Intercoolers?, Where are you turbo dudes putting one? |
zach914v8 |
Nov 19 2014, 09:16 PM
Member Group: Members Posts: 216 Joined: 26-November 10 From: Houston Member No.: 12,426 Region Association: Southwest Region |
I'm in the beginning steps of redoing my car. I have a boxster 6 speed and adapter plate(s)and flywheel and flex plate.. I was considering a built ls1, but now I'm leaning towards a turbo 4.8.
I know that there are probably not a lot of turbo 914's out there, but the ones that are, where did those guys mount their intercoolers? I don't really want to do the water to air thing. If I decide to do twins, I thought about scoops on the quarter panels, and one small intercooler on each side. Or If I do a single turbo, 1 large intercooler in the rear trunk with a hole cut into the lid, then another hole out of the rear of the car between the tail lights. But I'm looking for ideas/ inspiration. |
Mike Bellis |
Nov 19 2014, 10:36 PM
zach914v8 |
Nov 20 2014, 08:15 AM
d914 |
Nov 20 2014, 11:32 AM
Air to water intercooler w a second rad up front. Constant flow bosh pump, 3/4 in hose. |
McMark |
Nov 20 2014, 12:45 PM
My current intercooler is in the engine bay. Which means it has to be small and its not getting cold air. My next intercooler will be water to air. It's the only setup that makes sense to me.
zach914v8 |
Nov 20 2014, 01:10 PM
My current intercooler is in the engine bay. Which means it has to be small and its not getting cold air. My next intercooler will be water to air. It's the only setup that makes sense to me. I like water to air intercoolers, but my issues is strange. This car had a serious electrolysis problem. I just don't want to get a water to air cooler and have it leak and destroy my engine. Solved the electrolysis problem but it still worries me. |
zach914v8 |
Nov 20 2014, 01:18 PM
I guess being that it is separate from the cars cooling system probably would make it a none issue, but still a scary thought.
nein14 |
Nov 20 2014, 03:08 PM
Senior Member Group: Members Posts: 838 Joined: 6-February 03 From: USA Member No.: 262 |
here is mine
Attached thumbnail(s) |
McMark |
Nov 20 2014, 03:24 PM
iamchappy |
Nov 20 2014, 03:55 PM
Here's how i did mine... not seen are three 5" pusher fans under the 7" pull fans
Attached thumbnail(s) Attached image(s) |
Mike Bellis |
Nov 20 2014, 07:56 PM
McMark |
Nov 20 2014, 08:30 PM
My water to air system is a closed loop with pump and heat exchanger. It does not connect in any way to the engine cooling system. Yes. Separate systems for optimum performance. (IMG:style_emoticons/default/aktion035.gif) |
DBCooper |
Nov 21 2014, 08:55 AM
Wow, lots of cool stuff. Here's the original location of my air-air intercooler, neat and clean.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1416581754.1.jpg) Not enough air flow there so changed to water-air. Here's the engine side: (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1416581754.2.jpg) And up in front of the radiator: (IMG:http://www.914world.com/bbs2/uploads_offsite/i255.photobucket.com-2618-1416581754.3.jpg) Also using the always-on Bosch pump and 3/4" heater hose underneath to the front. Works just like it should. |
Maltese Falcon |
Nov 21 2014, 11:51 AM
Advanced Member Group: Members Posts: 4,629 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
...With the trunk closed + the engine lid off
Marty |
Andyrew |
Nov 21 2014, 11:56 AM
Your going to need a decent sized IC. The only way to do that is either run air/water or mount it like Marty's.
zach914v8 |
Nov 21 2014, 11:57 AM
iamchappy |
Nov 22 2014, 02:56 PM
My 1080 CFM intercooler works just fine.
Mike Bellis |
Nov 22 2014, 06:16 PM
Maltese Falcon |
Nov 22 2014, 08:06 PM
My 1080 CFM intercooler works just fine. What are your intake temps at the throttle body? Mike, speaking for the MSDS car; intake temps measured at the TB usually 10° to 15° warmer than ambient outside temp. In my water/meth injection days when the liquid tank ran out, I could see 250° at the TB (IMG:style_emoticons/default/sad.gif) Marty |
iamchappy |
Nov 22 2014, 09:34 PM
My 1080 CFM intercooler works just fine. What are your intake temps at the throttle body? Dont know other than they are much cooler (warm) after ic than (hot) before ic My fans pull air through it really good, and the air scoop in the spoiler helps get the outside air to it. |
Lo-Fi Version | Time is now: 19th April 2024 - 11:08 PM |
