Please Delete, please delete |
Mike1981 |
Aug 29 2015, 04:28 PM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
please delete
JRust |
Aug 29 2015, 04:59 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Looks pretty good to me at that price. Has some nice bits with it. Wouldn't consider it a daily driver with the current setup. A little more interior I'm sure it could be. Roll bar setup looks a little funny to me. Far from a n expert there though
Mike1981 |
Aug 29 2015, 05:15 PM
Thanks
Added 2 pics of exterior |
914forme |
Aug 30 2015, 05:26 AM
Need engine bay shot, under battery, for the price not bad, worse case is you get another chassis. But we have all seen a lot of 914 brought back to life on these forums.
BTW, I'd cut the cage out. The from drop should be perpendicular to the logs. Also needs some diagonal bracing. Also does not look like it ties in anywhere up top. Normally they tie in on seat belt bolts. And would not know unless it has an inspection hole, what the tube thickness is. Could be Exhaust tubing. One way to know, is hit it with the round end of a ball peened harmer. Proper spec DOM will not dent, with out serious force, exhaust turning will. Not good for negotiation. Of course you could also take an Ice Pick to everything, and start reducing price by the amount of rust you find. BTW, the monster decal adds 10Hp to the car |
Mike1981 |
Aug 30 2015, 08:51 AM
Added engine bay shots
Thanks for the responses It is helping me warm up to this car |
Mike1981 |
Aug 30 2015, 08:58 AM
Yes
Planning to cut the cage out Remove back wing re-mount gauges from the roll-bar Fix brakes-tires-caliper Compound-Polish-wax Change fluids vacuum/scrub fix little things Not going to consider it a daily driver just a sporty weekender Still worried about fixing the tranny would you think $1000.00 for this Thanks Mike |
JRust |
Aug 30 2015, 02:08 PM
Still worried about fixing the tranny would you think $1000.00 for this Fairly common issues there. Get DR Evil's CD & fix it yourself. Probably just needs dog teeth & Synchro's. May just be linkage bushings though. I'd start with all the linkage bushings. Then move onto the tranny. If it is the tranny. Pickup a used one & try it. Worst case at least you have more spare parts to rebuild one box. Tailshifters make great donor's for rebuilds (IMG:style_emoticons/default/smile.gif) |
matthepcat |
Aug 30 2015, 10:10 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Just convert it over to a Subaru trans and cable shifter.
914forme |
Aug 31 2015, 07:39 AM
Zip ties holding overflow bottle or Air purge bottle to engine lid torsion bars. (IMG:style_emoticons/default/headbang.gif)
No shot of the Hell Hole, but then, if you are wanting a project, this one will be a project. I second the Subaru Transmission, easy swap, cable shifter, makes it feel like a modren car. Need to fabricate trans mounts, and shifter assembly, but thats not a big deal or you can get a bud to help. |
Mike1981 |
Sep 1 2015, 07:01 PM
Thanks Everyone
I asked for shots of the hood, trunk as well as the longs and hell hole I have had no response...... Maybe this will not happen? |
Mike1981 |
Sep 3 2015, 04:47 PM
Hello
Owner did get back to me Has a soft clutch and 1st gear grinds Also has problem with steering rack I m loosing faith in this one Any advice? Mike |
dflesburg |
Sep 4 2015, 03:21 AM
Senior Member Group: Members Posts: 1,719 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
My advise, buy my GT you know its what you really want most.
Mike1981 |
Sep 4 2015, 04:26 AM
My advise, buy my GT you know its what you really want most. If your talking this one http://www.ebay.com/itm/Porsche-914-GT-wit...714485#viTabs_0 Yes that would keep me happy Broke and Happy |
Lo-Fi Version | Time is now: 24th April 2024 - 02:31 AM |
