Free (at cost) full size rear stiffener patterns, And/or trade for full size front sway bar stiffener patterns |
HalfMoon |
Dec 6 2016, 02:21 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
You pay for the paper, the copying, the shipping tube and shipping costs (essentially the costs).
Can't imagine it'd be more than $20 CONUS. Just trace it out on your metal, cut and weld. Beats spending $150 bux to have em pre-cut. David PS-straight trade for full size front sway bar stiffener pattern. Admin-if posted in the wrong place, move as you see fit :-) |
nick1973 |
Dec 9 2016, 03:53 AM
Newbie Group: Members Posts: 6 Joined: 29-April 15 From: Doncaster in the sunny uk Member No.: 18,678 Region Association: None |
You pay for the paper, the copying, the shipping tube and shipping costs (essentially the costs). Can't imagine it'd be more than $20 CONUS. Just trace it out on your metal, cut and weld. Beats spending $150 bux to have em pre-cut. David PS-straight trade for full size front sway bar stiffener pattern. Admin-if posted in the wrong place, move as you see fit :-) Id like a set if you can post to the uk thanks |
mbseto |
Dec 9 2016, 08:18 AM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
If you're not looking to make money from this, why not just email a dxf that a person could print at a local print shop? If this site had a place to stage drawing files, I'll bet we could build quite a stock.
cwpeden |
Dec 9 2016, 08:34 AM
Or we could support the people that support us?
I don't know what your time is worth but looked at a set and knowing what my time is worth, it would cost way more that $150 in time to make them....just sayin. |
HalfMoon |
Dec 9 2016, 09:23 AM
You pay for the paper, the copying, the shipping tube and shipping costs (essentially the costs). Can't imagine it'd be more than $20 CONUS. Just trace it out on your metal, cut and weld. Beats spending $150 bux to have em pre-cut. David PS-straight trade for full size front sway bar stiffener pattern. Admin-if posted in the wrong place, move as you see fit :-) Id like a set if you can post to the uk thanks No problem. I'll send em anywhere. |
HalfMoon |
Dec 9 2016, 09:24 AM
If you're not looking to make money from this, why not just email a dxf that a person could print at a local print shop? If this site had a place to stage drawing files, I'll bet we could build quite a stock. I traced em from my originals. They are FULL size. No idea how I'd make digital file of the them. My local UPS store has a large copier so I can make copies pretty easily. Pop em in a shipping tube and send em off. |
HalfMoon |
Dec 9 2016, 09:26 AM
HalfMoon |
Dec 9 2016, 04:19 PM
Mueller |
Dec 10 2016, 01:52 PM
If you are talking about the triangle shaped front swaybar part, I think I've posted a dxf or full size picture/pdf of them before, I'll try and look later on.
This is something that someone could just take a picture of with just a few dimensions to get a drawing made easily. |
Chris914n6 |
Dec 10 2016, 09:03 PM
Jackstands are my life. Group: Members Posts: 3,303 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Those holes look pretty random.
I can make a dxf file out the tracings if we want to open source this stuff. Totally worth my time if I don't have to do the measurements for the long stiffeners. A 4x8 sheet of 16ga is currently around $60 at the metal supply place, so might be worth it for those with a cutter and free time. |
Mueller |
Dec 11 2016, 12:02 AM
Those holes look pretty random. I can make a dxf file out the tracings if we want to open source this stuff. Totally worth my time if I don't have to do the measurements for the long stiffeners. A 4x8 sheet of 16ga is currently around $60 at the metal supply place, so might be worth it for those with a cutter and free time. You should be able to make a dxf from the picture, just need 2 or so dimensions to get a good reference. |
Mueller |
Dec 11 2016, 12:20 AM
I was lazy and didn't want to add the rest of the holes, for scale reference I made those holes .250"
Mueller |
Dec 11 2016, 10:39 PM
are there instructions someplace that show what plate goes where and if there are bends?
mbseto |
Dec 12 2016, 01:50 PM
You should be able to make a dxf from the picture, just need 2 or so dimensions to get a good reference. You'll get significant foreshortening error from a photograph. Better to scan, trace, or whatever, to get an accurate shape. Not saying anyone's obligated to do this, but making drawings from photos is doomed to frustration. |
HalfMoon |
Dec 14 2016, 03:59 PM
This is what the costs are to Laguana Beach CA so it gives a fairly good idea of what the costs are.
PM me if ya want one (copy). 3.50 Shipping tube 11.00 full size copy 10.71 UPS to CA 92651 25.21 Total |
nick1973 |
Dec 16 2016, 06:45 AM
I was lazy and didn't want to add the rest of the holes, for scale reference I made those holes .250" this is great im after a set but im in the uk so shipping the steel panels is crazy i can get them drawn up and lazered out for for less than the shipping costs (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) |
jmitro |
Dec 16 2016, 07:01 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
Or we could support the people that support us? I don't know what your time is worth but looked at a set and knowing what my time is worth, it would cost way more that $150 in time to make them....just sayin. (IMG:style_emoticons/default/agree.gif) ithe cost of materials is going to be at least half the cost. Sheetmetal aint cheap. Add in the hours of labor to precisely trace, cut, drill/punch, and you won't be saving any money. and no, I don't want a set. I ordered mine from Mad Dogs Motorsports (IMG:style_emoticons/default/wink.gif) |
HalfMoon |
Dec 16 2016, 11:21 AM
Or we could support the people that support us? I don't know what your time is worth but looked at a set and knowing what my time is worth, it would cost way more that $150 in time to make them....just sayin. (IMG:style_emoticons/default/agree.gif) ithe cost of materials is going to be at least half the cost. Sheetmetal aint cheap. Add in the hours of labor to precisely trace, cut, drill/punch, and you won't be saving any money. and no, I don't want a set. I ordered mine from Mad Dogs Motorsports (IMG:style_emoticons/default/wink.gif) Oh good. I'm happy for you :-) |
Mueller |
Dec 16 2016, 02:40 PM
You should be able to make a dxf from the picture, just need 2 or so dimensions to get a good reference. You'll get significant foreshortening error from a photograph. Better to scan, trace, or whatever, to get an accurate shape. Not saying anyone's obligated to do this, but making drawings from photos is doomed to frustration. Not a precision part like a piston wrist pin, these are getting welded and possibly beat to submission to get them to fit correctly. How many kits are out there? Can you say that they are all exact? If someone is told to make cardboard templates how is a photo driven drawing going to be that far off? |
Chris914n6 |
Dec 16 2016, 05:45 PM
Or we could support the people that support us? I don't know what your time is worth but looked at a set and knowing what my time is worth, it would cost way more that $150 in time to make them....just sayin. (IMG:style_emoticons/default/agree.gif) ithe cost of materials is going to be at least half the cost. Sheetmetal aint cheap. Add in the hours of labor to precisely trace, cut, drill/punch, and you won't be saving any money. and no, I don't want a set. I ordered mine from Mad Dogs Motorsports (IMG:style_emoticons/default/wink.gif) I've got nothing against MadDog, and I'd bet this kit is not their precision cut kit, but $260 shipped buys a whole day of my time. Plus the extra steel can be used for the rocker stiffeners and other projects. Mike- I've been in the sign business long enough to know pics don't make good templates. Too much distortion, things get smaller further away from dead center. |
Lo-Fi Version | Time is now: 23rd April 2024 - 10:26 PM |
