New item to work on. Guys with carbs what do you think?, phenolic spacers |
Mikey914 |
Dec 17 2014, 04:32 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Looking at making up some of these. These are intended to help insulate the carbs from the engine further at the carb base. Who's interested?
These were available at one time for $15 each. I should be able to do a set of 4 for $24, if i can get some quantity. Figured I'd see how much interest is out there. Attached image(s) |
GeorgeRud |
Dec 17 2014, 04:45 AM
I've always used insulating gaskets on my -6s, so I imagine they'd also help on the carbed -4s.
rhodyguy |
Dec 17 2014, 07:25 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
2:32am? When do you sleep? Looks like they will fit on any intake that accommodates IDF or DRLA carbs.
VaccaRabite |
Dec 17 2014, 07:36 AM
En Garde! Group: Admin Posts: 13,423 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
When I had carbs, I just used the standard FI phenolic spacer to get insulation from the heat of the heads.
Zach |
rhodyguy |
Dec 17 2014, 07:41 AM
Zack, the spacer would go in between the carb and the intake manifold. Further insurance against heat soak.
Mark Henry |
Dec 17 2014, 07:56 AM
I made my own for my six project. Hated machining the stuff, wear a mask.
(IMG:http://www.914world.com/bbs2/uploads/post-26-1392596789.jpg) |
flipb |
Dec 17 2014, 07:58 AM
Senior Member Group: Members Posts: 1,717 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
I've been having issues with heat transfer... I'd be in for a set!
ThePaintedMan |
Dec 17 2014, 08:17 AM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
That's a good idea Mark. Priced very reasonably as well. Could we also request gasket sets that go with these? Currently I order mine from CB Performance but it's an arm and a leg to ship from them for whatever reason.
To install the phenolic spacers, one would need 8 individual gaskets for a dual carb setup. |
clapeza |
Dec 17 2014, 08:38 AM
Member Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States |
Interested in a set!
Chester |
siverson |
Dec 17 2014, 09:08 AM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
I'm not familiar with this concept...
> I've been having issues with heat transfer... I'd be in for a set! How do you know if you are having issues? -Steve |
rhodyguy |
Dec 17 2014, 09:20 AM
if its hot outside or when the engine sits when hot you can experience heat soak to the fuel in the float chambers. can make for difficult starting until the cooler fuel is on board.
Mark Henry |
Dec 17 2014, 09:46 AM
I'm not familiar with this concept... > I've been having issues with heat transfer... I'd be in for a set! How do you know if you are having issues? -Steve They are stock on type 4 FI, a set comes in the gasket set, manifold to head. Heat soak leads to percolation, vapor lock, bad running issues. Are these for the carb to manifold? To install the phenolic spacers, one would need 8 individual gaskets for a dual carb setup. I would add the extra gaskets as well so peeps don't have to source them separately. |
Kansas 914 |
Dec 17 2014, 09:50 AM
I would be in for a set of 4.
Thanks Mark! |
rhodyguy |
Dec 17 2014, 09:54 AM
yes mark, in-between the carbs and the intake manifolds.
barefoot |
Dec 17 2014, 11:33 AM
Senior Member Group: Members Posts: 1,269 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I'm in for a set.
Barefoot |
Mikey914 |
Dec 17 2014, 11:38 AM
That's a good idea Mark. Priced very reasonably as well. Could we also request gasket sets that go with these? Currently I order mine from CB Performance but it's an arm and a leg to ship from them for whatever reason. To install the phenolic spacers, one would need 8 individual gaskets for a dual carb setup. Yes I could do them up easily, maybe $2 a pop depending on the material cost. |
kid914 |
Dec 17 2014, 11:49 AM
ALWAYS lead...NEVER follow!!!! Group: Members Posts: 2,534 Joined: 9-March 11 From: Canada Member No.: 12,811 Region Association: Canada |
In for a set (IMG:style_emoticons/default/bye1.gif)
Mr. Olympic Blue 2 You |
Dec 17 2014, 01:30 PM
Member Group: Members Posts: 134 Joined: 7-September 10 From: Puyallup, WA Member No.: 12,150 Region Association: Pacific Northwest |
I'm in for a set!
rgolia |
Dec 17 2014, 02:39 PM
GeoJoe Group: Members Posts: 704 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
I'm in for a set
JmuRiz |
Dec 17 2014, 03:27 PM
914 Guru Group: Members Posts: 5,422 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I'll need some for my /6 conversion...not sure where's the best place to get 'em though.
Lo-Fi Version | Time is now: 24th April 2024 - 11:10 AM |
