11 Pages V < 1 2 3 4 5 > »
> How many Non-OEM type Engine conversions, are represented on 914world.com?
BIGKAT_83
post Nov 15 2004, 12:03 PM
Post #41
QUOTE(Root_Werks @ Nov 15 2004, 09:54 AM)
QUOTE(BIGKAT_83 @ Nov 15 2004, 09:42 AM)
The newer Aluminum LSx engines will mount up with No mods to the front firewall if you are using a remote water pump as with the SBC. You would need to reverse the intake to have the throllte body facing the rear of the car and this takes cutting a hole in the rear firewall about as big as what is used for the distributor on the SBC.
Bob (IMG:style_emoticons/default/biggrin.gif)
Can't you just toss a carb on it? If the block is basically the same as say a post 86' block, can't you just K.I.S.S. and slap on a decnt 650 carb, HEI Ign and go?
Sorry for the questions, but sure seems like the way to go to me.
No way. The LSx engine is a completly new engine and shares no parts with the older gen1 and gen2 sbc engines. There is a aftermarket carb intake and ign. system for the LS series engines, but that would be a big step backward.
Bob (IMG:style_emoticons/default/smile.gif)
andys
post Nov 15 2004, 12:07 PM
Post #42
The newer Aluminum LSx engines will mount up with No mods to the front firewall if you are using a remote water pump as with the SBC. You would need to reverse the intake to have the throtlle body facing the rear of the car and this takes cutting a hole in the rear firewall about as big as what is used for the distributor on the SBC.
Bob,
Couple of questions on the LS1 conversion: Did you use the stock LS1 crank pulley? Was the motor/trans moved back the standard amount per the RH trans mount? What mod's did you have to make to the motor mount bar/mounting points? Did you use the stock LS1 oil pan, or go with the shorter 'Vette pan and pick-up?
Thanks,
Andy
andys
post Nov 15 2004, 12:14 PM
Post #43
QUOTE(turbo914v8 @ Nov 15 2004, 09:54 AM)
First of, let me just say that is a real honor to be on the list and to be part of such a great group of interesting people. Enough a$$ kissing. You can get an all aluminum virgin block from an number of suppliers. I almost got the aluminum block from Brodix. What changed my mind was not only the price tag of $3800.00 US, but at the end of the day you only save in the neighbor hood of about 100 lbs. Not worth the out lay of cash for 100lbs weight savings imo.
Regards,
turbo Paul.
Paul,
This is not too different than the LSx series motors. The cast iron 6.0L LQ4 truck block only weights 65lbs. more than the aluminum 5.7L LS1 block. Interesting that the LS1 bare blocks are less expensive than the LQ4.
Andy
Root_Werks
post Nov 15 2004, 12:20 PM
Post #44
Village Idiot
QUOTE(andys @ Nov 15 2004, 10:14 AM)
Regards,
turbo Paul.
Paul,
Andy
Wow, I didn't realize the wieght was so close.
Me thinks it would be best to grab a iron 350 with alum heads intake. Good enough.
Yeah, yeah, I am a big 914-6 guy, but thinking about doing a V8. The power behind it just sounds dam fun. (IMG:style_emoticons/default/driving.gif)
BIGKAT_83
post Nov 15 2004, 12:30 PM
Post #45
QUOTE(andys @ Nov 15 2004, 10:07 AM)
I'm using the stock F-body pan
Bob,
Thanks,
Andy
Andy
I used a C5 vette pulley. these are shorter than the f-body pulley.
I think the only reason the transaxles are moved back the standard 1.25" is this is how the SBC mounts in the 914. If you center up the stock chevy engine mounts with the 914 engine body mounts it places the transaxle back 1.25"
The LS1 mounts are farther back on the engine. I've made 2 sets of mounts. The first one uses a crossbar mount system like a 914 SBC and moved the engine mounts farther forward on the block.
The other mounts bolt solid to the engine and use rubber mounts at the stock 914 body mounts
this makes a nicer mount with no bar haning under the car.
aircooledboy
post Nov 15 2004, 12:31 PM
Post #46
Sweet Pea's 1st ride in daddy's "vroom -vroom"
QUOTE(Root_Werks @ Nov 15 2004, 12:20 PM)
Dude,
I just got back from getting some lunch in mine. I feel like shit today (IMG:style_emoticons/default/icon8.gif) , I can't even see my desk, and I feel too lousy to do anthing about it. But the fun of driving that car even for a few miles made me forget about all of it for 45 minutes. (IMG:style_emoticons/default/driving.gif)
Root_Werks
post Nov 15 2004, 12:46 PM
Post #47
Village Idiot
QUOTE(aircooledboy @ Nov 15 2004, 10:31 AM)
Dude,
I followed your thread about your 914 when you first bought it. I liked that you drove it 900+ miles. Seemed to be relaible. I don't know if I will do a V8, but if I do, I know I will have plenty of advise! (IMG:style_emoticons/default/laugh.gif)
soloracer
post Nov 15 2004, 12:47 PM
Post #48
Add me to the list. I'm working on a 1973 914 Twin Turbo Three Rotor Rotary engine swap. I have accumulated most of the parts I need to get started (adapter plate, clutch, flywheel, radiator, motor mounts, etc.) I just bought a new place with a big shop and as soon as I get settled in I will start my own build thread.
