Porsche 914 - 8 GTT, November '24 Update |
Maltese Falcon |
Mar 3 2024, 08:19 PM
Advanced Member Group: Members Posts: 4,845 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
My truck / so my music choice; they had to put up with my Country station The Bakersfield Beat...as Dwight Yoakam says " Music from the Dust bowl to the Hollywood bowl" (IMG:style_emoticons/default/biggrin.gif)
(IMG:style_emoticons/default/marty914.jpg) |
Moparboy72 |
Mar 8 2024, 02:45 PM
Newbie Group: Members Posts: 4 Joined: 5-March 08 From: Naperville, IL Member No.: 8,778 Region Association: Upper MidWest |
Marty,
Thanks for showing us around your shop and the wicked 914 - 8 GTT! It was great spending time with you and I even enjoyed the country music too (IMG:style_emoticons/default/aktion035.gif) Thanks again! |
Maltese Falcon |
Mar 16 2024, 12:42 PM
Maltese Falcon |
Mar 16 2024, 12:46 PM
Maltese Falcon |
Mar 16 2024, 12:50 PM
NorCalScott |
Mar 16 2024, 11:46 PM
Newbie Group: Members Posts: 30 Joined: 6-February 21 From: Sacramento Member No.: 25,173 Region Association: None |
I like that idea for the oil cooler brackets. The bracket stays out of the way. Nice execution with the correct angles! Keep working on the car and giving us updates. I check almost daily. lol
Maltese Falcon |
Mar 17 2024, 09:45 AM
@NorCalScott your comments + enthusiasm are much appreciated! I do cheat a little on our bracket set-ups; CAD...cardboard assisted design (IMG:style_emoticons/default/smile.gif)
Maltese Falcon |
Mar 17 2024, 09:54 AM
Pre fitting all of the targa area aluminum trim, before
the pieces head into the body shop for detailing + black coating. I'm big on all of the small 914 items that we can integrate back into this custom build. Shoutout to @Montreal914 for sourcing the rear targa trim pieces for us ! |
Montreal914 |
Mar 17 2024, 10:55 AM
Senior Member Group: Members Posts: 1,701 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Glad I was able to somewhat contribute to this build (IMG:style_emoticons/default/biggrin.gif).
BTW, you picked up that trim at our previous house (rental). We bought our house and moved to Claremont 8 years ago… (IMG:style_emoticons/default/blink.gif) So…time flies… Then, I had started rebuilding a 74 914 (white repainted red) while enjoying my 73 DD bought when I moved to CA late 2009., I later decided to pass along the 74 project and focus only on my 73, restoration that is still ongoing… (IMG:style_emoticons/default/rolleyes.gif) The white 74 car project is in good hands with Glenn @pencap914 . (IMG:style_emoticons/default/smile.gif) |
Maltese Falcon |
Mar 17 2024, 03:16 PM
@Montreal914 mais oui !¡ time flys when you're having fun with these little cars (IMG:style_emoticons/default/smile.gif)
à bientôt (IMG:style_emoticons/default/marty914.jpg) |
NorCalScott |
Mar 17 2024, 11:45 PM
I assume you're probably using the same rubber isolators to mount the oil coolers as you did to mount the trans cooler. Although they're probably very generic, I'm still curious which ones you're using.
Maltese Falcon |
Mar 18 2024, 06:59 PM
I assume you're probably using the same rubber isolators to mount the oil coolers as you did to mount the trans cooler. Although they're probably very generic, I'm still curious which ones you're using. For the smaller isolater-rubber buffers, like the 4 mounting points (sae ¼x20 threads) on this trans radiator: I just use neoprene or silicon muffler-bracket inserts. I just lightly disc sand these to remove any bumps, and install with small fender style washers, then a wavy washer and a little torque. For bigger accessories like a large intercooler (8mm or 5/16 threads) same technique but I use a larger silicon- buffer...also a donor from a muffler- bracket. |
Maltese Falcon |
Mar 18 2024, 07:53 PM
NorCalScott |
Mar 20 2024, 12:55 PM
Thanks for the info! I appreciate it.
rgalla9146 |
Mar 21 2024, 06:21 AM
Advanced Member Group: Members Posts: 4,651 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
@Montreal914 mais oui !¡ time flys when you're having fun with these little cars (IMG:style_emoticons/default/smile.gif) à bientôt (IMG:style_emoticons/default/marty914.jpg) Mon Dieu ! |
Maltese Falcon |
Apr 20 2024, 09:25 PM
Maltese Falcon |
Apr 20 2024, 09:28 PM
Maltese Falcon |
Apr 20 2024, 09:36 PM
ClayPerrine |
Apr 21 2024, 06:38 AM
Life's been good to me so far..... Group: Admin Posts: 15,901 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
When you get this finished, you should duplicate the paint job on the Sounato GT, but with number 41.
Maltese Falcon |
Apr 21 2024, 01:29 PM
Lo-Fi Version | Time is now: 23rd November 2024 - 05:26 PM |
