Relay Board Sealant |
stinkindiesel |
Oct 7 2015, 12:33 PM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
I'm finally getting around to doing some cleanup work on the 1.7L, and I've got a bunch of questions. I'll try to keep it to one question per post to avoid confusion.
I've got three relay boards in various states of decline, and would really like to get one cleaned up for use. I can certainly ohm out all the connections, but that won't always catch any intermittent opens. Ideally, I'd just remove the black potting compound from the bottom and solder the connections. Anyone have any experience removing the old sealant? Is there some chemical that will soften it without destroying the rest of the board, or do I just have to chip the old stuff off? Gary |
914_teener |
Oct 7 2015, 03:12 PM
914 Guru Group: Members Posts: 5,193 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Yep.....put it in a oil drain pan with gasoline....it will come right off. I finished it in the nooks and crannies with a stiff plastic brush.
Mike Bellis |
Oct 7 2015, 08:59 PM
stinkindiesel |
Oct 8 2015, 07:49 PM
Thanks, guys. Just what I needed. I'm shocked gasoline is all it takes, but the easier the better. I'll give it a try this weekend.
Gary |
Lo-Fi Version | Time is now: 23rd April 2024 - 01:40 AM |
