intake tube alignment, 3/4 tube to the distributor is off |
TheCabinetmaker |
Mar 22 2012, 07:14 AM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Facts: The plenum is installed correctly. There are right and left intake runners. The runners in your pics are not for a 2.0 (they wouldn't bolt to the heads and they would be way short). Conjecture: Your first pic shows the passenger side plenum tubes the same length. The tubes on the runners are not the same length. On a 1.7 plenum, the #3 tube is about a half inch longer than #4. In post #10 it "appears" the #4 tube is sticking inside the plenum? It also appears that #3 runner is touching the plenum. I don't have a 1.8 plenum to compare with physically, but comparing the two visualy, it looks like the 1/2 side of the two plenums are about the same while the 3/4 sides are much different. The 1.8 plenum is much "fatter" than the 1.7 on the 3/4 side. More conjecture: At least one of your intake runners is from a 1.7. |
malcolm2 |
Mar 22 2012, 07:28 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I think that you may be using thicker intake gasket, where did you get them from? Gasket set came from Type 4 store. They are the same on both sides and 1/2 fits nicely. It may look a bit different in the picture, cause I don't have the intake tubes bolted down on the off center side. My main question here is will this leak? If so, is that an issue? And then of course, how do I fix? |
malcolm2 |
Mar 22 2012, 08:09 AM
Facts: The plenum is installed correctly. There are right and left intake runners. The runners in your pics are not for a 2.0 (they wouldn't bolt to the heads and they would be way short). Conjecture: Your first pic shows the passenger side plenum tubes the same length. The tubes on the runners are not the same length. On a 1.7 plenum, the #3 tube is about a half inch longer than #4. In post #10 it "appears" the #4 tube is sticking inside the plenum? It also appears that #3 runner is touching the plenum. I don't have a 1.8 plenum to compare with physically, but comparing the two visualy, it looks like the 1/2 side of the two plenums are about the same while the 3/4 sides are much different. The 1.8 plenum is much "fatter" than the 1.7 on the 3/4 side. More conjecture: At least one of your intake runners is from a 1.7. The picture in post 10 is angled such that the 3/4 tubes look different, plus the 3/4 tubes are not bolted so they are lying under the plenuem tubes....Basically the tubes are exactly the same with the expection of the one tube that will not line-up with a plenum tube when mounted on either side. They came off of this engine and were formerly bolted to 1.8 liter heads. Question will this leak, will it be a problem? |
JamesM |
Mar 22 2012, 08:18 AM
Senior Member Group: Members Posts: 1,965 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
TheCabinetmaker |
Mar 22 2012, 08:30 AM
I never looked that close, but James is correct. That is a 1.7 plenum. The last pic on that post shows the difference i'm talking about.
Malcom, I don't doubt those are the parts you took off but still does not mean they are correct. To answer your question, if you can get the sleeves on and clamp them, then they probably won't leak. |
underthetire |
Mar 22 2012, 08:36 AM
I've tried to use the 1.8 runners on the 1.7 plenum. They just dont fit.
Spoke |
Mar 22 2012, 02:32 PM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Lo-Fi Version | Time is now: 27th September 2024 - 11:58 AM |
