Single carburetor setup, Setup single carburetor/distributor for a 1.8 |
struckn |
Aug 11 2017, 02:23 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
Are you running a centrifugal advance distributor or vacuum ? If vacuum , where is connected ? Thank's
[/quote] |
struckn |
Aug 11 2017, 02:41 PM
Reply, My 1.8 single carb car's distributor has a Pertronix Electronic module, or similar electronic module. It came installed on the car from the previous owner, no points, no vacuum advance, advance is done electronically. |
mrholland2 |
Aug 11 2017, 02:52 PM
Senior Member Group: Members Posts: 759 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Try an air cleaner assembly from an old Fiat 125 and a hear riser tube. It won't e perfect but it will be better
Lo-Fi Version | Time is now: 26th September 2024 - 09:48 PM |
