Another brake caliper option |
Chris Pincetich |
Feb 15 2012, 04:02 PM
(IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/rolleyes.gif) Trek - you're the reason I am still hooked on my 914. Stick around dude (IMG:style_emoticons/default/shades.gif) |
Trekkor |
Feb 15 2012, 07:02 PM
Trek - you're the reason I am still hooked on my 914. Stick around dude (IMG:style_emoticons/default/shades.gif) Thanks! I'll be here now and then. KT |
Trekkor |
Feb 15 2012, 07:06 PM
Here are the lengths from mounting face (the part that presses against the body) to the end of the MC. 914 MC: 137mm Mbz MC: 154mm I have a 69 911 up on the lift and held the 23mm MC up and it looks like there is JUST enough room. This picture also shows the difference in the supply ports. This is very helpful. thanks! KT |
mrbubblehead |
Feb 16 2012, 10:53 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
anderssj |
Feb 17 2012, 09:56 AM
Dog is my copilot... Group: Members Posts: 1,689 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Volvo 240 model--fronts are 4-pot, rears are 2-pot.
Most 240 front calipers have 2 input ports (and 3 bleeders), so you'll need to address that with a "T" or something (there are some pictures here in the garage somewhere). There are 2 sets of PNs, 5002026/7 (L/R) for non-vented rotors, and 5002028/9 (L/R) for ventilated rotors. Volvo gradually switched all 240s over to vented rotors during the 1980s (our old 83 GL was non-vented), so unless you plan to go with the thicker vented rotors you'll probably have to use the earlier caliper. Another note--front calipers from late 240s with ABS (1991-1993) have only one input port and one bleeder, but are all for vented rotors. PNs for the ABS calipers are 5003754/5 (L/R). I've got a set of those sitting in my garage, but need to compare them to the non-ABS calipers and look closely for differences. Not sure about using the rear calipers, but do know that the Volvo parking brake is basically a drum brake set-up. The cable actuates a pair of shoes that contact a "drum-like" cavity inside the rear rotor. Pretty good design for what it is . . . Hope this helps! |
Gint |
Feb 18 2012, 11:35 AM
Mike Ginter Group: Admin Posts: 16,093 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
What's going on Trekkor? (IMG:style_emoticons/default/bye1.gif)
Trekkor |
Feb 18 2012, 06:22 PM
Doing really well, enjoying myself.
Car is very good. Getting ready for anther season of track driving. KT |
Trekkor |
Feb 21 2012, 07:24 PM
Just ordered the MBZ master.
KT |
yeahmag |
Feb 27 2012, 04:12 PM
Advanced Member Group: Members Posts: 2,435 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Just found this car for sale:
http://www.race-cars.com/carsales/porsche/...327370813ss.htm ...and it has Volvo 240 fronts with BMW 320 rears. Interesting combo! |
Lo-Fi Version | Time is now: 27th September 2024 - 10:47 AM |
