More Oil Temperature Questions, Hot Oil, Cool Head |
BeatNavy |
Jul 26 2015, 03:52 PM
2056 with D-jet. After reading some of the recent oil temperature threads I decided I should probably check how I'm running. Don't have gauge, but I had my dipstick thermometer that was still in my old 1.7L engine. After 20 minutes of spirited driving around the neighborhood in 88 degree weather I was a little distressed to see temps on that gauge running close to 240. Yikes! Maybe not an emergency, but not optimum either. So this weekend I:
-made sure I had right amount of oil (running Joe Gibbs 20W50 right now) -made sure all the engine tin/warm air guides and heater components are in place (I had removed some of this a month ago when fixing the heat exchangers) -checked and reset timing (was probably advanced a little too much), -temporarily disconnected the thermostat cable from the top so the flaps are, in theory, always in max cooling position. None of this seemed to help. Funny thing is my head temps are normally cool. Driving around town (lots of costing and downshifting at lights) keep me in the 270-280 range, and the only time I ever really north of 300 degrees is when I'm going up a hill or if I'm running a few miles at 65 to 70 mph (and then it maybe gets to 335) out on the "freeway." Car is running great otherwise. So I'm wondering if the flaps truly are working. When I had the engine out a few months I definitely made sure, but I don't know if something is sticking or what. Right now that's my only working theory on why my head temps are cool to normal and the oil temp is warm to hot. Any thoughts? Any good way to verify flap operation without completely removing the tin (something I don't relish doing with the engine in the car). Also, engine came with this oil temp sending unit installed (below). It's definitely the source of one of my minor oil leaks. Anybody recognize it? I'd like to go ahead and install a gauge that works with this sending unit, and also see what I need to do to stop the leak. TIA, fellas. |
VaccaRabite |
Jul 26 2015, 03:57 PM
En Garde! Group: Admin Posts: 13,420 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Flaps are working or your heads would be roasting.
Zach |
Porschef |
Jul 26 2015, 04:47 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
What have you got to measure head and oil temps? If they're truly that low then the high oil temps seem unlikely, the other way around seems more possible.
BeatNavy |
Jul 26 2015, 05:04 PM
Thanks Zach, thanks Porschef. Zach, so you don't think my issue is necessarily flap not "closing" over the oil cooler to get max heat to it? I was kind of under the impression that the cooling system sort of traded head cooling for oil cooler cooling as it warmed up, but maybe that's a bad understanding of how it actually works.
Porschef, my head temp is a Dakota Digital setup under spark plug #3. The oil temp is that "mainely by design" dipstick setup. I tested it this weekend in boiling water, and it seemed close enough. I would like to get a gauge to go with that unknown sending unit in the picture above. Are those pretty universal, or do I need to get a sending unit specific to the gauge? Thanks again. |
SLITS |
Jul 26 2015, 05:16 PM
Sender is specific to the gauge ... never seen that setup.
Cooling flaps ... passenger side is open to the cylinders, but not the oil cooler when cold. When hot, the flap closes down over the oil cooler to direct air into it. Drivers side is closed off when cold and opens when hot for air to the cylinders. Failsafe is the position when the engine is warm (assuming the spring is working). Have you cleaned your oil cooler? I put them on a lift and shoot a can of brake cleaner from the underside and then blow the fins out with an air nozzle. I realize that any gunk gets pushed over the cylinders, but unless I drop the engine I am not taking the tin off to get to it. |
BeatNavy |
Jul 26 2015, 05:40 PM
Hey Ron - I replaced the oil cooler seals when I had it out, but I don't recall the cooler being abnormally dirty (but then I probably didn't know what I was looking at). Based on what you're saying I may be able to clean it with the engine in the car, right?
