Wanted 914-6 Wiper Assembly & Motor |
racerbvd |
Apr 25 2015, 11:24 AM
Advanced Member Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
Turns out that my wiper motor & parts vanished, so, now I need a replacement, any help would be appreciated.
914-628-019-10-OEM is the part number for the motor, it the rest the same as a 4?? Either way, looks like I need a replacement (IMG:style_emoticons/default/mad.gif) TIA |
914Sixer |
Apr 25 2015, 03:43 PM
914 Guru Group: Members Posts: 8,863 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Byron,
The -6 wiper rack is completely different than the 914-4. Motor mounts 911 style, different angle than the 4. |
stevegm |
Apr 25 2015, 03:47 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
racerbvd |
Apr 25 2015, 07:26 PM
Byron, The -6 wiper rack is completely different than the 914-4. Motor mounts 911 style, different angle than the 4. That is what I was afraid of (IMG:style_emoticons/default/sad.gif) Will an early 911 one work, if I can't find the correct rack & motor? |
914Sixer |
Apr 25 2015, 10:12 PM
Yes, you can take a tubing cutter and shorten the 911 rack and install the -4 wiper arm assembly. Remove the strap and drill a hole for the post mount. You then have a -6 rack.
911 wiper motor will need a harness made up to plug into column harness. |
sixnotfour |
Apr 26 2015, 09:49 AM
914 Wizard Group: Members Posts: 10,406 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Yes, you can take a tubing cutter and shorten the 911 rack and install the -4 wiper arm assembly. Remove the strap and drill a hole for the post mount. You then have a -6 rack. 911 wiper motor will need a harness made up to plug into column harness. (IMG:style_emoticons/default/agree.gif) with pics here; http://www.914world.com/bbs2/index.php?showtopic=254282 |
boxstr |
Apr 26 2015, 05:46 PM
I found a wiper arm assembly, not sure if it's a 4 or 6
Including some pics. Craig at CAMP Attached thumbnail(s) |
type47fan |
Apr 26 2015, 10:10 PM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
boxstr |
Apr 26 2015, 10:39 PM
Okay, then it appears to me that it is for a 6.
Craig at CAMP |
racerbvd |
Apr 27 2015, 04:35 PM
Total shipped to 32073??
Thanks guys.. |
mharmon |
Apr 27 2015, 05:39 PM
Member Group: Members Posts: 129 Joined: 1-November 06 From: Los Angeles Member No.: 7,133 |
Yes, no question that is for a 6
racerbvd |
Apr 29 2015, 08:17 PM
racerbvd |
May 7 2015, 04:40 PM
Thanks Craig, it looks GREAT!!
Still need the wiper motor & arms. |
Lo-Fi Version | Time is now: 19th April 2024 - 03:42 PM |
