Rebuild sequence..., ..or what not do to when rebuilding your car |
falcor75 |
Jan 30 2015, 12:03 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I've had my car torn down for almost two years now and though I have alot of detail photos to get back too the hole sequence of doing things is a bit fuzzy to me.
Here's my thoughts on it but please add yours or correct me if I've missed something. From a bare shell I've chosen to go this way. (sortof) Tunnel fuel lines Tunnel brake lines Electrical harness Windshield wipers Fresh air box Front sway bar Front susension and steering (excluding the steering column) Rear suspension Complete the brake system Complete the fuel system (up thru engine shelf lines) Instrument panel (the steel part) Steering column Where would you go next? (IMG:style_emoticons/default/smile.gif) |
Socalandy |
Jan 30 2015, 12:37 AM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
I would put the suspension on first and make it a roller. then install the lines and harness. After that its up to you. I'd do the interior last.
Start a build thread if you haven't already so we can watch your progress (IMG:style_emoticons/default/popcorn[1].gif) |
falcor75 |
Jan 30 2015, 07:43 AM
Lo-Fi Version | Time is now: 17th April 2024 - 07:02 PM |
