Mihai's Progress Thread!, One more. |
mihai914 |
Aug 12 2005, 06:29 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
This is the other patch made to cover the holes on the sides where the fuel lines bend upward froom the firewall, I made sure those were out of the way (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
redshift |
Aug 12 2005, 06:32 PM
lol! Looking good, buddy! M |
mihai914 |
Aug 12 2005, 06:35 PM
Welding went much better since most of the base was new metal, it tied well the lower part of the inner long with the vertocal part. I pulled on the whole thing and it got the car moving. Unfortunately it started to rain very little so I calle dit a day, but for the heck of it I loosened the braces to see if it improved something on the car.
The result was that the car came back to original spec (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) , since I'm not done I streched back the braces to support the car, don't want the new pieces to sag allready. Attached image(s) |
mihai914 |
Aug 17 2005, 05:11 PM
Got some more stuff done over the week, I'm getting close to a driveable car.
First I took some measurements for the replacement rocker panel, mainly where the heater tube starts and where this panel will overlap the lower wheel house. Attached image(s) |
mihai914 |
Aug 17 2005, 05:14 PM
Then I welded a piece of angle iron inside the patch whereabouts the jacking plate would be. Since I won't be putting the jack post and plate, I did the reinforcement from inside.
mihai914 |
Aug 17 2005, 05:15 PM
Here is the second piece, these do not interfere with anything. I did the same thing on the other side of the car but had forgotten to take a picture.
mihai914 |
Aug 17 2005, 05:18 PM
Since the seat belt support inside the long was completely rusted out I had to remake a bracket. I had to take the old piece and save the threaded part that I attached to some angle iron with a hole in the middle.
mihai914 |
Aug 17 2005, 05:21 PM
I could of used a simple nut to the back of the new bracket but decided to keep the original insert. I carefully drilled the hole and the pressed in the thing (I don't know what it's called exactly).
mihai914 |
Aug 17 2005, 05:22 PM
Here is a general view of the rocker replacement section with the inner reinforcements.
mihai914 |
Aug 17 2005, 05:26 PM
Another replacement patch for the suspension console/engine mount area. The main function of this patch is to elongate the flange that you see from underneath the car.
mihai914 |
Aug 17 2005, 05:28 PM
Here it is welded in, the upper part is useless for now, I just left it there, you never know when it might be needed.
mihai914 |
Aug 17 2005, 05:31 PM
Another reinforcement panel to be put in. This is the one that has the seat belt bracket on it. This thing is overkill but I'd rather be safe than sorry!
mihai914 |
Aug 17 2005, 06:08 PM
All welded in first picture.
mihai914 |
Aug 17 2005, 06:09 PM
Second.
mihai914 |
Aug 17 2005, 06:11 PM
Heater tube brackets are back in place.
mihai914 |
Aug 17 2005, 06:12 PM
Cleaned the weld splatter with a vacuum and some compressed air and applied primer to the finished inner section.
Here is a general view. Attached image(s) |
mihai914 |
Aug 17 2005, 06:13 PM
Rear view.
mihai914 |
Aug 17 2005, 06:14 PM
Front view.
mihai914 |
Aug 17 2005, 06:15 PM
And to top things off, the sealer, undercoating.
michelko |
Aug 18 2005, 12:05 AM
Senior Member Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) very very nice work. (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif)
Why didnĀ“t you do this a year earlier. Maybe it saved me from some headake if i saw it befor i started my restauration. Keep on going (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 05:28 PM |
