45 Pages V « < 37 38 39 40 41 > »
> Porsche 914 - 8 GTT, November '24 Update
Maltese Falcon
post Dec 22 2023, 09:39 PM
Post #761
Coolant pump bracket layout and 12v relay base-bracket
Maltese Falcon
post Dec 22 2023, 09:41 PM
Post #762
Make sure it fits: tack weld & re-check installation
Maltese Falcon
post Dec 22 2023, 09:49 PM
Post #763
Coolant pump relay-base finished
Maltese Falcon
post Dec 22 2023, 09:52 PM
Post #764
Good location for the pump
Maltese Falcon
post Jan 12 2024, 08:17 PM
Post #765
Just a few wires to connect, bolt some brackets into place; the finished components shown here.
Maltese Falcon
post Jan 27 2024, 11:14 AM
Post #766
Bottom view of the transaxle cooler pump ; next secure the resevoir bracket, and weld up the rear mounted radiator support brackets
Maltese Falcon
post Jan 27 2024, 11:26 AM
Post #767
The 2) resevoir bracket mounting points wind up in here. The shock towers are reinforced, and oe spotweld areas have all been fully mig welded.
krazykonrad
post Jan 27 2024, 12:00 PM
Post #768
Looking good! That thing is going to be a rocket.
Maltese Falcon
post Jan 27 2024, 01:52 PM
Post #769
@krazykonrad if not a rocket...we will be OK with a slow jet (IMG:style_emoticons/default/biggrin.gif)
KELTY360
post Jan 27 2024, 02:11 PM
Post #770
914 Neferati
QUOTE(krazykonrad @ Jan 27 2024, 10:00 AM) *
@Maltese Falcon Any idea when it will be ready for the launch pad?
Maltese Falcon
post Jan 27 2024, 02:48 PM
Post #771
@KELTY360 not anytime soon...but best to view this page as an archive in the making (IMG:style_emoticons/default/smile.gif)
Couple of Slow jets spotted over Lancaster CA recently !
Maltese Falcon
post Feb 1 2024, 09:27 PM
Post #772
Trans cooler resevoir 'nailed in place
Maltese Falcon
post Feb 6 2024, 11:18 PM
Post #773
coolant hose routing, starting at the pump inlet
Maltese Falcon
post Feb 6 2024, 11:24 PM
Post #774
Before trimming out the new plexi windows for side impact bar clearance, making sure to check the fit with a sturdy cardboard template
Maltese Falcon
post Feb 6 2024, 11:30 PM
Post #775
Throwing it back to the 2010 Daytona 24hr, Action Express engine change during Thursday practice; that Wilson intake plenum (#001) is on our Cayenne v8 !
Maltese Falcon
post Feb 6 2024, 11:34 PM
Post #776
2010 Daytona 24hr list of drivers for the #9 Action Express/ Riley Porsche.
Engine rated at approx 570 hp n/a
Maltese Falcon
post Mar 3 2024, 07:38 PM
Post #777
Transaxle cooler (heat exchanger) support brackets in the paint dept: hanging from the safety cage of the shop forklift (IMG:style_emoticons/default/smile.gif)
Maltese Falcon
post Mar 3 2024, 07:52 PM
Post #778
During the L.A. Porsche Lit week, I had a couple of surprise visitors over to MSDS shop; Glenn @gms and Andrew @Moparboy72 .They had a good look see around the 8gtt project, then presented us with a passing grade (IMG:style_emoticons/default/biggrin.gif)
I also walked them through the exhaust fabrication process and they are both now Top Tier header specialists !
Maltese Falcon
post Mar 3 2024, 07:56 PM
Post #779
Andrew checking out the inverted 996 gt2 transaxle and its support system.
Maltese Falcon
post Mar 3 2024, 08:05 PM
Post #780
Wrapping up, then a ride towards LAX and time for a quick coffee break
- Lo-Fi Version Time is now: 23rd November 2024 - 05:52 PM
