-6 #1050 chassis on ebay |
Socalandy |
Jul 30 2014, 11:36 AM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
FYI,
just the chassis and I added it to the database. http://www.ebay.com/itm/914-6-Race-Car-She...t_Street_Legal_ Attached thumbnail(s) |
walterolin |
Jul 30 2014, 12:38 PM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
I'm still waiting, Andy.
walterolin |
gms |
Jul 30 2014, 03:58 PM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
If you are looking for a race car this is great, if you want to make it a street car proceed with caution. It is illegal in my state to own a car with an altered VIN.
rgalla9146 |
Jul 30 2014, 07:18 PM
What's altered ?
Windshield tag, check Aluminum body plate, check Chassis number in trunk, check ( right series, ?) VIN stamp, top of right front wheel house, ? not legible. |
rick 918-S |
Jul 30 2014, 07:33 PM
Hey nice rack! -Celette Group: Members Posts: 20,419 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
What's altered ? Windshield tag, check Aluminum body plate, check Chassis number in trunk, check ( right series, ?) VIN stamp, top of right front wheel house, ? not legible. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/confused24.gif) |
rgalla9146 |
Jul 30 2014, 08:34 PM
........ unless
the chassis number is out of range and the stamped front fender # is not there. .......... both of the tags can be moved |
GaroldShaffer |
Jul 30 2014, 10:01 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
There is no vin stamp on the right front fender.
gms |
Jul 30 2014, 10:06 PM
What's altered ? Windshield tag, check Aluminum body plate, check Chassis number in trunk, check ( right series, ?) VIN stamp, top of right front wheel house, ? not legible. The VIN stamp was cut out and replaced with a piece of steel There is a 914/4 center vent on the dash and the Karman stamp is pretty far out of range. You can rivet the aluminum tags into a new chassis. |
Mike Bellis |
Jul 30 2014, 10:35 PM
It does look like a VIN swap to me too.
Insert George joke here... (IMG:style_emoticons/default/biggrin.gif) |
pete000 |
Jul 30 2014, 11:00 PM
Still has the 914-6 engine compartment fuel line clips intact ! (IMG:style_emoticons/default/laugh.gif)
Jul 31 2014, 11:53 AM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
It appears that the front clip was replaced with a factory replacement. The replacement panels didn't have the front holes punched out.
That might explain the lack of a VIN on the fender ... The rest of the chassis appears to be a real /6. (IMG:style_emoticons/default/popcorn[1].gif) |
gms |
Jul 31 2014, 12:42 PM
gms |
Jul 31 2014, 12:48 PM
dash has 914/4 center vent
Jul 31 2014, 01:28 PM
My point is, it looks as if the car had some major surgery and at least parts of the front replaced. The rear looks to be from an original /6.
It was not uncommon to splice two cars together after an accident back in the day. My guess would be that this car was turned into a race car after it was crashed and at least some parts of an early /4 front clip were crafted on. In which case they would have cut out the /4 VIN ... (IMG:style_emoticons/default/idea.gif) |
gms |
Jul 31 2014, 02:57 PM
My point is, it looks as if the car had some major surgery and at least parts of the front replaced. The rear looks to be from an original /6. It was not uncommon to splice two cars together after an accident back in the day. My guess would be that this car was turned into a race car after it was crashed and at least some parts of an early /4 front clip were crafted on. In which case they would have cut out the /4 VIN ... (IMG:style_emoticons/default/idea.gif) I agree, a clip was probably performed but the VIN cut is a major no-no in IL (and probably most states) that is why it is not sitting my garage right now. |
larryM |
Aug 1 2014, 11:06 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
about 15 yrs ago i looked at a "six" with a correct VIN in the Sac'to area - it had been in a flood - but my second inspection trip (with cash in hand) revealed it had later "4" dash vents, etc - and pulling up the carpets revealed that the front half of the car was a "4" sectioned onto the sixer back half
- it is not a "straight across cut", so you might not notice unless you really know these chassis' - a bodyman friend who'd worked at Gus Mozart Porsche confirmed that this was commonly done in the Bay Area "back in the day" - it's the same process routinely used to shorten a VW pan for a Manx body back-when I passed on it, even tho i only was looking for a racer shell (i've seen sketchier "original-6-GT" cars at some high-end vintage venues - some even still wear their "4" fender ID - obviously htis is not a concern in some circles) I have also seen a similar real six "tub" in Sac'to area that had the RF fender/quarter replaced - that "could" explain no-VIN or "erased VIN" in the fender liner I don't know where either of those shells went if all ya want is a race car - then it's worth considering if cheap enuf but if ya want a 100-point resto, 100K resale value - take your chances & buy a set of steel stamps and a good MIG . |
Lo-Fi Version | Time is now: 25th April 2024 - 01:44 AM |
