New member with 1974 2.0, Making progress but still work to do |
marksteinhilber |
Feb 22 2015, 03:57 PM
Member Group: Members Posts: 229 Joined: 18-October 12 From: Foothill Ranch, CA 92610 Member No.: 15,057 Region Association: Southern California |
Have made some progress in the past few weeks. Lots of metal work and also got the chance to work on the motor. Ended up getting an engine shelf from RD in addition to the other parts. They make great products and are great to deal with. Some more carnage. My buddy said it's not as bad as it appears. I still almost started having buyer's remorse but felt OK once I saw the repairs in person. The inside of the longs were treated and then buttoned up. A little more grinding discovered this: Floors and jack points are in and inside of frame is treated. Next time I do this, I'm springing for a rotisserie... We replaced all the hoses, fuel lines and ignition parts (used Bosch or Bremi except for NGK plugs), along with injector seals, and intake gaskets and seals. Fuel lines and clamps came from Tangerine Racing, who I also highly recommend. Still need to install the stainless lines but motor refresh (except front and rear seals) is done. Removed the transaxle and found the flywheel had seen better days. Was able to get it resurfaced for $75. Hopefully it has another 40 years left haha. The clutch had plenty of meat left but my buddy suspected it was from the late 70s or early 80s because it had Audi markings on it. Regardless, I got a new kit from Sachs as wells as new flywheel bolts, clutch fork bushing, locking plate, felt washer, flywheel seal and pinion bearing. New front and rear seals and alternator belt will be going on soon. Also got the engine weatherstripping and other goodies from 914 rubber. Will install those when we reinstall the drivetrain. The guys from 914 rubber are great too. It's really nice to have so many good resources for these awesome cars. Should have some more updates soon. I know the structure is the priority right now but I'm still sending the steering wheel off to get recovered. Also splurged on one of those fancy stainless steel keychains. (IMG:style_emoticons/default/white914.jpg) You're making rapid progress with everything. Seems like your friend doing the welding is very good, he knows his steel surgery and how to put the metal back in the right spots. Seems like you could be driving in a couple days. Make sure to check all the shift bushings and ga et all the slop out, these cars are known for having vague shifting otherwise. This will make for a better driving enjoyment. Also, make sure you have good ground connection to engine and trans to avoid electrical mysteries. Lights may be dim, such as in guages, again, clean grounds to improve. N Joy! |
Cairo94507 |
Feb 23 2015, 07:37 AM
Michael Group: Members Posts: 10,022 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I am impressed that you tackled all of the rust issues immediately. The work looks very good and you are saving a terrific car. Nicely done.
Shadowfax |
Feb 23 2015, 09:22 AM
Show us the meaning of haste Group: Members Posts: 509 Joined: 19-January 15 Member No.: 18,340 Region Association: South East States |
You're making rapid progress with everything. Seems like your friend doing the welding is very good, he knows his steel surgery and how to put the metal back in the right spots. Seems like you could be driving in a couple days. Make sure to check all the shift bushings and ga et all the slop out, these cars are known for having vague shifting otherwise. This will make for a better driving enjoyment. Also, make sure you have good ground connection to engine and trans to avoid electrical mysteries. Lights may be dim, such as in guages, again, clean grounds to improve. N Joy! Thanks. I'd definitely be overwhelmed if I had to do all this by myself. I do have a shifter bushing kit and also the bronze pedal bushings but thanks for the suggestion. New ground strap too. It's the shiniest part of the tranny right now haha. I am impressed that you tackled all of the rust issues immediately. The work looks very good and you are saving a terrific car. Nicely done. Appreciate that. Still have some ways to go but will be worth the wait. |
Shadowfax |
Apr 1 2015, 05:08 PM
It's been a little more than a month since my last update and there's been some progress.
