I need some testing help, Free Parts! |
McMark |
Nov 25 2014, 07:32 PM
914 Freak! Group: Retired Admin Posts: 20,177 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
While playing with my MicroSquirt kits I found that the stock CHT has a quite frequent failure rate. I used a stock unit on the motor I installed and on my trip to Portland I realized it was giving lots of erroneous readings. When I got back I installed another one, and it was fine for awhile, but eventually started giving the same erroneous readings. I found a modern electronic component which replicates the stock resistance/temp curve of the CHT sensor and isn't prone to vibration/heat damage like the stock unit (including new replacements). I would like to find someone who drives their car enough to notice if there is a difference.
Who's got stock D-Jet installed on their system, drives somewhat regularly and is willing to do some testing? (IMG:style_emoticons/default/beerchug.gif) |
rick 918-S |
Nov 25 2014, 07:37 PM
Hey nice rack! -Celette Group: Members Posts: 20,354 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
(IMG:style_emoticons/default/dry.gif) Not in the snow (IMG:style_emoticons/default/dry.gif) But Cool! (IMG:style_emoticons/default/smile.gif)
914_teener |
Nov 25 2014, 07:40 PM
914 Guru Group: Members Posts: 5,193 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I.ll help.
ConeDodger |
Nov 25 2014, 07:48 PM
Apex killer! Group: Members Posts: 23,543 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
For once, this isn't me... (IMG:style_emoticons/default/biggrin.gif)
BeatNavy |
Nov 25 2014, 07:57 PM
Certified Professional Scapegoat Group: Members Posts: 2,920 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
I may be able to help. 72, 1.7L with stock D-Jet. I just installed the MPS repair/tuning kit and haven't had a chance to "dial it in," but it's still running ok and I could do some before/after stuff. My CHT was replaced about a year ago and I put one of Brad's spacers on it earlier this year.
What are we trying to fix? CHT behavior or just find a better replacement? |
McMark |
eyesright |
Nov 25 2014, 08:00 PM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
Me?
I have a '76 2.0L (weren't they all that year?) DJet that is a DD. Has nearly 30K on my rebuild. Send me a PM |
hot_shoe914 |
Nov 25 2014, 09:54 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
TheCabinetmaker |
Nov 26 2014, 05:27 AM
I drive my car everyday Group: Members Posts: 8,299 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I run djet and at the present time is my only transportation, so it gets driven everyday. I too have noticed a large failure rate of chts in the last few years. Would love to see an alternative. Be more the glad to help out with this
ClayPerrine |
Nov 26 2014, 05:53 AM
Life's been good to me so far..... Group: Admin Posts: 15,367 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If you are willing to use an L-Jet system, I can put one on Betty's car. It definitely gets driven all the time.
McMark |
Nov 26 2014, 11:33 AM
Cool, four testers should be sufficient to know if it's a good upgrade. (IMG:style_emoticons/default/boldblue.gif)
Thanks guys! |
914werke |
Nov 26 2014, 11:57 AM
"I got blisters on me fingers" Group: Members Posts: 9,894 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Mark can you elaborate?
Were these variances something you noticed looking at a map or glitches in drivability that led you to the CHT & observe issues with their resistance/temp curve? |
MartyYeoman |
Nov 26 2014, 03:09 PM
Senior Member Group: Members Posts: 1,516 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Mark,
You can send one my way if you want one more data point. My car gets about 150 to 200 miles a week added on the odometer. Marty |
McMark |
Nov 26 2014, 03:51 PM
Mark can you elaborate? Were these variances something you noticed looking at a map or glitches in drivability that led you to the CHT & observe issues with their resistance/temp curve? Since I'm running MicroSquirt I can graph the readings. I was getting a bit of bucking, each time the reading jumped it would squirt a bunch of fuel. The first one stopped reading all together and just had high resistance, so the engine always thought it was cold. Thankfully I had my laptop with me so I just turned off the cold-start enrichment and ignored the sensor. The second failure was similar, but never got to the worst case scenario. It would buck occasionally - just a quick miss and then back to normal. |
Jake Raby |
Nov 26 2014, 06:00 PM
I've observed this with newer sensors as well.. The old ones seem to hold up much longer and to be much more stable.
Chris Pincetich |
Nov 27 2014, 10:22 PM
WHAT?!?!? You mean chasing the TPS and vacuum leaks isn't the only thing that might be causing my D-jet to experience the mysterious buck n hesitate during the normal driving commute? (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/biggrin.gif)
Very interested in seeing the outcome here. Been upgrading bits in the engine bay to help make my 914 a more reliable commuter (IMG:style_emoticons/default/beerchug.gif) |
Jake Raby |
Nov 27 2014, 11:24 PM
Something else I noted with the stock CHT is the resolution is very notchy.. It may be unresponsive for 20-40 degrees of engine temperature differential, then all of a sudden it'll change. This makes it very difficult to build a MAP of engine temp values in regard to enrichment.
Lo-Fi Version | Time is now: 28th March 2024 - 07:31 PM |
