31 Pages V « < 23 24 25 26 27 > »
> diggin into hell, Rustoration: You have to be strong
SpecialK
post Jul 31 2005, 08:14 AM
Post #481
aircraft surgeon
QUOTE (michelko @ Jul 31 2005, 06:49 AM)
nother view
its amazing what you can do with some sheet metal and a hammer
"...its amazing what you can do with some sheet metal and a hammer."
(IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif)
michelko
post Aug 6 2005, 08:24 AM
Post #482
So guy´s
i decided for the por 15 way. Grind down the panel to bare metal (exept the great ding), wash it with marin clean, prep it with metal ready, paint some por 15. So far so good. then tie coat primer, then bondo the little scratches and dings, sand all smooth, shoot filler, again sanding/filling, last but not least the blue paint.
This is the plan , let´s see how it works.
the first four steps i did today, see the pics.
#1 after metall ready
michelko
post Aug 6 2005, 08:25 AM
Post #483
michelko
post Aug 6 2005, 08:26 AM
Post #484
michelko
post Aug 6 2005, 08:27 AM
Post #485
michelko
post Aug 6 2005, 08:29 AM
Post #486
the next ones with the por15 on
the difference in the look is realy amacing
#5
michelko
post Aug 6 2005, 08:30 AM
Post #487
michelko
post Aug 6 2005, 08:31 AM
Post #488
michelko
post Aug 6 2005, 08:32 AM
Post #489
michelko
Post #490
michelko
post Aug 6 2005, 08:34 AM
Post #491
till now i am realy sattisfied with the result.
can´t wait to go further.
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif)
post Aug 6 2005, 01:02 PM
Post #492
Resident German
QUOTE (michelko @ Jul 31 2005, 05:44 AM)
found a little rust hole. can you see it?
yes, you have to remove the hard foam filler that's sitting inside the cavity (from underneath) and clean it all out really good and use lots of "Metal Ready" in there.
that's a very common rust spot on those cars. the seam sealer around the foam cracks after a few years of road use and allows water to seep in.
the foam acts like a spunge and keeps the water in there until it has eaten it's way through the metal ...
(IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) Andy
michelko
post Aug 6 2005, 01:36 PM
Post #493
QUOTE (SirAndy @ Aug 6 2005, 11:02 AM)
so you (mean I ) can access that foam from the wheel well?
Gruss aus der alten Heimat (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif)
post Aug 6 2005, 01:46 PM
Post #494
Resident German
QUOTE (michelko @ Aug 6 2005, 12:36 PM)
yes, from inside the wheel well. you'll see that the cavity is filled with "something" and has seam-sealer around it (might have undercoating over it) ...
once you start "digging" into it, you'll see it's the same yellowish foam they used in so many other places on our little cars.
you have to get it all out and clean it up really well. if it's already rusted through the top, i wouldn't be surprised if it also ate through into the rear trunk and behind the taillights (on the side) ...
Viel Spaß beim Restaurieren!
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) Andy
michelko
post Aug 16 2005, 01:03 AM
Post #495
Hi everybody, here is some update on the project.
Like sirandy mentioned, i scraped out the foam. Nearly impossible from wheel well. "Fortunately" (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) there was an hole in the fender, so i could use this as a window to access the schitty foam. found some nice rust under it.
Sorry no pic of it.
Metallreadyied the hell out of it and then put some por 15 over.
After that i shot a coat of tie coat primer on it
michelko
post Aug 16 2005, 01:04 AM
Post #496
nother
michelko
post Aug 16 2005, 01:06 AM
Post #497
next step:
filling the little dings with bondo an sanding it
some more to go , but looks nice again
michelko
post Aug 16 2005, 01:07 AM
Post #498
nother
michelko
post Aug 16 2005, 01:08 AM
Post #499
last one
CptTripps
post Aug 16 2005, 06:22 AM
Post #500
:: Punch and Pie ::
Unsolicited Advice: MAKE SURE you get this section PERFECT. I didn't, and I've been mad at myself ever since.
Don't be afraid to go back down to metal again to get it right. I thought "I'm too far at this point to go back" before I painted, and afterwards, I've been kicking myself for NOT going back and fixing it.
Looking great man!
- Lo-Fi Version Time is now: 23rd November 2024 - 12:59 PM
