FS: 1974 914 1.8 w/dual Carb, SOLD |
chads74 |
Feb 14 2017, 07:29 PM
Member Group: Members Posts: 386 Joined: 13-March 12 From: Tampa, FL Member No.: 14,252 Region Association: South East States |
I am trying to sell the car before moving cross country as I transition out of the Air Force in a couple months. I didn't get a lot of interest before so I thought I would take more pictures of the rust areas to show how solid the car is. If you have any questions please ask away. Asking $5,500 obo. More pictures can be found at my photobucket library: http://s1376.photobucket.com/user/chad_smi...ideshow/Porsche ((If you can't get past picture 48 on the slide show you should be able to close the slide show and still see the pictures one by one. There are over 100 pictures.))
Chad |
chads74 |
Feb 15 2017, 09:04 PM
chads74 |
Feb 15 2017, 09:06 PM
chads74 |
Feb 15 2017, 09:10 PM
chads74 |
Feb 15 2017, 09:12 PM
chads74 |
Feb 15 2017, 09:13 PM
chads74 |
Feb 15 2017, 09:28 PM
carr914 |
Feb 16 2017, 07:24 PM
Racer from Birth Group: Members Posts: 118,049 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Gonna miss ya! Where are you headed?
chads74 |
Feb 16 2017, 07:47 PM
TonyA |
Feb 17 2017, 09:36 AM
Nachmal Group: Members Posts: 459 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States |
I am trying to sell the car before moving cross country as I transition out of the Air Force in a couple months. I didn't get a lot of interest before so I thought I would take more pictures of the rust areas to show how solid the car is. If you have any questions please ask away. Asking $5,500 obo. More pictures can be found at my photobucket library: http://s1376.photobucket.com/user/chad_smi...ideshow/Porsche ((If you can't get past picture 48 on the slide show you should be able to close the slide show and still see the pictures one by one. There are over 100 pictures.)) Chad looks great |
chads74 |
Feb 18 2017, 10:42 AM
frostyf |
Feb 28 2017, 10:07 AM
Member Group: Members Posts: 153 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region |
Chad, Has the car had any welding done to your knowledge? Also has it got sway bars? How was the plasticote finish done - spray cans or otherwise? Do you have any of the tinware cut from the inner front fenders and the trunk lid in the back? Is it drivable on the 1.8? Thanks, Nick |
chads74 |
Mar 2 2017, 08:53 AM
Chad,
Has the car had any welding done to your knowledge? Also has it got sway bars? How was the plasticote finish done - spray cans or otherwise? Do you have any of the tinware cut from the inner front fenders and the trunk lid in the back? Is it drivable on the 1.8? Thanks, Nick [/quote] The car had the left rear panel replaced before I bought the car, but I could only tell from inside the trunk after I bought it and had it at home. It has a Weltmister front sway bar, either 21 or 22mm, I'll double check. I did the plastidip myself with the special spray gun they sell and 2.5 gallons of flex blue. I will have to double check if I kept the cut out for the distributor in the rear trunk, but I know I have the cut outs from the front wheel wells. Car drives great, the carbs could probably use a little tlc, but it has hydraulic lifters so you don't have to worry about adjusting valves. Let me know if you have any other questions, and I'll doubled check the sway bar size and what sheet metal I have. |
chads74 |
Mar 10 2017, 11:14 PM
Sale Pending
Lo-Fi Version | Time is now: 19th April 2024 - 11:43 PM |
