Large cache of 914 parts Eastern Panhandle of WV, See inventory and prices within |
HalfMoon |
Dec 11 2014, 11:01 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Very large stash of Porsche 914 parts, some extremely rare (a few select 911 parts too)
See the entire inventory (images and prices) here (cut and paste to your browser): http://s32.photobucket.com/user/david16481...401894749848999 Located in Charles Town, WV (eastern panhandle) 25442 Don’t reply to this posting or PM me as this is for a friend of mine. I rarely use 914World anymore. Contact Greg at greg_cobb@comcast.net 914 Calipers=$75 a pair 911 Calipers=$125 pair Accusump=$200 Front turn lens (euro?)= $40 pair Axles/CV’s/Stubs=$125 each Interior back panel (with light) =$100 Battery tray (new) =$40 Bilstien yellow=$125 pair Front hoods=$175 each Porsche 914 Bra=$75 New (German) rotors front and rear=$50 each Cam=$50 A-Arms w/cross member=$200 A-Arms=$85 Each CV’s=$45 each Dash cover=$75 Engine lid w/rain tray=$125 Deep sumps=$50 each Ignition rotor (new) =$30 Fog relay=$20 Square relay=$10 Ignition condensers=$18 each Two GA 2.0 block w/cranks=$750 each Various fan shrouds=$40 each Fiberglass GT style fender flares=$150 a pair Fuel pump=$50 GC 2.0 bare block (repairable crank journal damage, new studs) =$100 Headlight motors=$50 each Rare headlight washer motor=$75 Heat exchangers (lightly used) =$200 set Type IV heads=$200 set Four 2.0 jugs=$125 full set Koni yellow or koni red=$125 a set License plate/trunk light=$30 Oil cooler=$35 Oil cooler with breather tank=$75 Rain tray=$50 Rear lenses=$75 each Finned alum cylinder covers=$75 pair Seat mounts=$35 each Two solex carbs w/intakes=$500 Speaker cover=$75 Outer rocker (steel) =$125 Steering rack w/tie rods=$350 Transmission side shift console cover=$40 CV boots (new) =$5 each Steering boots (new) =$15 each Transmission linkage firewall boots (new) = $20 each OEM air filters (new) = $12 each OEM German oil filter=$15 Black powder coated engine tins=$400 set Trailing arms (with shafts) =$100 each Transmission cores=$300 each Tall intakes=$150 Approximately 11k in parts. Parts sold individually or the entire horde could be had for bids over 8k |
gms |
Dec 12 2014, 12:50 PM
Advanced Member Group: Members Posts: 2,692 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
I will take the rear Koni's with adjustment knob
HalfMoon |
Dec 14 2014, 11:52 PM
pneuhyde |
Dec 15 2014, 01:03 AM
Member Group: Members Posts: 94 Joined: 24-February 05 From: San Leandro, Ca. Member No.: 3,654 Region Association: Pacific Northwest |
Interested in the Heat Exchangers, What Engine size are they for? more pics?
HalfMoon |
Dec 15 2014, 07:09 PM
fs096b |
Dec 16 2014, 11:49 AM
bob Group: Members Posts: 8 Joined: 12-December 14 From: simi valley, ca. Member No.: 18,216 Region Association: Southern California |
Very large stash of Porsche 914 parts, some extremely rare (a few select 911 parts too) See the entire inventory (images and prices) here (cut and paste to your browser): http://s32.photobucket.com/user/david16481...401894749848999 Located in Charles Town, WV (eastern panhandle) 25442 Don’t reply to this posting or PM me as this is for a friend of mine. I rarely use 914World anymore. Contact Greg at greg_cobb@comcast.net 914 Calipers=$75 a pair 911 Calipers=$125 pair Accusump=$200 Front turn lens (euro?)= $40 pair Axles/CV’s/Stubs=$125 each Interior back panel (with light) =$100 Battery tray (new) =$40 Bilstien yellow=$125 pair Front hoods=$175 each Porsche 914 Bra=$75 New (German) rotors front and rear=$50 each Cam=$50 A-Arms w/cross member=$200 A-Arms=$85 Each CV’s=$45 each Dash cover=$75 Engine lid w/rain tray=$125 Deep sumps=$50 each Ignition rotor (new) =$30 Fog relay=$20 Square relay=$10 Ignition condensers=$18 each Two GA 2.0 block w/cranks=$750 each Various fan shrouds=$40 each Fiberglass GT style fender flares=$150 a pair Fuel pump=$50 GC 2.0 bare block (repairable crank journal damage, new studs) =$100 Headlight motors=$50 each Rare headlight washer motor=$75 Heat exchangers (lightly used) =$200 set Type IV heads=$200 set Four 2.0 jugs=$125 full set Koni yellow or koni red=$125 a set License plate/trunk light=$30 Oil cooler=$35 Oil cooler with breather tank=$75 Rain tray=$50 Rear lenses=$75 each Finned alum cylinder covers=$75 pair Seat mounts=$35 each Two solex carbs w/intakes=$500 Speaker cover=$75 Outer rocker (steel) =$125 Steering rack w/tie rods=$350 Transmission side shift console cover=$40 CV boots (new) =$5 each Steering boots (new) =$15 each Transmission linkage firewall boots (new) = $20 each OEM air filters (new) = $12 each OEM German oil filter=$15 Black powder coated engine tins=$400 set Trailing arms (with shafts) =$100 each Transmission cores=$300 each Tall intakes=$150 Approximately 11k in parts. Parts sold individually or the entire horde could be had for bids over 8k I need a pair of rear brake CALIPERS 8/72 TO 76 LATE, DO YOU HAVE ALSO METAL BUMPER STAIGHT, DO YOU HAVE ANY |
gms |
Dec 17 2014, 11:38 AM
I will take the rear Koni's with adjustment knob Read the post carefully. Contact the person indicated. I did not response (IMG:style_emoticons/default/confused24.gif) |
HalfMoon |
Jan 29 2015, 09:03 PM
Bump to refresh. Please keep in mind DO NOT CONTACT POSTER. Contact the person indicated in the original post. I've posted this on his behalf and will not respond to ANY inqueries or posts. D |
sixnotfour |
Feb 1 2015, 06:15 PM
914 Wizard Group: Members Posts: 10,392 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
he responded and ..what happened to the one Koni rear shock.???
HalfMoon |
Feb 20 2015, 11:51 PM
HalfMoon |
May 21 2015, 08:23 AM
Sigh. Before you hit reply or send a PM, please READ THE ORIGINAL POST CAREFULLY. You can do this, I know you can.... |
HalfMoon |
Jun 14 2015, 07:46 PM
Many of you have emailed the contact person Greg C in WV and found out that he was recently out of country. I heard from Greg today and he's back for a few weeks and ready to ship out a buncha parts to everyone who has made inquiries. He also wanted me to express his gratitude for ya'lls patience. Please remember to contact him directly at: greg_cobb@comcast.net and not the poster of this thread (a friend who is only facilitating Greg's liquidation of 914 parts). |
Lo-Fi Version | Time is now: 29th March 2024 - 05:46 AM |
