Truck lid and Targa top clearance |
914Next |
Oct 7 2014, 06:26 PM
Senior Member Group: Members Posts: 698 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
So.... after placing the targa top in the truck for the first time, I drove the car for 10-15 miles. When I later went to take the top back out I noticed the the trunk lid had actually rubbed on the top of the targa top. Is the clearance that tight? Could I have clamped it in incorrectly? Seemed fairly straightforward but was surprised that I had effectively zero clearance. Only minor rubbing damage but don't want to see that happen again. What did I do wrong?
GaroldShaffer |
Oct 7 2014, 06:32 PM
You bought another 914? Group: Benefactors Posts: 7,617 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
did you have the top in the trunk the right direction? Targa latches inside the cups, lip edge in the white holders and rear held down with the rubber holders?
anderssj |
Oct 7 2014, 07:00 PM
Dog is my copilot... Group: Members Posts: 1,641 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Unfortunately mine has done that for years. Rubbing is at rear edge of the top, right where the reinforcement for the trunk lid crosses. It happened even when the car was brand new. Still happens with all new clips/holders front and rear. I've started putting a piece of old sweatshirt material on the back edge of the top before closing the trunk . . . seems to help.
dlkawashima |
Oct 7 2014, 07:11 PM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
Could I have clamped it in incorrectly? I think you have to consider the fact that the car is new to you and the top hadn't shown any wear from rubbing on the trunk lid until now. That tells me most likely the problem was the way you clamped the roof into the trunk. First, as Garold noted, make sure you have oriented the roof in the same direction as it attaches to the car. When you close the lid, push down with a gentle amount of force. If the trunk doesn't latch immediately, stop and readjust the roof. Remember that the roof can adjust both fore and aft and side to side. My car is really picky about getting the side to side alignment just right ... if I'm off by just a little bit the trunk won't close without an excessive amount of force. |
abnrdo |
Oct 7 2014, 08:16 PM
Member Group: Members Posts: 399 Joined: 24-September 04 From: Panama City, FL Member No.: 2,820 Region Association: South East States |
Mine has a rub mark from where someone had either sat on the back trunk, or completed numerous dukes of hazard slides. Which in turn knocked the trunks support beams lower to rub the top while in the trunk.
Olympic 914 |
Oct 8 2014, 07:39 AM
Group: Members Posts: 1,658 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Unfortunately mine has done that for years. Rubbing is at rear edge of the top, right where the reinforcement for the trunk lid crosses. It happened even when the car was brand new. Still happens with all new clips/holders front and rear. I've started putting a piece of old sweatshirt material on the back edge of the top before closing the trunk . . . seems to help. +1 I just put a couple layers of duct tape on the inside trunk lid to cushion it. ( back in the 80's when it ran) |
tumamilhem |
Oct 8 2014, 07:47 AM
LUFTBRIGADE Group: Members Posts: 1,228 Joined: 29-October 12 From: Jacksonville, FL Member No.: 15,092 Region Association: South East States |
This should not happen even when new. Your latches may be in the cups but they may not be ALL the way in. They are kind of clumsy to get in and if not in all the way, the targa top sits too high.
On the back end, the top fits into the rubber roof brackets. Once inserted, the rubber surrounds the edge and goes over the top of the roof, preventing the roof from coming into contact with the rear bonnet lid. It also sets the roof in place low enough to not touch the lid. My guess is there's something wrong with your installation, that it's not secured properly. |
JmuRiz |
Oct 8 2014, 07:49 AM
914 Guru Group: Members Posts: 5,414 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Mine does that too, started happening after replacing the side targa seals. Stiffer/taller seals made it raise enough to rub.
DRPHIL914 |
Oct 8 2014, 08:12 AM
Dr. Phil Group: Members Posts: 5,753 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I just bought a large thick bath towel at TJMAXX on sale to lay across the top for protection. i agreee about the tnew seals, once i put on new seals it seems to stick up just a bit more
GeorgeRud |
Oct 8 2014, 12:16 PM
Also check the rubber snubbers that hold the rear edge of the top, they are different left to right. The side seals and rear seals on the top shouldn't really be an issue as the clamps all attach to the fiberglass part of the top.
GeorgeRud |
914Next |
Oct 8 2014, 03:09 PM
Thanks for the input. short term I'll jus go the route us using a thin towel between them. Longer term will check to see what is really going on. Original seals are on the top so it can't be new seals.
Oct 8 2014, 08:39 PM
Custom Member Group: Members Posts: 24,501 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Thanks for the input. short term I'll jus go the route us using a thin towel between them. Longer term will check to see what is really going on. Original seals are on the top so it can't be new seals. It does not touch the trunk lid. Check out how you are putting it in the trunk....it can go in wrong and the lid will close.... |
bigkensteele |
Oct 8 2014, 09:18 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
No matter how much I fuss with the positioning of my top, there is always interference with the lid. I have replaced the rear latches and they are correctly oriented. It just is what it is.
Olympic 914 |
Oct 10 2014, 07:38 AM
Also check the rubber snubbers that hold the rear edge of the top, they are different left to right. The side seals and rear seals on the top shouldn't really be an issue as the clamps all attach to the fiberglass part of the top. That's a new one for me, didn't know they were different. could have been the prob. |
Kansas 914 |
Oct 10 2014, 12:38 PM
Also check the rubber snubbers that hold the rear edge of the top, they are different left to right. The side seals and rear seals on the top shouldn't really be an issue as the clamps all attach to the fiberglass part of the top. That's a new one for me, didn't know they were different. could have been the prob. They have a small "R" and "L" embossed on them. I think even the reproduction ones have the markings. |
karmann |
Oct 11 2014, 09:21 AM
Newbie Group: Members Posts: 31 Joined: 9-August 13 From: Cheshire UK Member No.: 16,227 Region Association: None |
I'm also having the same issue. I've checked the orientation of both the tier catches at the bac of the car as they are on the correct way and the bolts are at the bottom of the slotted holes. I've fiddled for ages trying to get it to not be in contact with lid, it's driving me mad!
shane |
Oct 11 2014, 09:47 AM
Member Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
Where can you get the plastic clips and rubber snubbers that hold the top in the trunk.
Cuda911 |
Oct 11 2014, 12:12 PM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
^^^^ 914rubber.com sells the rear rubber holders. I think Pelican has the front plastic ones.
My trunk lid does not rub at all on the roof. Like stated above, be sure the clips are in the cups and aren't lifting the roof up a bit too high. Funny, sometimes the roof just pops perfectly in place in the trunk, and sometimes it's like assembling a freekin' Chinese puzzle to get it to fit correctly. |
karmann |
Oct 11 2014, 04:09 PM
Well after careful inspection earlier on today I've come to the conclusion that the rear trunk is contacting the black rubber roof holders, obviously once the roof is in the slots of the holders then this opens them up, and I think that the tab on the top is just a little to high. What does anyone else think?
Lo-Fi Version | Time is now: 29th March 2024 - 12:06 AM |