Most of the welding is done. The interior was cleaned and treated and is solid again. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1104.photobucket.com-18340-1427929694.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1104.photobucket.com-18340-1427929694.2.jpg) And the hell hole is a thing of the past... Before paint: (IMG:http://www.914world.com/bbs2/uploads_offsite/i1104.photobucket.com-18340-1427929694.3.jpg) After: (IMG:http://www.914world.com/bbs2/uploads_offsite/i1104.photobucket.com-18340-1427929694.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1104.photobucket.com-18340-1427929695.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1104.photobucket.com-18340-1427929695.6.jpg) New stainless lines are in. The old ones weren't too bad except the return line was clogged: (IMG:http://www.914world.com/bbs2/uploads_offsite/i1104.photobucket.com-18340-1427929695.7.jpg) Inspected the tank and it's solid but I took it to a local radiator shop to get cleaned. There was a lot of junk in the frunk. Was relieved to see only minor surface rust hiding underneath the tank. Treated that too. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1104.photobucket.com-18340-1427929695.8.jpg) Reinstalled the motor... (IMG:http://www.914world.com/bbs2/uploads_offsite/i1104.photobucket.com-18340-1427929695.9.jpg) And took care of a few odds and ends: shifter bushings, brake and pedal pads, had the steering wheel recovered, new horn return rubber deal, new driver's door brake, new trunk rollers from 914rubber, and some other minor items I'm forgetting. Had to order a new accelerator cable too. So waiting on that and the refurbished fuel tank before we can try to crank her up. I can't wait. Still to do (have parts, just need to do it) are reinstall the interior, replace the pedal bushings and install the turbo tie rod kit. Suspension is next and then maybe in a year or two I can redo the exterior. |
billh1963 |
Apr 1 2015, 06:53 PM
Car Hoarder! Group: Members Posts: 3,403 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
Slow down! You are putting us all to shame (IMG:style_emoticons/default/lol-2.gif)
Nice looking work...seriously! |
Phoenix914 |
Apr 2 2015, 06:00 AM
Member Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States |
Your car is looking really nice. That clean engine bay is an inspiration for me to get mine cleaned up. Great job to you and your mechanic.
DRPHIL914 |
Apr 2 2015, 09:58 AM
Dr. Phil Group: Members Posts: 5,808 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Slow down! You are putting us all to shame (IMG:style_emoticons/default/lol-2.gif) Nice looking work...seriously! (IMG:style_emoticons/default/agree.gif) really! but nice to see that in such a short time. usually we see this amount of work done over months or years not weeks!! - btw, who is doing most of the welding and metal work? really did a great job. my 75 has some of the same cancer in the rear longs and jack points and have not been able to find anyone locally and have to get those done. but watch out once the community gets wind of his ablilities he will get an onslaught of requests! enjoying the posts! keep up the good work |
PanelBilly |
Apr 2 2015, 10:53 AM
914 Guru Group: Members Posts: 5,840 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
While the tank is out, it a god time to pull out the fan unit and give it a service.
Shadowfax |
Apr 2 2015, 03:19 PM
Slow down! You are putting us all to shame (IMG:style_emoticons/default/lol-2.gif) Nice looking work...seriously! (IMG:style_emoticons/default/biggrin.gif) thanks. Am just really anxious to finish so I can drive it (IMG:style_emoticons/default/driving.gif) Your car is looking really nice. That clean engine bay is an inspiration for me to get mine cleaned up. Great job to you and your mechanic. Appreciate that. Hopefully I can keep it fairly clean. (IMG:style_emoticons/default/agree.gif) really! but nice to see that in such a short time. usually we see this amount of work done over months or years not weeks!! - btw, who is doing most of the welding and metal work? really did a great job. my 75 has some of the same cancer in the rear longs and jack points and have not been able to find anyone locally and have to get those done. but watch out once the community gets wind of his ablilities he will get an onslaught of requests! enjoying the posts! keep up the good work Thanks. He really has done a good job so far and has been very patient with me as I learn about these cars. I wish I had his welding skills (IMG:style_emoticons/default/welder.gif) While the tank is out, it a god time to pull out the fan unit and give it a service. Thanks. I'll make sure to pass this along. |
Shadowfax |
Apr 22 2015, 08:55 PM
Got the car back tonight. Was glad to drive it again. Runs great. Still needs some work (suspension is sketchy) but at least it's at my house again. Hope to have it street legal and road ready soon (IMG:style_emoticons/default/driving.gif)
Abridged to-do list: - Adjust shift linkage - Fix reverse lights (need to check the bulbs, but suspect switch is bad) - Suspension/steering (have turbo tie rod kit and rear shocks; need springs, front strut inserts and ball joints) - Reinstall interior (cleaned old carpet but plan on replacing it once the funds are replenished, have new carpet vinyl from 914rubber and sound deadener, also plan on replacing the dash top with the 914rubber group buy (IMG:style_emoticons/default/aktion035.gif) ) - Fix horn (recovered steering wheel is nice, but no horn is bad) - LED rear tail lights (on order from Spoke) - Fix rear glass and replace engine deck lid seal (have seal from 914rubber) - New outer rocker panels from RD |
Larmo63 |
Apr 22 2015, 09:39 PM
Advanced Member Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
You are a quick study! The way to learn about these cars is from the ground up and you are doing that. Nice saveā¦.
