F/S 3 Hand throttles for carbs, $99 each + shipping |
Mikey914 |
Dec 17 2014, 04:57 AM
The rubber man Group: Members Posts: 12,625 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have a few extra hand throttle assemblies hanging out. Let me know if you want one.
daytona |
Dec 17 2014, 06:47 AM
daytona Group: Members Posts: 435 Joined: 13-April 14 From: Ormond Beach, Florida Member No.: 17,249 Region Association: South East States |
Hi,
Just curious; where do you mount the hand throttle? Center console? Bill. |
tornik550 |
Dec 17 2014, 06:55 AM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I am interested also however I have the same question as above. Where do you mount these?
SA-914 |
Dec 17 2014, 08:13 AM
Member Group: Members Posts: 125 Joined: 30-June 14 From: San Antonio,tx Member No.: 17,566 Region Association: Southwest Region |
I will take one.
bdstone914 |
Dec 17 2014, 09:28 AM
bdstone914 Group: Members Posts: 4,496 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I am interested also however I have the same question as above. Where do you mount these? Pretty sure they mount in the same place as the ones on the -6 which is in the slot in the front of the shifter. My question is do you have to weld your own tab on the accelerator crank on the pedal set? |
johnhora |
Dec 17 2014, 09:43 AM
Senior Member Group: Members Posts: 864 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Mark...these are really nice....another great product....wish you had been making these way back when I had 4cyl carbed 914s.....my 914-6 comes stock with this feature and it is great for warm up....even used it for a fake cruse control once....
It goes in front of your shifter and pushes forward on the accelerator bracket in the tunnel. That is what that slit is for on the front side of the shifter floor support. If you have carbs you would love one....never knew what I was missing until I go the 914-6...start the car up set the lever and rest your right foot....no more continuous holding the throttle down... |
Mikey914 |
Dec 17 2014, 11:32 AM
I hope this helps cleat this up a little. The mount on the tunnel and have a plate that gets attached to the back of the accelerator portion of the pedal assembly.
Let me be perfectly clear - we do not recommend using this as a cruse control and only make the product to be used as a choke. The autocross guys set the height at about 2000 rpm so when they shift the motor will not wind down as much. This is a closed course application. 2 left Attached thumbnail(s) Attached image(s) |
forrestkhaag |
Dec 17 2014, 11:36 AM
I would like to purchase / can you send me an invoice to PayPal forrest@fkhmail.com to be sent to 92651? Thanks
forrestkhaag |
Dec 17 2014, 11:39 AM
Kansas 914 |
Dec 17 2014, 11:46 AM
PM sent - thanks Mark.
11tenths |
Dec 17 2014, 01:18 PM
Ve get too soon old, und too late schmart Group: Members Posts: 142 Joined: 11-October 12 From: Islip, Long Island, NY Member No.: 15,026 Region Association: North East States |
hblyle |
Dec 18 2014, 03:07 PM
Member Group: Members Posts: 64 Joined: 23-May 11 From: Huntington Beach Member No.: 13,110 Region Association: Southern California |
I'm in for one! My email is Tonelliracing@yahoo.com
era vulgaris |
Dec 18 2014, 07:18 PM
J is for Genius Group: Members Posts: 980 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
Is there a way to use one of these if you have a center console?
BuddyV |
Dec 19 2014, 12:28 AM
Robert Group: Members Posts: 552 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
PM sent - I will take one.
Cheers! |
FourteenFour |
Dec 19 2014, 04:20 PM
I'm new here ... Group: Members Posts: 0 Joined: 27-October 13 From: Toronto Member No.: 16,574 Region Association: Canada |
I'll check to see if there are any left in a PM.
Mikey914 |
Dec 20 2014, 12:13 AM
daviddisanto |
Dec 20 2014, 09:43 AM
Newbie Group: Members Posts: 2 Joined: 15-January 14 From: Phoenix, AZ Member No.: 16,889 Region Association: None |
rhodyguy |
Dec 20 2014, 02:51 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,042 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the technical drawing is very helpful.
morgan_harwell |
Jan 26 2015, 10:09 AM
Ha! Finally snuck up on a camera! Group: Members Posts: 126 Joined: 28-January 03 From: Santa Cruz Mtns., Ca. Member No.: 203 Region Association: Northern California |
Thanks Mikey!
I purchased one of these hand throttles last Summer and installed it in my 914-6conversion this past weekend. Install went smoothly. My 2.4L CIS engine is an early one out of a 1973.5 911T, which was not equipped with an Auxillary Air Regulator the later CIS injected 911s got. If I remember correctly, 1973 911s also came with hand throttles. To start the cold CIS engine now: depress throttle pedal slightly, pull back new hand throttle lever, release throttle pedal, turn ignition key and neet neet VROOOM!, and now the cold engine idles by itself without stalling (IMG:style_emoticons/default/smile.gif). I have since retired the very finely crafted wood block to the wood stove. The block that I used to place between the throttle & brake pedals after start up to hold the engine at high-idle, for the past 28 years. |
eyesright |
Jan 26 2015, 11:25 AM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
Mikey914
I bought mine last summer. I figure the installation will be an no brainer when I get to that point...but thanks for the picture and diagram. It WILL be a no brainer now. |
Lo-Fi Version | Time is now: 29th March 2024 - 03:36 AM |
