Euro Turn Signal Conversion $280.00 plus shipping |
Martin Baker |
May 20 2013, 08:44 PM
I just heard I sold my cars! Group: Members Posts: 1,140 Joined: 11-February 03 Member No.: 290 Region Association: Northern California |
To make it a little more clear, current prices for my conversions.
Ready to Install, complete pair of signal housings. $280.00 plus shipping. Attached thumbnail(s) |
Martin Baker |
May 20 2013, 08:46 PM
Installed....
Martin Baker |
May 20 2013, 08:49 PM
More, I love 914 types.
Martin Baker |
May 20 2013, 08:54 PM
Martin Baker |
May 20 2013, 08:59 PM
This shot gives a good idea of how much light a 7.5 watt bulb can make. Originally the cars used a 6 watt bulb which will fit this socket, I use a 7.5 as it is the most available bulb, and resonably priced. Original type bulbs can be found in a Salvage Yard, try BMW makes. I found a couple, and are still in my Orange car....they may have been the reverse lights, 3 or 5 Series. Not sure.
914Sixer |
May 20 2013, 09:07 PM
914 Guru Group: Members Posts: 8,863 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Pretty Cool !!!!!
mharmon |
May 20 2013, 10:44 PM
Member Group: Members Posts: 129 Joined: 1-November 06 From: Los Angeles Member No.: 7,133 |
I'll take 1 complete set and 1 DIY if you have them available.
Please let me know. Thanks Martin. Mike |
Martin Baker |
May 20 2013, 11:03 PM
Mike Thank You! I can make the refractors in an evening. I just came up from the Garage, I do not have two sockets, I need to order some. Normally take a couple of days from the supplier.
Martin Hey Sixer, Thanks for the kind words! |
JmuRiz |
May 21 2013, 07:58 AM
914 Guru Group: Members Posts: 5,422 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I'll send you a PM, these'll go great with my car.
horizontally-opposed |
May 21 2013, 10:52 AM
Advanced Member Group: Members Posts: 3,430 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Hey Martin,
I'd like to do this when I get through the engine conversion, and will probably want to ship my housings to you. Would you be willing to do it that way? Very cool mod! Thanks! pete |
Harpo |
May 21 2013, 04:34 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Very interesting. Does this require a special lense? Will this fit in a Medium USPS box?
Thanks David |
Martin Baker |
May 21 2013, 07:27 PM
When I started making these, I would make a set for three pairs in trade, send me three sets, I send you back a restored set, I kept two sets to restore/sell, which worked OK, but many that I recieved were unusable, corroded, bent, missing parts, etc. I still have all the rejects in a box, big box. I have given up on that method, as one persons idea of usable may be very different from someone else's. I can't sell to someone a housing thats been crushed, or so corroded that the terminal cap has no lugs to retain it. One guy sent me six housings, and all six were unusable. So Yes, by ALL means, if you have nice housings and want them done, I will do them, here, and insure you get back what you sent. I have seen a few where the original finish still looks great, and if they do, I do not paint them. Just install a refractor and wire them. I am nearly out of useable housings, so for me, doing yours (Pete, or anyone else!)is a better deal. Before you send, look to see that the contour of the sides of the housing have a unifom shape, the housing is not cracked from someone screwing in the retaining stud to far into the housing. Seen a few of those. Inspect the area where the electrical terminal cap is, to insure the lugs that retain the white terminal cap, can be re-installed and secured.
No special lense, only a normal Euro lense is required. What you see here is an exact copy of what the factory did. Martin Attached image(s) |
Martin Baker |
May 21 2013, 07:40 PM
Thank you to both of the buyers for these two sets, I will start tonight on two more sets, plus a display set for the swap meet. Also, if you bought a set of these from me in the past, and would like to have the refractors polished, its do able. PM me, it would not be that much work. It really makes a difference. FYI, 5 pairs of sockets are on the way.
Martin |
Harpo |
May 22 2013, 09:53 AM
I'm interested if any are still available
Thanks David |
Martin Baker |
May 22 2013, 10:23 AM
Begin another pair tonight. I will make one set of those for you if you like.
Martin |
jim_hoyland |
May 22 2013, 01:25 PM
Get that VIN ? Group: Members Posts: 9,256 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
PM sent
rgalla9146 |
May 22 2013, 08:44 PM
Advanced Member Group: Members Posts: 4,544 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Martin Baker |
May 22 2013, 09:13 PM
PM sent Hello What is the cost if I send you my usable units ? Can you post a picture of the unit from the rear outside ? I'm curious about the connectors. Rory Sure no problem on the photo, its completly original in appearance, as I mentioned earlier. 100% like the original. Plug it in. I duplicated the original as close as possible. What it does is deactivates the park light side of the 1157 bulb, and wires up the 89 bulb internally. An original Euro uses a single filament bulb in both positions. I have thought a bit about the price of a conversion, so if you ship them to me, and they must be usable, (as I am now out of usable housings) I will do them for $200.00 returned shipped to your location. I think this is fair, and it would be around a week turn around if I have parts on hand. I currently have sockets on order. Martin Attached thumbnail(s) |
B2524 |
May 23 2013, 07:49 AM
It's a sickness. Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California |
interested in a set. can you PM me your phone # so we can hook up at the swap meet?
i need to check my stash and see if i have any i can trade in. thanks Kent |
Martin Baker |
May 23 2013, 09:34 AM
interested in a set. can you PM me your phone # so we can hook up at the swap meet? i need to check my stash and see if i have any i can trade in. thanks Kent Sent requested PM, yes to all who have extras and want a restored set, look for me there at the Swap. I'll be with my SONAUTO replica. We can save you some CASH on shipping to me, and return them back to you quickly. Martin |
Lo-Fi Version | Time is now: 19th April 2024 - 08:06 PM |
