TRANSMISSION REBUILT DVD, TRANSMISSION REBUILT DVD |
Gint |
Jan 14 2012, 03:23 PM
Mike Ginter Group: Admin Posts: 16,093 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Dude those are killer pictures!
Dr Evil |
Jan 26 2012, 09:37 PM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Bao,
I got the trans case, cleaned off the old gaskets, checked the sealing surface of the front gasket, cleaned out the inside, and installed your new seal. I think what you were seeing was the seal bunching on the outside. This looks bad, but is common with the new style seals and is not an issue. The old style had a step on the outside that hid this process from view. I will contact you for return shipping payment and such. |
BAO B |
Jan 27 2012, 08:28 AM
Newbie Group: Members Posts: 43 Joined: 6-January 12 From: FLORIDA Member No.: 13,967 Region Association: None |
Bao, I got the trans case, cleaned off the old gaskets, checked the sealing surface of the front gasket, cleaned out the inside, and installed your new seal. I think what you were seeing was the seal bunching on the outside. This looks bad, but is common with the new style seals and is not an issue. The old style had a step on the outside that hid this process from view. I will contact you for return shipping payment and such. Thanks so much, When shipping the case back to me, please include gaskets ( fit between int. plate and main case). I will look for your email for payment. Bao |
BAO B |
Feb 12 2012, 05:19 PM
Bao, I got the trans case, cleaned off the old gaskets, checked the sealing surface of the front gasket, cleaned out the inside, and installed your new seal. I think what you were seeing was the seal bunching on the outside. This looks bad, but is common with the new style seals and is not an issue. The old style had a step on the outside that hid this process from view. I will contact you for return shipping payment and such. Thanks so much, When shipping the case back to me, please include gaskets ( fit between int. plate and main case). I will look for your email for payment. Bao Dr. Evil, Got the case back, everything is good. Now that i'm ready to put it all back together i have a question to ask. First, the 2 gaskets that goes in between the int. plate and main case, do i need to put sealant in between? Second, the single gasket that goes in between the int. plate and the tail cone, do i need sealant there? Also, watching the trans. dvd 2 the section where you dropped the gears into the main case, you have the 4/5 gear selected..and once the gears are in you used a screw driver to set the 4/5 gear back to neutral...specifically where is the place that the screw driver lean against in order for you to push the selector rod for 4/5 gears back to neutral? Thanks very much in advance. Bao |
Dr Evil |
Feb 12 2012, 05:27 PM
Hey Bao,
as in the DVD, there is no sealant used anywhere. Just put them on dry and you are good. For the gear selection, I cant explain better or show you better than the DVD. The simple explanation is to look inside the hole on the side of the tranz to see the rod, then put your screwdriver in there and move the 4-5 rod back into neutral. You wont mess it up. |
BAO B |
Feb 18 2012, 07:10 PM
Hey Bao, as in the DVD, there is no sealant used anywhere. Just put them on dry and you are good. For the gear selection, I cant explain better or show you better than the DVD. The simple explanation is to look inside the hole on the side of the tranz to see the rod, then put your screwdriver in there and move the 4-5 rod back into neutral. You wont mess it up. Dr. Evil, I study the dvd carefully and was able to successfully installed the gears and put the 4/5 gears back to neutral.. YES!!! Thank you. The question now is the selector rod in the correct position, as in pic. 2 the rod is in the case with all gears in neutral. Pic. 3 shows the close up of the "dong" positioned. Pic 4 shows the fork cover in position with the two fingers pointing upward. the selector rod will be in between the two fingers on the fork once the fork is installed. You noticed in pic 4 there is a skinny o ring seal only and no paper gasket seal.. is this correct? do i need a paper gasket seal also? so, from pic 1 to 4, i'm correct so far as selector rod positioning? Also, one question on the reverse gear bearing. pic. 5 shows one side of the bearing with the inner circle area lifted. pic 6 shows one side of the bearing with the inner circled area NOT LIFTED. which is the correct installed position? pic. 5 or pic. 6? Again as always, thanks for all your input and knowledge. Bao Attached image(s) |
Dr Evil |
Feb 18 2012, 10:18 PM
Well, if the dong is in the channel in the shift rods, you are good. However, the O-ring you have on the fork doesnt go on to this transmission. You need to use the paper gasket instead.
The rest looks good to go (IMG:style_emoticons/default/smile.gif) The tailshifter/nose shifter911 are the hardest to reassemble. A real PITA to get it all lined up. You should fee very proud to have come this far (IMG:style_emoticons/default/smile.gif) |
BAO B |
Feb 19 2012, 04:26 PM
Well, if the dong is in the channel in the shift rods, you are good. However, the O-ring you have on the fork doesnt go on to this transmission. You need to use the paper gasket instead. The rest looks good to go (IMG:style_emoticons/default/smile.gif) The tailshifter/nose shifter911 are the hardest to reassemble. A real PITA to get it all lined up. You should fee very proud to have come this far (IMG:style_emoticons/default/smile.gif) Dr. Evil, That's great. Can you help as far as the reverse gear bearing is concern? I'm not sure which side facing upward base on pic. 5 and pic 6. Thanks again, Bao |
Dr Evil |
Feb 20 2012, 08:44 AM
Bao, the bearing can go in either way. No top or bottom to worry about. Just make sure you put it UNDER the gear (IMG:style_emoticons/default/wink.gif)
BAO B |
Feb 20 2012, 11:05 AM
Bao, the bearing can go in either way. No top or bottom to worry about. Just make sure you put it UNDER the gear (IMG:style_emoticons/default/wink.gif) Great. thanks so much. I'll keep you and others posted upon the completion of the trans. Bao |
BAO B |
Feb 22 2012, 11:44 AM
Bao, the bearing can go in either way. No top or bottom to worry about. Just make sure you put it UNDER the gear (IMG:style_emoticons/default/wink.gif) Great. thanks so much. I'll keep you and others posted upon the completion of the trans. Bao Hello Dr. Evil I check all over the U.S. for the paper gasket for the folk cover and none have them in-house. Is in germany and won't be available for 3 weeks. Do you have any available for me to buy? Or do you know any one have them? Let me know. thanks, Bao |
Dr Evil |
Feb 22 2012, 05:04 PM
I will check. This is for an early 911 so is far less common, but I may have one.