If the sending unit is not recognized, is the fitting fairly standard (e.g., 1/8th npt)? Thanks. |
Mark Henry |
Jul 26 2015, 06:09 PM
Hey Ron - I replaced the oil cooler seals when I had it out, but I don't recall the cooler being abnormally dirty (but then I probably didn't know what I was looking at). Based on what you're saying I may be able to clean it with the engine in the car, right? If the sending unit is not recognized, is the fitting fairly standard (e.g., 1/8th npt)? Thanks. The taco plate for the sender is odd, factory taco plate the sender is on a 45 degree angle. I'd say it's custom taco so the sender thread could be oddball. |
messix |
Jul 26 2015, 06:18 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
run 10-40 or 10-30 and let the oil run through the motor a little faster
porschetub |
Jul 26 2015, 06:20 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Hi Beatnavy,thats getting warm....or is it,check to make sure the gauge is rated to the sendor,example 150C max gauge must use 150C sender,then get your cooling flaps/thermostat sorted ASAP,cheers.
messix |
Jul 26 2015, 06:21 PM
good reading here http://www.smartsynthetics.com/motor-oil-viscosity.htm
BeatNavy |
Jul 26 2015, 06:25 PM
The taco plate for the sender is odd, factory taco plate the sender is on a 45 degree angle. I'd say it's custom taco so the sender thread could be oddball. Hmmm....ok, not necessarily what I was hoping to hear, but makes sense. (IMG:style_emoticons/default/dry.gif) Thanks Mark. run 10-40 or 10-30 and let the oil run through the motor a little faster Yes, I'm planning on trying Brad Penn 10W40 to see if that helps. But I was hoping to throw an oil temp gauge into the cart as well. May have to wait tho... |
Java2570 |
Jul 26 2015, 06:26 PM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
Looks like your taco plate is one of Jonesy's billet taco plates.....it's got the same 14mm x 1.5 thread as the stock sender.
Harpo |
Jul 26 2015, 06:29 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
His billet taco plate looks like the one that Jonesy out of the UK was selling. I have one in my basement. The threads are the same but they are perpendicular instead of being at an angle. Beat Navy are you using the factory OE sender or the shorter one?
David |
BeatNavy |
Jul 26 2015, 07:08 PM
His billet taco plate looks like the one that Jonesy out of the UK was selling. I have one in my basement. The threads are the same but they are perpendicular instead of being at an angle. Beat Navy are you using the factory OE sender or the shorter one? David Hi David - I don't know what sender I'm using. It came with the engine. That's two votes for "Jonesy's taco plate." Any thoughts on what gauges (other than OEM) will work with that? It was reading about 2K of resistance ambient and then around 12 ohms when it was hot (roughly 240 degrees). Or am I better off just getting another gauge/sending unit that fits that "taco" plate? Thanks for everyone's help. Hi Beatnavy,thats getting warm....or is it,check to make sure the gauge is rated to the sendor,example 150C max gauge must use 150C sender,then get your cooling flaps/thermostat sorted ASAP,cheers. Welcome to the World, porschetub! Glad to see you made the trip over from the Bird! |
BeatNavy |
Jul 26 2015, 07:15 PM
The Jonesy "taco plate" makes additional sense. After searching I found he also makes a "mini deep oil sump" or tuna can that I think I also have:
mikedsilva |
Jul 26 2015, 07:18 PM
Member Group: Members Posts: 90 Joined: 23-February 15 From: Australia Member No.: 18,462 Region Association: Australia and New Zealand |
if any of you are selling one of those billet taco plates on the cheap, I am keep to take it from you (IMG:style_emoticons/default/smile.gif)
porschetub |
Jul 26 2015, 07:30 PM
His billet taco plate looks like the one that Jonesy out of the UK was selling. I have one in my basement. The threads are the same but they are perpendicular instead of being at an angle. Beat Navy are you using the factory OE sender or the shorter one? David Hi David - I don't know what sender I'm using. It came with the engine. That's two votes for "Jonesy's taco plate." Any thoughts on what gauges (other than OEM) will work with that? It was reading about 2K of resistance ambient and then around 12 ohms when it was hot (roughly 240 degrees). Or am I better off just getting another gauge/sending unit that fits that "taco" plate? Thanks for everyone's help. Hi Beatnavy,thats getting warm....or is it,check to make sure the gauge is rated to the sendor,example 150C max gauge must use 150C sender,then get your cooling flaps/thermostat sorted ASAP,cheers. Welcome to the World, porschetub! Glad to see you made the trip over from the Bird! Yea thanks,thought it was time for the move,enjoying it so far,lots on here know way more about my car that i do (IMG:style_emoticons/default/smile.gif) . I have always liked VDO stuff,buy a matched gauge and sender to suit the temp range you need and go from there,you need to sort this to set a baseline for further work into your problem. Coolers......I swapped my 911 cooler for one modded for a 914/6,it had been cleaned by PO the cheap and nasty way,I had it ultrasonically cleaned and they said it was filthy,really worth doing if you can't fully sort your problem by other means,cheers. |
Mblizzard |
Jul 27 2015, 05:12 AM
Cheap easy check. Buy a USB camera from Amazon and inspect the flaps. Pretty easy to see if you go in through timing port.
