High CHT before the thermostat opens. |
falcor75 |
Apr 20 2017, 10:28 PM
Senior Member Group: Members Posts: 1,578 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I have a CHT sensor under the sparkplugs on cylinder 1 and 3.
I can see that Cyl1 gets much hotter than Cyl 3 before the thermostat opens fully and I'm guessing that is because the flap on that side of the Engine is "closed" before the thermostat opens. To get a little more airflow on that side can I just slacken the thermostat wire a bit to let the flap be a bit more open untill the thermostat heats up and de-tensions the wire fully? Or am I thinking wrong about how it moves? |
falcor75 |
Apr 21 2017, 10:08 AM
Slackened the cable around 4-5 mm and that seems to have worked a treat. Much more even temps between the heads.
Lo-Fi Version | Time is now: 29th March 2024 - 09:46 AM |
