perfectly! (IMG:style_emoticons/default/driving.gif) YEAH! what a difference new bushings, new clutch disc, and an adjusted shifter makes. almost as smooth as one of my vws. i wonder if a cable shifter system would make it any better? or is this just the way the internals are designed? and its as good as its gonna get? |
Bob L. |
Dec 19 2011, 11:59 AM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
yesterday- I replaced my center console panals with burled wood finish and a cup holder for my "coffee" ! - tired of it spilling- to match my doors. - I have to drill the holes for the Gauges , and will be installing a A/F ratio meter in Slot #3, next up- going to do the dash as well, and hoping to get my fresh air blower going next- it no work- (IMG:style_emoticons/default/confused24.gif) - Phil Nice wood panels. What kind of wood? I plan on doing some wood trim in mine as well. I've seen some really nice stuff. |
struckn |
Dec 19 2011, 02:50 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
Turned the Key to On and Fuel pump kicked in, EM Brake Light Flashed, Oil and Temp Light came on. Turned key to start and heard a click and everything went dead, tried Start again and nothing. Waited ten minutes and it did the same thing. Disconnected the Positive battery cable and removed the yellow tack wire from the Negative terminal at the coil, reconnected the Battery and she fired up and ran. Backed out of the garage and saw oil dripping from the Oil Filter. Put it up on ramps and took a oil filter wrench and gave it a 1/4 of a turn to snug it up. Better but still dripping. Coming down from above the filter. Only leaks when running. Drove around to my other garage and parked it for winter storage. Going to look for a good repair shop after Holiday and Income Taxes in the Spring and get everything fixed.
type47 |
Dec 19 2011, 04:33 PM
Turned the Key to On and Fuel pump ... and Income Taxes in the Spring and get everything fixed. Zach and Joe Sayre are in your area if you need a hand (hmmm, it's easy to volunteer someone else to help (IMG:style_emoticons/default/biggrin.gif) ) I finished the install of CFR SS fuel lines today after I received some parts from Tangerine. One "easy" job and I did it alone ('course the car has the engine out and is up on jack stands so that helped) |
boogie_man |
Dec 19 2011, 04:38 PM
Member Group: Members Posts: 308 Joined: 22-April 11 From: So Cal Member No.: 12,969 Region Association: Southern California |
Worked all night long in the hell hole area....rust free and proud to be (IMG:style_emoticons/default/beer3.gif)
DblDog |
Dec 19 2011, 05:17 PM
Member Group: Members Posts: 164 Joined: 8-February 05 From: San Rafael, CA Member No.: 3,578 Region Association: Northern California |
OK, it was last Friday...after WAY too long, I'm back on the road. Picked it from Mark at Original Customs...its a 72 with a used 73 1.7 and a De Bernardi enhanced side shift conversion...it shifts like butter! Now the fun begins...again.
BTW, I bought it in May of 72...brand new. |
SLITS |
Dec 19 2011, 07:07 PM
I looked at it.
I started up the six and heated it up. I went home. |
Krieger |
Dec 19 2011, 07:11 PM
Advanced Member Group: Members Posts: 4,763 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Bought her parts! Oil tank seals/spacer, spark plug wires, oil lines/fittings, carpet.
bcheney |
Dec 19 2011, 07:39 PM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
Removed pilot bearing from the flywheel...installed new pilot bearing and installed Flywheel on my 6 conversion 2.2 motor. First work I've done in months....
mrbubblehead |
Dec 19 2011, 11:14 PM
i installed a new alternator today (IMG:style_emoticons/default/piratenanner.gif) . no more screeching noise from a bearing going south. it was like a ticking time bomb. with no idea when it was gonna go off!
mrbubblehead |
Dec 20 2011, 07:50 PM
i tore the interior out today in preparation for the engman inner long stiffening kit. i also removed the tar board and white calking. thats a hell of a job. i was happy to find very little rust (IMG:style_emoticons/default/smile.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1324432207.1.jpg) i also made a little money while i was in there. (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1324432207.2.jpg) |
aharder |
Dec 20 2011, 09:03 PM
Advanced Member Group: Members Posts: 4,561 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
Tried to break the 1/2 shafts away from the stud axles (IMG:style_emoticons/default/headbang.gif) Will try again tomorrow it now time to (IMG:style_emoticons/default/beerchug.gif)
dangrouche |
Dec 25 2011, 08:45 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
[attachmentid=288
647]Road bicycle rack finally completed. I had a bunch of parts laying around and finally got around to fabricating a bike rack. Now I can ride in both of my favorite forms of transportation. Basically used metal brackets from an old garage door opener, aluminum plate, aluminum angle, and lots of allen head screws. Still need to trim off the angle and rattle can the entire thing black. Looks like Rube Goldberg, but I did a test run and its pretty sold. Oh, yeah, the bike cost about the same price as the car. Attached thumbnail(s) |
aharder |
Dec 25 2011, 09:43 PM
Cleanerd my 1/2 shafts (IMG:style_emoticons/default/biggrin.gif) |
Maltese Falcon |
Dec 27 2011, 08:52 PM
Advanced Member Group: Members Posts: 4,844 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
I hooked up a Deltran 12 volt tender to the beast, and threw it a raw steak.
jsayre914 |
Dec 27 2011, 09:05 PM
Speed Up !!! Group: Members Posts: 3,206 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
Turned the Key to On and Fuel pump kicked in, EM Brake Light Flashed, Oil and Temp Light came on. Turned key to start and heard a click and everything went dead, tried Start again and nothing. Waited ten minutes and it did the same thing. Disconnected the Positive battery cable and removed the yellow tack wire from the Negative terminal at the coil, reconnected the Battery and she fired up and ran. Backed out of the garage and saw oil dripping from the Oil Filter. Put it up on ramps and took a oil filter wrench and gave it a 1/4 of a turn to snug it up. Better but still dripping. Coming down from above the filter. Only leaks when running. Drove around to my other garage and parked it for winter storage. Going to look for a good repair shop after Holiday and Income Taxes in the Spring and get everything fixed. Your in luck Bro, cause we have the coolest 914 shop right here in York. Call Tony @ Translog http://www.914world.com/bbs2/index.php?sho...amp;hl=translog Nice to see another 914 so close. There is a bunch of us here in york. Shoot me a PM if you need any help Joseph Sayre |
PeeGreen 914 |
Dec 27 2011, 09:07 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
I went and pulled the A-arms off tonight. Next I will press out the bushings and put the Rebell Racing bushings in.
nsr-jamie |
Dec 27 2011, 09:44 PM
914 guy in Japan Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
Got my car back from the body shop today as it was in for minor repair work after my neighbor backed into the bumber. Car came out much nicer and got to repair a few other areas of the car too and didn't cost me a dime!! Very happy !! Took it for a run at night time and it was so fun !! Car is running and looking very good now.
Lo-Fi Version | Time is now: 23rd November 2024 - 01:35 AM |
