GB - Clutch cable end the cable goes through, 2 correct size nuts, pulley, pulley bushing, and cable cover bellows., $22 for all I will have clutch cables available at $18 each as an option |
Mikey914 |
Oct 21 2014, 11:22 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So, I have made the end that the cable goes through as that's been running about $13 as I lost one of mine and had to replace it, so thought these were quite overpriced.
I decided to include 2 nuts as these are hard to find and using one with nylon will eventually give out over time. This happened to me at WCR 2012, and was a pain to deal with on the drive as a few of you may remember. If you tighten the 2 against each other you can get them to stay. Also made the pulley and the NLA bushing as these tend to both wear over time. I made the replacement out of delrin and it is sturdier than the OEM eliminating any flex of the pulley. The cable bellows is new also Option for the cable is $18 if you want to add it. I'm bringing in cables, and will have them in a few days, the other parts are made and on the shelf Really a great deal fro many hard to find and overpriced parts. Bump the thread and I'll put you down for a set. let me know if you want a cable. I will have 2 other GB's opening up soon and and you will be able to combine, one is for some interior parts that haven't been available in many years, the other is something we all can use, and is in the same area. So, who's interested ? Attached thumbnail(s) Attached image(s) |
Mblizzard |
Oct 22 2014, 04:36 AM
Even if yours is in good shape this is something to have on the shelf just in case.
I an in! |
Oct 22 2014, 05:17 AM
914-6 GT in waiting Group: Members Posts: 19,234 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Yes
SA-914 |
Oct 22 2014, 05:42 AM
Member Group: Members Posts: 125 Joined: 30-June 14 From: San Antonio,tx Member No.: 17,566 Region Association: Southwest Region |
I'm in with cable.
BeatNavy |
Oct 22 2014, 05:59 AM
This is good timing for me. I am in for probably two, sir.
cn2800 |
Oct 22 2014, 06:23 AM
Member Group: Members Posts: 119 Joined: 11-August 14 From: Amarillo, Texas Member No.: 17,766 Region Association: None |
I'm in for two sets of everything, including cable.
rmital |
Oct 22 2014, 06:30 AM
Northeast optimist Group: Members Posts: 1,946 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
I'm in for one set including cable. (IMG:style_emoticons/default/flag.gif)
no1uno |
Oct 22 2014, 06:48 AM
Member Group: Members Posts: 206 Joined: 2-December 10 From: Melbourne, FL Member No.: 12,448 Region Association: South East States |
I'm in for 1 set
Tbrown4x4 |
Oct 22 2014, 06:52 AM
Senior Member Group: Members Posts: 699 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
I'm in. One set with cable. Thanks
jim_hoyland |
Oct 22 2014, 07:10 AM
Get that VIN ? Group: Members Posts: 9,258 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Great ! This is a smok'en deal...put me in.
Attached thumbnail(s) |
Highland |
Oct 22 2014, 07:11 AM
Senior Member Group: Members Posts: 511 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I'm in.
pilothyer |
Oct 22 2014, 07:20 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I'm in for 2 (no cables)
sb914 |
Oct 22 2014, 07:24 AM
Surf Guru Group: Members Posts: 4,296 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
I'm in as well, with cable
michael7810 |
Oct 22 2014, 08:04 AM
Senior Member Group: Members Posts: 1,078 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
I'm in with a cable
craig downs |
Oct 22 2014, 08:15 AM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
I would like one including the cable
andrew15 |
Oct 22 2014, 08:27 AM
Newbie Group: Members Posts: 40 Joined: 10-April 10 From: Thunder Bay, ON Member No.: 11,594 Region Association: None |
In for 2 sets
rmdinmd |
Oct 22 2014, 08:40 AM
Member Group: Members Posts: 488 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States |
am in for one.
'73-914kid |
Oct 22 2014, 08:41 AM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
2 sets without a cable please
02loftsmoor |
Oct 22 2014, 09:18 AM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
So, I have made the end that the cable goes through as that's been running about $13 as I lost one of mine and had to replace it, so thought these were quite overpriced. I decided to include 2 nuts as these are hard to find and using one with nylon will eventually give out over time. This happened to me at WCR 2012, and was a pain to deal with on the drive as a few of you may remember. If you tighten the 2 against each other you can get them to stay. Also made the pulley and the NLA bushing as these tend to both wear over time. I made the replacement out of delrin and it is sturdier than the OEM eliminating any flex of the pulley. The cable bellows is new also Option for the cable is $18 if you want to add it. I'm bringing in cables, and will have them in a few days, the other parts are made and on the shelf Really a great deal fro many hard to find and overpriced parts Bump the thread and I'll put you down for a set. let me know if you want a cable. I will have 2 other GB's opening up soon and and you will be able to combine, one is for some interior parts that haven't been available in many years, the other is something we all can use, and is in the same area. So, who's interested ? put me down for the small parts,,, NO cable please Wes |
barebrad |
Oct 22 2014, 09:36 AM
Member Group: Members Posts: 54 Joined: 13-September 13 From: Huntsville, Al Member No.: 16,382 Region Association: South East States |
+2 for me. Cables with both.
Lo-Fi Version | Time is now: 23rd April 2024 - 07:03 PM |
