Motor Mount bolt size/length?, (outer mounts for side shift trans motor bar) |
BuddyV |
Mar 29 2015, 12:51 PM
Robert Group: Members Posts: 552 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
I am installing a 2.0 with a side shift trans...... I need to buy the outer volts that attach the motor mount bar to the underside of the car. I have only had tail shift cars until now....
What size bolt (and length) do I use. I thought I had heard M10 x ? Also, just (2) washers and nylon lock nut for each side??? I peeked under the car at the mounting pint, and there seems to be a platform mounted in the circular opening..... does this platform restrict the use of a standard washer??? Thank you for your help..... hoping bolts/washers/nuts are easily found at my local hardware store...... but please let me know if there are any "special" parts that I should know about. Cheers! |
DavidSweden |
Mar 29 2015, 02:00 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am installing a 2.0 with a side shift trans...... I need to buy the outer volts that attach the motor mount bar to the underside of the car. I have only had tail shift cars until now.... What size bolt (and length) do I use. I thought I had heard M10 x ? Also, just (2) washers and nylon lock nut for each side??? I peeked under the car at the mounting pint, and there seems to be a platform mounted in the circular opening..... does this platform restrict the use of a standard washer??? Thank you for your help..... hoping bolts/washers/nuts are easily found at my local hardware store...... but please let me know if there are any "special" parts that I should know about. Cheers! M10x85. No problem with washer size (IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1427659247.1.png) |
BuddyV |
Mar 29 2015, 03:02 PM
cconcepcion |
Mar 29 2015, 04:11 PM
Member Group: Members Posts: 51 Joined: 5-January 06 From: Peoria,Az Member No.: 5,370 |
Hey buddy,
I have #'s 16, 15, 14, 18 and 19. They were removed from a late 914. Lemme know if you want 'em. They ship from Peoria, AZ Regards, Cesar |
TheCabinetmaker |
Mar 29 2015, 04:36 PM
Be sure to note on the breakdown that the bolt head is on the bottom. That's to keep from buggering up the threads when you run over something or meet an unfriendly speed bump.
BuddyV |
Mar 29 2015, 05:26 PM
Threads up - I agree.
Although I can understand why some install the other way..... seems easier when installing. Cheers, all. I am ready to install my motor! (IMG:style_emoticons/default/piratenanner.gif) |
Mar 29 2015, 06:56 PM
914 Idiot Group: Members Posts: 14,980 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Actually, the washers are not standard ones. They are not a complete circle on the outside, but have two flat edges so that they fit in the U channel piece. (See #22 in the diagram above.)
--DD |
BuddyV |
Mar 29 2015, 07:43 PM
Actually, the washers are not standard ones. They are not a complete circle on the outside, but have two flat edges so that they fit in the U channel piece. (See #22 in the diagram above.) --DD DAMN! I was wondering about the shape of that mounting plate! Where's the best place to buy two (2) washers (special)? |
bdstone914 |
Mar 29 2015, 08:22 PM
bdstone914 Group: Members Posts: 4,508 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Actually, the washers are not standard ones. They are not a complete circle on the outside, but have two flat edges so that they fit in the U channel piece. (See #22 in the diagram above.) --DD DAMN! I was wondering about the shape of that mounting plate! Where's the best place to buy two (2) washers (special)? Round ones will fit. Need thick grade 8.8. |
Mar 30 2015, 09:13 AM
Yeah, I think the ones with the flat sides are oversized. You can probably fake one up by taking a grinder to an oversized washer.
Part number is: 914.375.162.00 --DD |
7TPorsh |
Sep 11 2020, 09:49 AM
Reviving an old thread with a relevant question.
WHat is the pitch of the motor mount bolts? Specifically for a 1970. Supply house has 1.0, 1.25, and 1.5 |
Krieger |
Sep 11 2020, 02:04 PM
Advanced Member Group: Members Posts: 4,693 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
95% probability of 1.5. As long as it matches the nuts it doesn't make a difference
Lo-Fi Version | Time is now: 19th April 2024 - 07:53 PM |