chunger
post Nov 15 2004, 01:15 PM
Post #49
Felix,
Nice. . . I conned myself into buying a running 914 (IMG:style_emoticons/default/smilie_pokal.gif) Actually, the way I'm wired, if I'm driving one, I'll have double motivation to finish the V8. Another issue that motivated the purchase was price. . . and in the back of my mind, there was the fact that this car already had on it an ideal suspension for V8. . . and I have all the parts to do a quick conversion on a running car. But now that I have it, I feel it'd be nice to keep the car legal in it's class. . . .since I have an all new 5 lug suspension for the project already. And my scirocco is going to die. I need a reliable running car.
-'Chung
aircooledboy
post Nov 15 2004, 01:23 PM
Post #50
QUOTE(chunger @ Nov 15 2004, 01:15 PM)
Doh!! (IMG:style_emoticons/default/headbang.gif)
MarkG
post Nov 15 2004, 01:25 PM
Post #51
I've been wondering if I could cram a 308 series Ferrari engine in mine.......
dwillouby
post Nov 15 2004, 01:34 PM
Post #52
You can add mine to the list. dwillouby KY 914 355V8.
David
turbo914v8
post Nov 15 2004, 01:36 PM
Post #53
Gentlemen,
If the 914 v8 is done correctly, I see no reason why it can not be a daily driven car. I am reading a lot of comments that suggest people are still afraid to drive the 914 v8 as a daily driver. We have a large enough community with many examples of well done 914 v8's, I am sure that there must be a few out there that drive their car's daily. Feel free to chime in at any time.
Regards,
Turbo Paul.
DougC
post Nov 15 2004, 01:52 PM
Post #54
Mine's got some ways to go yet but will have SBC power soon.
Doug C
Mueller
post Nov 15 2004, 02:08 PM
Post #55
914 Freak!
can you add?
914club member: 914turboford,
engine: Ford 2.3 turbo EFI (mounted sideways)
aircooledboy
post Nov 15 2004, 02:21 PM
Post #56
QUOTE(turbo914v8 @ Nov 15 2004, 01:36 PM)
I drive mine every day that it is not raining when I leave the house. I will continue to do so until the first salt hits the roads, especially since I just plumbed in my heat last week.
Root_Werks
post Nov 15 2004, 03:01 PM
Post #57
Village Idiot
Oh, I don't think there is any question that a basic, well done sbc will last a ton of miles in just about any car. Plus, you can pick up a long block from just about any FLAPS! (IMG:style_emoticons/default/laugh.gif)
I would think any question would be in the install. Say the cooling system. Did someone really hack up the 914 to install the hoses and rad? Something along those lines.
So aircooledboy (contradiction in terms (IMG:style_emoticons/default/biggrin.gif) ), do you use the stock 901 gear set?
aircooledboy
post Nov 15 2004, 03:25 PM
Post #58
Only until I take it to Brad Mayuer this hibernation season. Then it will be taller-gears-o-rama (IMG:style_emoticons/default/boldblue.gif) It is fine for now as is, but I will enjoy highway driving much more after the gear swap.
BTW, only ONE of my teeners is a waterpumper. I will always be air cooled at heart. After all, I am just like a TIV powered 914 (slow, out-dated, a little rusty, with loud putt putt noises coming from the back end, but very quick in tight spaces and damn good fun on a nice day (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/w00t.gif) )
neo914-6
post Nov 15 2004, 03:30 PM
Post #59
neo life
Chung,
I wish I had the cash at hand to buy that car for my Neo914. Even if I did, my wife won't let me bring it home. (IMG:style_emoticons/default/sad.gif)
Paul,
Where the hell are the pics of your car.? Check out "Dinner and Chris Julians" thread. He said he had a pic but was sworn not to show it. Why are you holding out? (IMG:style_emoticons/default/confused24.gif)
All newbies,
Thanks for chiming in with your projects. Post some pics so I know you're for real! (IMG:style_emoticons/default/laugh.gif) Just kidding, there are ALOT of projects in the works. We are tackling what typically takes millions of dollars, 100's of engineers, and years to accomplish. So the result are rarely "factory" but we do our best...
Felix
Rider914
post Nov 15 2004, 08:14 PM
Post #60
I have a '72 914 SBC that was a daily driver for 5 years, now it is a garage queen!!! I got tired of parking in that far corner spot, no radio or AC. One day some guy got out of his car and mooned me at a traffic light, it attracts too much attention. Damn the price of fame. . .
- Lo-Fi Version Time is now: 23rd November 2024 - 06:47 AM
