Differences Between Flat 15x6 and Deep 15x6 Wheels, Inquiring minds... |
gcrotvik |
Aug 12 2017, 02:20 PM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
I'm considering purchasing a set of deep 6's. I'm confused as to the differences between the "flat" and "deep" 15 x 6 wheels. I understand they are deeper dish but what does that actually mean in terms of fitment? Both are 6 inches wide and have an offset of 36 and a backspace of 112. To me (I may be wrong, that's why I'm asking), that means the fitment, measured from the inner lip of the wheel well to the outside lip of the rim is exactly the same for both wheels. If so, when why are the deep 6's all the rage? Because they look "deeper"? See the reference chart below.
Educate me please!! Thanks. If this topic has been covered here before, my apologies. Greg Attached image(s) |
mb911 |
Aug 12 2017, 02:33 PM
914 Guru Group: Members Posts: 6,802 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I believe its in looks only that there is a difference.
Mark Henry |
Aug 12 2017, 02:58 PM
Where the center meets the rim flat's are 20mm deep and deep's are 43mm.
Some like the look of the deep Fuchs, too me it's only really noticeable on fully polished rims. Fitment is the same. For me if you're getting a deal sure, but if the price difference is huge I'd go for the flats. There's also the euromiesters Fuchs in 16" and 17", way cheaper and better tire selection. I'm seriously thinking about selling my real flat 15" as soon as my tires are done. (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-26-1502571617.1.jpg) |
BK911 |
Aug 12 2017, 03:06 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
Deep 6s came on the early cars up to 71.
Some didn't have the safety bead. |
Aug 12 2017, 03:08 PM
914-6 GT in waiting Group: Members Posts: 19,234 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Huge price difference but they will probably just go up in value.
Mark Henry |
Aug 12 2017, 03:23 PM
Huge price difference but they will probably just go up in value. (IMG:style_emoticons/default/agree.gif) Then you likely also have to refinish them, more money to pay a pro or a huge DYI time suck. You could buy the repops and high end tires and it will still come out less than the deep rims alone. In fact you might come out at the price of just 2 deep fuchs. (IMG:style_emoticons/default/wink.gif) That said if you are getting a steel I'd grab them ASAP. |
gcrotvik |
Aug 12 2017, 03:44 PM
I currently have a set of flat 6's that need to be refinished. I was looking at a set of fully finished, TUV approved, reproductions at 350.00 each. That's nearly the cost of refinishing each of my wheels alone. I was hoping the deep 6's were offset slightly outward toward the inner wheel well, to increase the tire track width. Looks like I will keep my OE Fuchs.
Thanks! Greg |
914Sixer |
Aug 12 2017, 03:57 PM
914 Guru Group: Members Posts: 8,867 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Check out Maxilite Fuchs wheels.
MartyYeoman |
Aug 12 2017, 04:20 PM
Senior Member Group: Members Posts: 1,516 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
napasteve |
Aug 12 2017, 05:12 PM
914 driving winemaker Group: Members Posts: 500 Joined: 2-January 13 From: Napa, CA Member No.: 15,327 Region Association: Northern California |
pete000 |
Aug 12 2017, 05:18 PM
Deep sixes might be lighter and are very expensive. Some also have what is refereed to as with hearts which describes the opening around the valve hole. Some do not have hearts. The heart wheels tend to bring more money.
I was lucky a few years ago to find a set of four deep sixes with hearts for $400.00 I assumed they were reproductions, but to my surprise when I went to buy them they were OEM Fuchs !!! Cha Ching ! Attached image(s) |
Mark Henry |
Aug 12 2017, 05:22 PM
I currently have a set of flat 6's that need to be refinished. I was looking at a set of fully finished, TUV approved, reproductions at 350.00 each. That's nearly the cost of refinishing each of my wheels alone. I was hoping the deep 6's were offset slightly outward toward the inner wheel well, to increase the tire track width. Looks like I will keep my OE Fuchs. Thanks! Greg Be aware many think the TUV approval is (IMG:style_emoticons/default/bs.gif), they are likely just the same repops that may have been at most x-rayed Just to be clear, looking at Mark Henry's picture, the deep Fuchs is on the left and the flat Fuchs is on the right, correct? FYI I like my flat Fuchs (part # 911.361.020.10), refinished by Harvey. Correct, you can see the windows wrap inwards, and sets in further. |
nine11speedster |
Aug 12 2017, 05:25 PM
Carson Group: Members Posts: 55 Joined: 8-February 08 From: Ca, USA Member No.: 8,686 Region Association: None |
do we have some pricing for both the deep 6" and flat 6" for comparison?
is it true that "heart" are all deep 6"? Thanks |
ndfrigi |
Aug 12 2017, 05:46 PM
Deep sixes might be lighter and are very expensive. Some also have what is refereed to as with hearts which describes the opening around the valve hole. Some do not have hearts. The heart wheels tend to bring more money. I was lucky a few years ago to find a set of four deep sixes with hearts for $400.00 I assumed they were reproductions, but to my surprise when I went to buy them they were OEM Fuchs !!! Cha Ching ! ooops sorry Pete! I think that was me who sold that to you. That is my 1st month when I started with 914. Am I right there is 911 part number on it? Well sorry no idea it was OEM and I'm sure you did look at it first before you bought it. Again sorry! I'm sure u able to sell them for the price you paid. I did bought 2 sets of replicas within my 7 years with 914 and I paid $650 and $440 each set. |
wndsnd |
Aug 12 2017, 06:53 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
I have a set of both. MY deep six with hearts are polished which I do not prefer, but they are worth more than my flat sixes that are original and anodized.
I run the flat sixes daily. They both fit the same and I like the look. Pricing really depends on finish quality. But if you really have a nice set of deep sixes, you will love the look. To me the original anodized petals with black background can not be beat. |
wndsnd |
Aug 12 2017, 06:54 PM
Larmo63 |
Aug 12 2017, 07:28 PM
wndsnd |
Aug 12 2017, 08:28 PM
pete000 |
Aug 12 2017, 11:31 PM
Yes they are OEM Deep sixes with hearts for $400 I could not be happier !
pete000 |
Aug 12 2017, 11:33 PM
Lo-Fi Version | Time is now: 23rd April 2024 - 01:20 AM |