DRPHIL914 |
Jul 27 2015, 06:45 AM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
the temps you are seeing are similar to the temps i have been seeing as well, but also found out that checking and calibrating my dipstick thermometer that my gauge was reading 30-40 degrees warmer than dipstick.
- i have the same billet deep tuna can and also the billet tuna can replacement as does Jim Hoyland. I have ordered a new VDO gauge that iwll match the sender properly and should give a more accurate indication of oil temp. my current gauge is off brand from before and not correct. - i just switched to a 10-40 oil from 20/50 and while i only have one day of driving this past weekend after the oil change it appears this made a measurable difference in my temps, i did not measure an oil temp over 205-210 this weekend and i had been pushing that 240 range before. the real test will be when i take it out on a hot day for more spirited driving. i was and still may consider replacing the stock cooler with the set up that Chris Foley has, or just an add-on aux. cooler that several other members have put in that seems to have worked well for them. - i still am going to go back to recheck my timing as that will matter for overal engine temp but if you have good head temps i would say that is not your problem. - a good racing oil will not break down at 250 or even 275, but som oils will begin to do that at that point. last year at octeenerfest i talked to John Forbes about this, because when pushing hard going up the mountain with our group i hit that 250 point and was very concerned. see how much change it makes with the other oil as i am before spending a bunch of extra cash on something else. |
BeatNavy |
Jul 27 2015, 04:11 PM
Cheap easy check. Buy a USB camera from Amazon and inspect the flaps. Pretty easy to see if you go in through timing port. Hey Mike - that's a good idea. Just bought one. Could come in handy for many reasons. the temps you are seeing are similar to the temps i have been seeing as well, but also found out that checking and calibrating my dipstick thermometer that my gauge was reading 30-40 degrees warmer than dipstick. - i have the same billet deep tuna can and also the billet tuna can replacement as does Jim Hoyland. I have ordered a new VDO gauge that iwll match the sender properly and should give a more accurate indication of oil temp. my current gauge is off brand from before and not correct. - i just switched to a 10-40 oil from 20/50 and while i only have one day of driving this past weekend after the oil change it appears this made a measurable difference in my temps, i did not measure an oil temp over 205-210 this weekend and i had been pushing that 240 range before. the real test will be when i take it out on a hot day for more spirited driving. i was and still may consider replacing the stock cooler with the set up that Chris Foley has, or just an add-on aux. cooler that several other members have put in that seems to have worked well for them. - i still am going to go back to recheck my timing as that will matter for overal engine temp but if you have good head temps i would say that is not your problem. - a good racing oil will not break down at 250 or even 275, but som oils will begin to do that at that point. last year at octeenerfest i talked to John Forbes about this, because when pushing hard going up the mountain with our group i hit that 250 point and was very concerned. see how much change it makes with the other oil as i am before spending a bunch of extra cash on something else. Hey Phil - I am planning on switching to 10w40 to see if that helps. I'd really spend my time/money on something other than installing an oil cooler on a -4. Of course I don't want to spend my money on rebuilding a fairly fresh engine either. I'm going to go shopping for a VDO gauge... Thanks again for everyone's help. |
Lo-Fi Version | Time is now: 19th April 2024 - 11:04 PM |