(IMG:style_emoticons/default/welcome.png) |
Shadowfax |
Feb 27 2016, 09:46 AM
It's been about 10 months since I updated this thread. Have gotten much done, especially in the past few months.
This car is a solid driver and is definitely a keeper. Now I'm looking for an '84-'89 Carrera to tinker with but man are they expensive. Anyway, here's the list of what me, my buddy or a shop (tires and alignment) have done since I bought the car last January. Oil and filter changes are not shown (three oil and filter changes last year). *Front wheel bearings *Bleeder valves and rubber caps, front and rear *Front and rear rotors *Brake pads, clips and inner adjustment covers, brake hoses *Bronze pedal bushings; cleaned and treated area underneath cluster and repainted the cluster *Turbo tie rod kit and alignment *Ball joints, pins/bolt, nut, washer *Clutch tube *Trigger points *Speedometer cable *Seat belt decals *914rubber: targa holders, screw caps (need to be installed) *Engine lid rubber *tranny seals, speedo drive o-ring and shaft seal, cv joint bolts *Radio *Fuel pump - aftermarket Bosch 69133 and new fuel filter *H6024 - headlights *Fixed fresh air and heater blowers *Set of 5 Fuchs alloys, caps and lug bolts *Shift knob group buy (not installed; kept original) *Headlight arm with clips (not installed) *Heater lever knob *Seat adjuster handle driver's side *2.0 TPS board *2.0 throttle body gasket *Transmission tail cone gasket *Front trunk drain tube *Sunvisors *Seat belt interlock relay - bypassed starter wires and removed relay *Fuel injectors *Clean AAV *Windshield wiper blades *Seat belts *Relay board *Ignition switch *Pedal board hardware *Door light switch rubber surround *Drivers side deflector/cooling flap *Flexible hose pcg261235a *Accelerator cable *Passenger fog light grill *Passenger turn signal lens *Rear glass - Napa 4196 Martin Senour butyl tape *Refinish flywheel *Flywheel seal, pilot bearing, felt washer, clutch fork pivot bearing, bolts and locking plate *Sachs clutch kit *Used outer rocker covers *Rocker panel rivets - didn't use *Fuel injection boots *Weatherstripping for engine bay *Spark plugs - NGK 7432 B6ES *Engine front and rear seals, gaskets *Injector seals and intake gaskets (manifold and plenum) *Dist cap, rotor, points, condenser, plug wires, dist seal, oil tower gasket *Breather and vacuum lines *Shift bushings *Used transaxle (original wouldn't shift into 4th or 5th) *Inspection plug cover *Fuel lines and hoses - Tangerine Racing *Expansion tank hose 3 mm *Expansion tank and sender gaskets *Gas cap gasket installed *Gas tank - acid etched and cleaned *Dash top - 914rubber group buy *Rear springs 100lb *Front strut inserts (Sachs) *Rear shocks (Sachs) *Targa top handle - front driver's side (used) *Drivers side door brake *Clutch and brake pedal pads *Heater hoses *Vinyl kit for floor *Sheetmetal from restoration design *More sheetmetal *Muffler *Reverse light switch and plunger *Pass side taillight lens *LEDs for parking lights and rear lights (front set ordered last week) *Side markers - used assemblies and new gaskets and clips *Trunk rollers *Shift knob crush sleeve *Fender to cowl seals *Door actuator cams *Fatmat *Tires *Seal along bottom edge of rear window and engine lid *Steering wheel - refinished at Custom Craft *Horn - 90134782301 spring return and 91161510901 relay; aftermarket horns *Horn spring plate, new contact ring and base plate *Battery mat Still to do: **Fuse box cover **Top seals, door seals, trunk seals **Jack tube covers **Odometer gear **Fix clock **Rear trunk lid :/ find good used or repair?? **Sail panel vinyl kit **Recover seats, center console and door panels; might as well do carpet too Eventually the car will be stripped and repainted but maybe next year. Here's how she sits now: |
Lo-Fi Version | Time is now: 27th September 2024 - 08:59 AM |
