Tranny in neutral despite shifter, Car currently broke down on road |
Red-Beard |
Sep 15 2004, 02:14 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
The correct roll pin is available from Porsche or Pelican.
Cost , about $1. Plus shipping...might be easier to get it from a Local Porsche dealer. You cannot use the "C" roll pins from a flaps because they are not strong enough. I did successfully put a small C roll pin inside another and pound this into the hole and that did work. Then I found out that the roll pin is cheap. |
rhodyguy |
Sep 15 2004, 03:37 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i told you what size the pin was in my post. get 2. they're cheap all right unless you order from AA and you get charged $6 for shipping and handling.
kevin |
86motoman |
Sep 15 2004, 05:12 PM
Member Group: Members Posts: 200 Joined: 13-May 04 From: Walla Walla, WA Member No.: 2,064 |
QUOTE(Red-Beard @ Sep 15 2004, 12:14 PM) You cannot use the "C" roll pins from a flaps because they are not strong enough. I did successfully put a small C roll pin inside another and pound this into the hole and that did work. Then I found out that the roll pin is cheap. uh-oh...I didn't use a double roll pin. I used the standard "C". It is shifting excellent right now. Do you think the standard will be strong enough for a couple of weeks until I order one?? I start school next monday...and I work on the weekends! |
Dr Evil |
Sep 15 2004, 05:27 PM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
It depends, do you feel lucky? (IMG:style_emoticons/default/rolleyes.gif)
86motoman |
QUOTE(rhodyguy @ Sep 15 2004, 01:37 PM) i told you what size the pin was in my post. get 2. they're cheap all right unless you order from AA and you get charged $6 for shipping and handling. kevin Good call that's exactly what happened. I just ordered one from my AA dealer. I hope the regular C will last a couple weeks. |
86motoman |
Sep 15 2004, 06:04 PM
I could of swore that somebody posted they successfully doubled up some pins??? Did somebody delete there post or am I going crazy??
Anyway...I doubled up two normal "C" pins, to my surprise it went in just fine. I am hoping the pins are just as strong??? Has anyone done this successfully? Works great right now. I have distinct areas/gates for each gear!!! At the most it has 3" of slop...not bad from when I started. I was completly undrivable when I bought it. |
Red-Beard |
Sep 15 2004, 06:13 PM
Yes, I posted that. I put a small c inside a bigger c and it worked for a year. Then I converted to sideshift and it makes no difference now...
And someone wants the end peice of my tail shift 6 and I can't get the C pins out now. Broke 2 tools trying to drive them out! Dr. Evil was there. The single C lasted a couple of days and I then had to change the thing in the parking lot at work... James |
86motoman |
Sep 15 2004, 06:27 PM
QUOTE(Red-Beard @ Sep 15 2004, 04:13 PM) The single C lasted a couple of days and I then had to change the thing in the parking lot at work... James I am glad I took the time to double them up (small c in bigger c). Hopefully mine will be good and strong to. I do have the others ordered as well. Thankyou guys!!! (IMG:style_emoticons/default/rocking nana.gif) In a couple of days I will post some pictures of my success with this little car. I was only able to do it because of you guys helping. Thankyou! (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 01:02 PM |
