License Plate Restoration, Recommendation |
burton73 |
Apr 10 2020, 03:20 PM
burton73 Group: Members Posts: 3,655 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Hi Clay,
Eric @PMB sent my plates for a repaint and they did a perfect job. Call E and he should tell you who did them. Best Bob B |
eric9144 |
Apr 10 2020, 04:39 PM
Advanced Member Group: Members Posts: 2,739 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
Damn Bob those look great! (IMG:style_emoticons/default/first.gif)
914_7T3 |
Apr 10 2020, 06:18 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,862 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
[quote name='76-914' date='Nov 17 2015, 04:48 PM' post='2266293']
[/quote] BTW, I emailed that company here in Socal to ask if they do Dealer Frames as well. (IMG:style_emoticons/default/drooley.gif) [/quote] @76-914 Below are two SoCal sources that can restore vintage dealer plate frames. Pulled this info off of an old Early 911S Registry thread: https://www.early911sregistry.org/forums/sh...ration-(chrome) Vernes Chrome Plating 1559 W. El Segundo Boulevard Gardena, California 90249 323-754-4126 Sihilling Metal Polishing 1702 Newport Cir., Unit D Santa Ana, CA 92705 714-543-7051 Talked to Vernes earlier and they do not paint after chroming. Will call Sihilling on Monday before deciding on which direction to go in with my frame. |
FlacaProductions |
Apr 10 2020, 06:53 PM
Senior Member Group: Members Posts: 1,737 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
There are some great threads on the early 911S registry board....they go down in the weeds on chroming and re-painting the frames - who is good...and who isn't. If you're taking one in and it's special, do your research and/or put a test case through to see if the work is up to your standards.
I have one from Tom Cheney Porsche in Harvey, IL which is where my 914 was originally sold - if I were to re-do the plate, I'd have the frame done as well but the patina on it matches the plate.... |
76-914 |
Apr 10 2020, 07:52 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,611 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
[quote name='914_7T3' date='Apr 10 2020, 05:18 PM' post='2802985']
[quote name='76-914' date='Nov 17 2015, 04:48 PM' post='2266293'] [/quote] BTW, I emailed that company here in Socal to ask if they do Dealer Frames as well. (IMG:style_emoticons/default/drooley.gif) [/quote] @76-914 Below are two SoCal sources that can restore vintage dealer plate frames. Pulled this info off of an old Early 911S Registry thread: https://www.early911sregistry.org/forums/sh...ration-(chrome) Vernes Chrome Plating 1559 W. El Segundo Boulevard Gardena, California 90249 323-754-4126 Sihilling Metal Polishing 1702 Newport Cir., Unit D Santa Ana, CA 92705 714-543-7051 Talked to Vernes earlier and they do not paint after chroming. Will call Sihilling on Monday before deciding on which direction to go in with my frame. [/quote] Thx for the "Heads Up" but I had mine done by a guy in El Cajon, IIRC. Toolguy gave me the referral and he did a great job. ~$50 but worth it IMHO. (IMG:style_emoticons/default/beerchug.gif) |
914_teener |
Apr 10 2020, 08:59 PM
914 Guru Group: Members Posts: 5,245 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Lo-Fi Version | Time is now: 27th September 2024 - 05:29 AM |
