Wiring deiagram or description for the intermittent wiper relay |
brant |
May 26 2016, 08:50 PM
914 Wizard Group: Members Posts: 11,603 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
My int. Relay test good yet my int feature is not working
Can anyone tell me how the find a wiring diagram thread.... or wiring description so I can better trace my wiring Thanks in advance Tia |
Valy |
May 26 2016, 09:10 PM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
1. Look at the wiring diagram for your car specific year on the Pelican site.
2. How did you test the relay? 3. What switch do you have. Not all of them have the int. functionality. |
brant |
May 26 2016, 10:35 PM
It worked previously and I converted the switch 25 years ago before the Internet
My wire colors aren't in a factory wire loom for int wipers I have two relays that test good There is a thread for testing them linked to world. From a 924/44 site I didn't find the diagram in Haynes but can search pelican tomorrow Figured ther was likely a thread on world but couldn't find it |
steuspeed |
May 27 2016, 12:15 AM
Senior Member Group: Members Posts: 1,005 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
I have not done mine yet, but look for a .99 programmable relay if you do it. You select intermittent and then off again re-select and that sets the timing.
JeffBowlsby |
May 27 2016, 05:22 AM
914 Wiring Harnesses Group: Members Posts: 8,470 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The schematic and installation instructions are at the bottom of my wiring harness webpage (in the reference library). 2 separate documents.
http://bowlsby.net/914/WiringHarnesses/ |
brant |
May 27 2016, 06:26 AM
The schematic and installation instructions are at the bottom of my wiring harness webpage (in the reference library). 2 separate documents. http://bowlsby.net/914/WiringHarnesses/ Thanks a ton |
Lo-Fi Version | Time is now: 18th April 2024 - 07:08 PM |
