Electronic longevity |
Gunn1 |
Apr 30 2016, 09:27 PM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
I have many relays, sensors and electrical parts from various 914 parts cars.
My question is if these test out as being good, are they ok to use? Just asking if it might be better to buy new stuff rather than use 40year old electronics that would fail soon after being put back to use. Any thoughts or experience with this would be appreciated . Thank you |
Amphicar770 |
Apr 30 2016, 10:01 PM
Senior Member Group: Members Posts: 1,181 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
I have many relays, sensors and electrical parts from various 914 parts cars. My question is if these test out as being good, are they ok to use? Just asking if it might be better to buy new stuff rather than use 40year old electronics that would fail soon after being put back to use. Any thoughts or experience with this would be appreciated . Thank you A lot depends on how and where they were stored. Rust is bad especially on things like electromechanical relays. If it is something really hard to get to or critical to safety you may want to go with new. Otherwise, probably fine to use them. |
Mikey914 |
Apr 30 2016, 10:02 PM
The rubber man Group: Members Posts: 12,622 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes, used parts can fail, but they are "solid state", so test them, and carry some spares.
Apr 30 2016, 10:11 PM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Buy a pack of red, white and blue fuses from the eBay vendor that sells 20 of each + free ship for $10. Replace them all including the ones on the relay board in the engine compartment. Keep the extras in the glove box. You can't go wrong with new fuses vs old.
Gunn1 |
May 1 2016, 04:58 AM
I am not as worried about the solid state stuff as I am the relays, switches, motors.
How robust is some of this stuff? Sure it tests out on the bench and works now but after It's installed back in the car and heats up wondering about the failure rate. Thanks |
Geezer914 |
May 1 2016, 05:09 AM
Geezer914 Group: Members Posts: 1,358 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I would use them and carry spares. Hell, even new parts fail.
Mike Bellis |
May 1 2016, 12:08 PM
The quality of the old relays is better than new ones. Just carry spares.
The "solid state" only applies to the ECU and a couple other items (tach, flasher relay, etc.). The biggest issue for this stuff is capacitor failure. The caps can dry out over time and fail. |
Lo-Fi Version | Time is now: 28th March 2024 - 03:40 AM |
