914 Cup Proposed Rules and Classes! now is the, time to make suggestions&modifications! |
Aaron Cox |
Jan 23 2005, 01:11 PM
im winning the improved class already! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Dave-O |
Jan 23 2005, 06:00 PM
Is winter done yet? Group: Members Posts: 511 Joined: 26-August 03 From: Minneapols, MN Member No.: 1,082 |
I will speak for the Minneapolis area AXers. I'm sure Dave will chime in if i miss judged his points, I think he's busy moving into a new house.
David Hildebrandt (Dave-O) Stock class (95 points) Dave Parsons (OttoX914) Improved (225 points) We will also have at least one more 914, i'll keep you posted. David |
T H O M A S |
Jan 23 2005, 06:13 PM
Senior Member Group: Members Posts: 626 Joined: 1-August 03 From: Donaueschingen, Germany Member No.: 974 Region Association: None |
lets goooooo
modified 360 points |
xsboost90 |
Jan 23 2005, 06:40 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
looks like im in at 115 -improved! w/ cam/springs/swaybar
Demick |
Jan 23 2005, 07:01 PM
I'm in.
225 pts Demick |
Joseph Mills |
Jan 23 2005, 07:38 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
Count me in on these shenanegans as well.
Put me in with Paul Heery. I'm about 80 points. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Oh, wait... no I guess I'm about 285. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Series9 |
Jan 23 2005, 08:00 PM
OK, I was only kidding about the 1000 points.
I just added it up and came up with 405. Might go up after some suspension improvements. |
J P Stein |
Jan 23 2005, 08:06 PM
The ulfer says: "Yum, yum, 10 cars in Modified. I need to feed"
(IMG:http://www.914world.com/bbs2/html/emoticons/chowtime.gif) |
Joseph Mills |
Jan 23 2005, 08:14 PM
Your table is waiting sir. Would you like a nice Chianti with your meal? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) What does lower than stock gearing mean? My fifth gear is "stock". It just spins where third use to. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Shall I penalize myself another 30 points? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
nebreitling |
Jan 23 2005, 08:20 PM
although i wasn't specifically thinking about that particular mod -- i do think that counts as lower-than-stock gearing. a lower third gear is a definite advantage at AX.
but i'd like to hear others' input. perhaps 20 points is too much penalty? [edit] ALSO, let's try not to get too attached to the current class distribution. i think there's a chance that we may raise the improved/modified boundary just a bit; or, as andrew suggested early on, that we may create a super-modified class. the purpose of either scenario would be to create as much fair competition as possible in each class. though it's perhaps ambitious, i don't think that it's unrealistic to have 40-50 competitors in this thing. such a number would sustain 4 classes. that said, JP -- you'll definitely be in the highest class. best bring your appetite, indeed. |
Joseph Mills |
Jan 23 2005, 08:30 PM
Actually, it's listed at 20 points. Still seems a lil' high to me. Honest fellers, thang just barely works half the time. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Joseph Mills |
Jan 23 2005, 08:37 PM
What exactly do your class points signify, other than your car classification? Are you car class points entered as an equasion factor against your AX points within your "class"? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
nebreitling |
Jan 23 2005, 08:39 PM
i think it should at least be a 15 point penalty. you're adding torque (albeit in one gear, in your particular case). displacement moves in steps of 15 points, so i can concede that same number to gearing. other? 15pts? 20pts? 0 pts?
dudn't matter if it werks or not.... (IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif) |
nebreitling |
Jan 23 2005, 08:47 PM
in reverse order:
No.
only the level of development of your car -- which in turn is used for classing (stock, improved, modified) AND POSSIBLY an additional PAX-index system, where each car would take a handicap based specifically on their car's points; as a more "pure" drivers' competition. so, if we run such an additional PAX index, it WOULD matter whether you are at 285 or 305 points -- regardless of the fact that either puts you in modified. does this make sense? |
Trekkor |
Jan 23 2005, 09:21 PM
Nice line up of drivers.
Why does the ULFster always have to be hungry, why? Great job to get this off the ground. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) 914 CUP is here! KT |
VegasRacer |
Jan 23 2005, 09:46 PM
ELVIRA Group: Benefactors Posts: 8,624 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
I think 6 events is a good number to work with. Without the 914 Cup I would have entered only a few auto-crosses this year. This competition will give me a reason to go out and play a little more.
On the Tire width points - Instead of a flat 30 points for over 205's, how about xx points for tire size 2xx? Example: If you are running 225's (on the back) you would add 25 points. If you have 245's you get 45 points. It wouldn't affect the scoring, but I would enjoy seeing what SCCA or PCA class everybody is running in. In the 914 Club auto-X at the WCC last year, TTOD was Bill (914 cats) in the race/modified class. I was 2nd place in that class. If I remember, the top 3 guys in the improved class were faster than me. I have since sold that race car. This year I have a different car. It will be fun to see how I end up finishing in this new format. I figure my total point are 205. That puts me in the Improved class. Wanna make a side bet Aaron? |
Joseph Mills |
Makes sense to me. Gentlemen....Start your Engines... Except for Otmar. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
nebreitling |
Jan 23 2005, 10:13 PM
Okay. Two issues we need feedback on. If no feedback then the 914cup committe will decide Issue #1 Tire Width: proposal: instead of a flat 30 point penalty for tire sizes, we pro-rate the penalty. (modified from suggested, i think we should leave the standard 205's unpenalized, then add 10 points per tire size). tirewidth (for 305 and less): (2xx – 205) = penalty points greater than 305 width = 100 penalty points. i.e. : 205 or less = +0 215 = +10 225 = +20 235 = +30 etc.... 305 or greater = +100 For those running slicks in non-standard tire size, convert sizes and place yourself. All Tire Width penalties are based on the widest tire run on car. In other words, a competitor with 225 rear's and 215 front's will add penalties based off the 225's, i.e. 20 points. personally, i'm in favor of this. Issue #2 non-stock gearing current penalty is 20 points. should this be adjusted to 15? to 30? to 0? personally, i'm in favor of a minimum of 15 points, preferably 20. |
GaroldShaffer |
Jan 23 2005, 10:27 PM
You bought another 914? Group: Benefactors Posts: 7,627 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
OK, so the euro P&C's doesn't change my displacement to more than 2.0L? If this is true then I would only be at 80 points not 95. I was thinking 50 for the falkens & 45 for the not stock 2.0L, but if the euro P&C doesn't matter then I am 80 points with the current rules.
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
I think 15 is fair. |
nebreitling |
Jan 23 2005, 10:36 PM
Garold: nope. displacement is still 2.0
you're at 80 -- now you've got headroom for a header! thanks for the input, keep it coming in, folks! n |
Lo-Fi Version | Time is now: 27th September 2024 - 05:25 AM |
