engine bay plug |
engine bay plug |
gulf908 |
Feb 26 2017, 11:45 PM
Member Group: Members Posts: 122 Joined: 25-December 13 From: Sydney Member No.: 16,795 Region Association: Australia and New Zealand |
Guys
I have a plastic plug in the side rail just under the battery on my '70 -6. I need another for the other side as I have only tape there Does this plug have a part number - I looked on the parts cd but its hidden somewhere (IMG:style_emoticons/default/sad.gif) It seems to be plugging a hole - is the hole for the -4s ? TIA Dennis (IMG:style_emoticons/default/smile.gif) Attached image(s) |
porschetub |
Feb 27 2017, 01:29 AM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
possibly for rain tray drains Dennis,many wiser than me may comment.
rgalla9146 |
Feb 27 2017, 08:20 AM
Advanced Member Group: Members Posts: 4,544 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Yes, the hole is for the 4 cyl. rain tray drains.
The plug is a 6 only part. (no rain tray) There is another oval shape plug on original 6 cyl. cars to fill one of the fuel line holes. Is either still available ? |
forrestkhaag |
Feb 27 2017, 10:44 AM
On my 71, I made two round plates with a tab on them for bolting them to the tin. They work fine and is a simple fix / not sure if 914 rubber has them aftermarket..
(IMG:style_emoticons/default/beerchug.gif) |
Larmo63 |
Feb 27 2017, 10:55 AM
I have two 40mm holes to plug there myself. There are solid rubber grommets that size, but I haven't found them in small lots.
I'd opt for that original Porsche (like yours) part if someone finds a source. |
Tom_T |
Feb 27 2017, 12:50 PM
IIRC Auto Atlanta has them as repros, not sure if 914Rubber does.
AA also just got in the 3 rear trunk floor plastic plugs (2 sizes) as a new repro FYI. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Harpo |
Feb 27 2017, 06:55 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I would buy two of these. Maybe 914rubber can make them?
Thanks |
GeorgeRud |
Feb 27 2017, 08:49 PM
Don't know about availability, but the part numbers were:
914 559 243 10 Large plug 914 559 245 10. Gas line plug |
Larmo63 |
Feb 27 2017, 09:50 PM
Weird, but I found two of them in my 914 stuff. I don't recall where they came from or where I got them.
porschetub |
Feb 28 2017, 12:31 PM
I have blocked off all unused opening with rubber gromments and got the rubber seals around the engine tins sealing the best I can.
The fan on the 6 is a powerful beast think I have stopped it drawing some of the hot air,got to make even a small difference right ? |
GeorgeRud |
Feb 28 2017, 12:57 PM
You want to plug them up as much as possible, though the engine cover grill will be the easiest way for air to get to the engine. Any rubber plugs/grommets should do the job, but the Porsche ones may be desirable for the concour crowd.
gulf908 |
Mar 1 2017, 12:53 AM
mgphoto |
Mar 1 2017, 08:52 AM
"If there is a mistake it will find me" Group: Members Posts: 1,335 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Yes, the hole is for the 4 cyl. rain tray drains. The plug is a 6 only part. (no rain tray) There is another oval shape plug on original 6 cyl. cars to fill one of the fuel line holes. Is either still available ? No not for 4/cyl, these are to run oil lines and such. The drain holes are toward the rear of the engine compartment. Not sure about later models but '72 and down have them. Check with Bruce Stone for this item. Good luck, Mike |
6freak |
Mar 1 2017, 03:46 PM
IIRC Auto Atlanta has them as repros, not sure if 914Rubber does. AA also just got in the 3 rear trunk floor plastic plugs (2 sizes) as a new repro FYI. (IMG:style_emoticons/default/beerchug.gif) Tom /////// I need a few as well, been looking forever!... to run oil lines! first I heard that one (IMG:style_emoticons/default/smile.gif) |
sbsix |
Mar 1 2017, 09:07 PM
only the lead dog enjoys a change in scenery... Group: Members Posts: 447 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
NLA for a very long time. Hoping Mark at 914rubber can reproduce. The ones fromAA are black and not clear like the OE ones.
Larmo63 |
Mar 1 2017, 10:01 PM
I used hot water, Soft Scrub, and a toothbrush, they look NOS.
I'm baffled as to where they came from. |
sbsix |
Mar 2 2017, 02:33 PM
These are from my six. I haven't been able to whiten them at all. Love suggestions or if we could persuade 914rubber to reproduce?
sbsix |
Mar 2 2017, 02:35 PM
Top shot. I'm sending these while about to hike up Machu Picchu! I just love technology!
Lo-Fi Version | Time is now: 18th April 2024 - 11:27 AM |
