Welding longs with engine in?, Beginning a resto... |
mbseto |
Oct 15 2014, 09:05 AM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Howdy all;
About to start a restoration, hoping to do a rolling resto. After looking over some of the threads on prep for repairing longs, I see two things everyone advises: 1) brace the doors 2) get the car off the wheels, i.e. jackstands under the donuts It looks like the engine is nearly always pulled... Is this a must, or can the longs be repaired with the engine in? If so, is additional support under the engine/trans needed? Thanks for the input, M. |
rjames |
Oct 15 2014, 09:46 AM
I'm made of metal Group: Members Posts: 3,876 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Howdy all; About to start a restoration, hoping to do a rolling resto. After looking over some of the threads on prep for repairing longs, I see two things everyone advises: 1) brace the doors 2) get the car off the wheels, i.e. jackstands under the donuts It looks like the engine is nearly always pulled... Is this a must, or can the longs be repaired with the engine in? If so, is additional support under the engine/trans needed? Thanks for the input, M. Depends on how far back your repairs are going. Unless your repairs extend into the engine bay you won't need need to remove the engine. Apply the bracing as planned so that your gaps don't change. You also don't need to support the engine or tranny. They should already be supported by the engine mount/crossbar and the tranny mounts at the rear. Raising the car off the ground won't change that. Remember to disconnect the battery. Good luck and let's see some pictures of what you'll be fixing! |
CptTripps |
Oct 15 2014, 11:07 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
I always thought it was good to do it with the engine in place. If the car is on stands, there's a little more weight in the back to keep things stretched out before you weld it.
I could be wrong though. That's just my "2-bit garage engineer" opinion. |
Johny Blackstain |
Oct 15 2014, 11:45 AM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
I would think it all depends on the amount of rust damage there is. If the hell hole is more like a canyon & the right trailing arm mount is damaged as well, it would probably be easier to repair these areas without the engine in the way.
Oct 15 2014, 11:52 AM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I'm no expert but have never seen a car that needed long repairs but had a good hell hole. Maybe your lucky but make sure you dig deep into the passenger side of the engine compartment and the passenger suspension console. Good luck!
scotty b |
Oct 15 2014, 12:13 PM
98% of the time if the long is bad the hell hole is bad. 95% of the time the hell hole and long are bad, the suspensions console and engine mount are bad, you just don't realize it until you get all the paint and undercoating off. 99% of the time the hell hole and longs are bad, the rear floor and rear firewall are bad.
what I'm saying is drop the drivetrain Jack stands under the donuts is o.k., but not ideal. The whole length of the car really needs to be supported. Use the jackstands, but run a 4x4 from front to back to support the floor pan. This also will help things to settle back to a neutral position if the gaps are off. If I get some time later tonight I'll dig up a couple threads that will scare you straight (IMG:style_emoticons/default/happy11.gif) It is VERY easy to completely fubar one of these cars if things are not properly braced, and the parts are not replaced correctly. If the inner and outer wheel wells are bad you REALLY need to do some serious bracing to the rear ( trunk ) of the car. I'm going to be working on Mepsteins car in the next month and will be making a frame work for that rear area. I'll post pics when it is in place |
mbseto |
Oct 15 2014, 12:16 PM
I'm no expert but have never seen a car that needed long repairs but had a good hell hole. I hear you, that's what I see in all the build threads I've looked at. The car I have seems to have a decent hell hole. From what the PO told me, it was in pretty good shape but sat in a barn while he worked on other cars. It looks like it rusted from the bottom up, I assume from sitting over damp ground. In any case, I'll dig around a little more thoroughly to make sure. Just finished cleaning out the tar, going to clean away the undercoating to see what I'm dealing with. |
CptTripps |
Oct 15 2014, 12:52 PM
Looks like you may benefit from doing your floor pans too. If it was over damp ground that rotted up through the edges, you may end up going all the way around anyways. You can repair the bottom 3" of the inner longs, but you'll need good metal to weld TO. I did the floors and it really wasn't a hard job at all. Just make sure you have everything level before you go hacking away and welding it back together.