BAO B |
Feb 22 2012, 06:49 PM
Jeffs9146 |
Feb 22 2012, 07:36 PM
Looking at some of the first photos of first gear dog teeth they look worn don't they???
Dr Evil |
Feb 22 2012, 07:49 PM
Good eyes, Jeff. The dog teeth for 1st are shot. The slider may not be. I see decent teeth, although far away, in post 39 pic 1.
Bao, you should consider replacing those dog teeth on first gear. I can help (IMG:style_emoticons/default/smile.gif) |
BAO B |
Feb 23 2012, 08:12 AM
Good eyes, Jeff. The dog teeth for 1st are shot. The slider may not be. I see decent teeth, although far away, in post 39 pic 1. Bao, you should consider replacing those dog teeth on first gear. I can help (IMG:style_emoticons/default/smile.gif) Dr. Evil I got what you're saying now after reading this, so forget about my earlier email to you. So, how do i send you the gears (dog teeth) to be replaced. Where do i start?? Thanks, Bao |
BAO B |
Feb 24 2012, 06:59 PM
Good eyes, Jeff. The dog teeth for 1st are shot. The slider may not be. I see decent teeth, although far away, in post 39 pic 1. Bao, you should consider replacing those dog teeth on first gear. I can help (IMG:style_emoticons/default/smile.gif) Dr. Evil, I'm going through this and try to describe what we have to do. Pics taking from your video, pic 4 to pic 9 described how to remove the first gear. pic 4: removed the bolt, pic 5 removed the gear and hand fork in place, pic 6 shows gear and fork together, pic 7 shows separation of fork and gear, pic 8 and 9 shows the damage gear. Is this what i need to do? if so, pic 1 shows the bolt from my trans, and should be removed, first thing ..correct? pic 2 shows the actual gear that is the same as the one from pic 8 and 9, correct? pic 3 shows another gear that should be left in place? i'm not sure. Well, let me know how i do so far. Thanks, Bao Attached thumbnail(s) Attached image(s) |
Dr Evil |
Feb 24 2012, 11:21 PM
Bao, you are close. Nice posting pics from the DVD, that helps a lot.
The part posted in the last pic is the slider. It would be nice to see pics of yours close up, but it was looking promising. The part I need is held in by the large 30mm bolt. The gear and teeth are what that slider pictured go to. One word of caution to help you not get too deep. Before you remove the slider to get to the 1st gear, mark the end of the shaft and the fork so you can reassemble them correctly and will not need to readjust using a jig. |
BAO B |
Feb 25 2012, 07:17 AM
Bao, you are close. Nice posting pics from the DVD, that helps a lot. The part posted in the last pic is the slider. It would be nice to see pics of yours close up, but it was looking promising. The part I need is held in by the large 30mm bolt. The gear and teeth are what that slider pictured go to. One word of caution to help you not get too deep. Before you remove the slider to get to the 1st gear, mark the end of the shaft and the fork so you can reassemble them correctly and will not need to readjust using a jig. Dr. Evil, So, the part you need is the picture i included in this post where i pointed to the bottom gear, which is the first gear correct? From this pic. can you tell if the teeth are 50% ..70% or garbage at this stage? If this is correct, base on your video I would need a jig [rectangle plate with 2 circle holes in it] to lock in place and to removed the 80 ft lb torqued 30 mm bolt. This required the stack NOT in the trans. case.. which is not my situation. But in my case since i already dropped the gears stack in the trans. case and i hate to take it out again, would it be much easier to use the modified tool "first gear slider with a long rod welded to it"? as shown from your video. In that case, the question is is this modified tool available to be rented out?? Let me know? Let assume i have the correct tools to removed the 30 mm bolt. In the case with the modified tool [1st gear slider with rod..] I think your dvd shows that all gears must be in NEUTRAL..correct??? before sliding the tool in place and using the 30mm breaker bar to remove the bolt. Let me know if i'm correct with all gears in NEUTRAL?? That's all for now. Thanks again, Bao |
Dr Evil |
Feb 25 2012, 12:54 PM
Yup, the part in the pic. It is about 30% at best.
I have a tool I can ship you for holding the shaft while the stack is in the case. It is a smaller version of the one in my DVD so ships easier. Also, you are in luck as I have found ONE nose cone seal for your early 911 in my parts bin. Not a common part (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 12:23 PM |
