Straightening a 914, no one around here has a cellette |
rick 918-S |
Nov 25 2013, 09:54 PM
Hey nice rack! -Celette Group: Members Posts: 20,680 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
This is all good information. Thanks for the offer George I may need your help. What ever I do I plan to be there to watch and supervise. John Wish you were closer. I'd pull it for you. You could always tow dolly it up here.... (IMG:style_emoticons/default/idea.gif) I'm going to rent the Celette fixtures sometime around the end of February I think for the 6. I think I am going to try to talk Scotty b into towing out his rear hit car. It could be an interesting week. (IMG:style_emoticons/default/idea.gif) |
rick 918-S |
Nov 25 2013, 09:59 PM
Just adding to the above, I think you are also going to have to cut the cage. I'm helping remake a Caterham frame now that was wrecked then attempted to be straightened on a bench. The end result was doubling the number of buckled tubes and cracked welds (as compared to the original accident). The weld cracking was a bit scarier as not all was easy to see (unlike the painfully obvious tubes) and wouldn't have been found without a cafeful inspection. For reference, Caterhams are TIG welded, fillet brazed, and them most likely stress relieved, so their joints are significantly more ductile than the MIG welds on most cages. I believe that Caterham was more likely gas welded like an air frame. Specially if it's 4130. The best process for 4130 is gas welding. Tig works if properly stress relieved. The heat concentration with tig is too small causing the welds to cool fast rather than naturalize with the tubes. Lots of guys tig tube I know but I'm referring to the likely method back in the day. The best method is still old school. You're correct. The frame is a 2001 which per google looks to have mostly been bronze welded. The interesting part is that most of the welding appears to have "steel" filler. I agree that gas welding on 4130 is better since you don't need to stress relieve. We've built a few tube chassis and the stress relieving after TIGing takes forever; it seems like it would be quicker to have a good torch guy gas weld the whole thing and skip the relieving step. (IMG:style_emoticons/default/smile.gif) Is there a way to tell if something is TIG or gas welded Sorry for hijacking John... Well that depends on who welded it. Tig welds tend to be just slightly smoother than gas weld due to the rod flow in the flame verses the arch flow of the tig. But there are some very talented air frame guys out there. The filler rod your seeing may be silicon bronze. |
sixnotfour |
Nov 25 2013, 10:36 PM
914 Wizard Group: Members Posts: 10,525 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
There are lots of frame pulling systems capable of pulling a 914, The measurement system is the Labor intensive part of it.. Celette fixtures have the benefit of being peg in hole, and bolt on and pull to fit.
ThePaintedMan |
Nov 26 2013, 08:43 AM
Wish you were closer. I'd pull it for you. You could always tow dolly it up here.... (IMG:style_emoticons/default/idea.gif) I'm going to rent the Celette fixtures sometime around the end of February I think for the 6. I think I am going to try to talk Scotty b into towing out his rear hit car. It could be an interesting week. (IMG:style_emoticons/default/idea.gif) Road trip!!! (IMG:style_emoticons/default/aktion035.gif) I'm always up for one (IMG:style_emoticons/default/smile.gif) |
rhodyguy |
Nov 26 2013, 09:02 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
that's what all the married guys used to say...
Lo-Fi Version | Time is now: 27th September 2024 - 08:04 AM |