I did my pans, and repaired the longs of my last build with the engine in the car. |
stugray |
Oct 15 2014, 12:55 PM
If you havent had the engine out, then you didnt look hard enough for rust.
Just my $.02 And if you are doing a "resto" then step #1 should be: drop engine and trans. |
rjames |
Oct 15 2014, 12:58 PM
My car had minimal rust in the longs that needed taking care of but fortunately the hell hole was completely solid, so it's possible you've got nothing else that needs attention.
However, given the damage shown in the pictures I'd go through the entire car really well. I especially recommend checking the rear suspension mounts that usually have plugged up drain holes. You don't want this to happen to you: |
BeatNavy |
Oct 15 2014, 01:33 PM
Certified Professional Scapegoat Group: Members Posts: 2,922 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
The whole length of the car really needs to be supported. Use the jackstands, but run a 4x4 from front to back to support the floor pan. This also will help things to settle back to a neutral position if the gaps are off. I'm getting ready to attempt something similar. Scotty, is there any particular place you recommend putting the 4x4? I see in threads like Michelko's that he is using a board, but I can't really tell where exactly he's running it. I guess just off the long under the floor pan? Also, is it necessary to support the suspension console with 4x4 in a manner similar to the way he did? If I'm hijacking the thread I apologize mbseto. |
scotty b |
Oct 15 2014, 04:07 PM
The whole length of the car really needs to be supported. Use the jackstands, but run a 4x4 from front to back to support the floor pan. This also will help things to settle back to a neutral position if the gaps are off. I'm getting ready to attempt something similar. Scotty, is there any particular place you recommend putting the 4x4? I see in threads like Michelko's that he is using a board, but I can't really tell where exactly he's running it. I guess just off the long under the floor pan? Also, is it necessary to support the suspension console with 4x4 in a manner similar to the way he did? If I'm hijacking the thread I apologize mbseto. If you're only doing the outer long, then put the 4x4 down the inside of the pinch weld that joins the inner and outer long. If you have to do the inner and outer like it appears the OP is probably going to have to do, well.....that's a whole other bag o' worms (IMG:style_emoticons/default/unsure.gif) |
Oct 15 2014, 04:22 PM
Custom Member Group: Members Posts: 24,501 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
If you have not taken the motor out, it's time to learn.
The first time will take a bit of time. I am down to about 45 minutes at a slow pace with coffee breaks. might as well buckle down and learn how to do it....it makes all sorts of stuff easier to do. |
Porschef |
Oct 15 2014, 05:35 PM
How you doin' Group: Members Posts: 2,162 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Rich is 100% correct, the idea of dropping the engine is the most difficult part of it to overcome. Read up, there's plenty of tutorials, and while the engine's out, you can address the no doubt myriad of oil leaks... (IMG:style_emoticons/default/rolleyes.gif)
injunmort |
Oct 15 2014, 06:11 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
I set mine on3x3 sq.tubing from firewall to firewall just inside of the donuts. it measured out correctly, put in door braces and repaired. measured again as the long and console are repaired, all is good with good door gaps. I chose this way because my first 914 had rotted so much it sagged to the point of the doors not opening, put it into this configuration and it measured out perfectly with good door gaps. guessing from your pictures your hell hole/long are toast and you will need to drop engine/trans to repair.
rick 918-S |
Oct 15 2014, 07:52 PM
Hey nice rack! -Celette Group: Members Posts: 20,356 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Believe me, pulling the engine is going to be the easiest part. (IMG:style_emoticons/default/shades.gif)
Tbrown4x4 |
Oct 16 2014, 06:47 AM
Senior Member Group: Members Posts: 699 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Believe me, pulling the engine is going to be the easiest part. (IMG:style_emoticons/default/shades.gif) Wise words^^^^^ |
stugray |
Oct 16 2014, 07:58 AM
A perfect example is that picture posted by rjames above.
That was my car. You almost could not have seen that break with the engine in the car. The PO had no idea it was there.... |
mbseto |
Oct 18 2014, 01:47 PM
scotty b |
Oct 19 2014, 10:28 AM
Lo-Fi Version | Time is now: 29th March 2024 - 09:39 AM |
