WTB: throttle body return spring |
proto31 |
Jun 25 2017, 10:21 PM
Member Group: Members Posts: 413 Joined: 2-February 06 From: Costa Mesa, CA. Member No.: 5,515 Region Association: None |
Does anyone have a good 2.0 D-jet throttle body return spring? The spring that pulls the throttle butterfly back down to idle?
bdstone914 |
Jun 26 2017, 07:16 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Does anyone have a good 2.0 D-jet throttle body return spring? The spring that pulls the throttle butterfly back down to idle? I probably have some in my collection. I used to pull them off of Mercedes cars in Pick a a parts yards. You can rebend the straight section of the spring to get the right tension. Unless you are going to be a weenie and want an original Porsche part. (IMG:style_emoticons/default/poke.gif) |
proto31 |
Jun 26 2017, 12:41 PM
Does anyone have a good 2.0 D-jet throttle body return spring? The spring that pulls the throttle butterfly back down to idle? I probably have some in my collection. I used to pull them off of Mercedes cars in Pick a a parts yards. You can rebend the straight section of the spring to get the right tension. Unless you are going to be a weenie and want an original Porsche part. (IMG:style_emoticons/default/poke.gif) I'll take what I can get (IMG:style_emoticons/default/smile.gif) |
saigon71 |
Jun 26 2017, 01:32 PM
Senior Member Group: Members Posts: 1,997 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
If Bruce doesn't have what you need, check out your local auto parts store. I bought a pack of throttle springs for a few bucks and found one that works well.
Lo-Fi Version | Time is now: 24th April 2024 - 03:57 AM |
