Nine Fourteen Sex, The on going story of Love and Lust for a Machine. |
914 Ranch |
Jun 18 2022, 06:16 AM
Team Sharp where the 914 grow wings Group: Members Posts: 1,460 Joined: 29-January 16 From: TheNorth Shore Retreat. Deland Member No.: 19,611 Region Association: South East States |
Enjoying my coffee and accomplishments this morning. Not to be beating my own drum this is a really cool piece of work. A couple of things still to be done. I ordered some wire and some bullet connectors which will finish it up and bring me to the installation. Fusch, Fusch, I truly believe that this is the sweetest rear of the car oil cooler installation I have ever seen.
And here is another accomplishment. This thread is about to go over 37,000 viewers. This is so COOL. WOW JUST WOW... Once again thanks to all y'all for your continued support of my addiction and LOVE for my machine. Beating my own drum ( Eeh, Aye, Aye, Aye.) To an ancient Native American rhythm. Enthusiasm Inspiration Imagination Innovation I do feel the LOVE. |
914 Ranch |
Jun 20 2022, 12:02 PM
This morning I hooked up all the electrical connections and fired it up. There were motors running and that made my day. Remember one of the motors is not connected so it doesn't work. Still waiting on the connectors. Happy to hear the response from the 3 of them. When all 4 motors are running I will get them straight and all running the same way.
So close... |
914 Ranch |
Jun 22 2022, 10:06 AM
914 Ranch |
Jun 23 2022, 01:51 PM
The connectors arrived yesterday and I installed them immediately. I then got all the motors running the same direction. I'm running into some electrical glitches so after I get all of them sorted out I will do the installation.
That is a big deal as it involves work under the dash through the hole car, pulling the plenums, finishing up the oil coolers. An oil change and reassembling the duct work and fan box. No sweat, we're going into the hottest time of the year and I will be working outside. We'll see how it goes. Checking out batteries and I think I'm gonna need a bigger boat er, uh battery. |
914 Ranch |
Jun 27 2022, 09:59 AM
Although it appears that nothing is happening here work on the wiring for the circuit board for the control of the sensors. Air temperature, pressure and velocity and a few other things in the car.
Remember going digital? That's still happening. There is a circuit board on the fan box and a screen on the dash going in. I don't have the ability to fabricate the boards so my neighbor Josh is doing that. He says the screen has 5 lines on it and they can each be different colors. Two new buttons are also coming to the dash one to power up the circuit board and one for Mark Shid+#!?&tl @euro911 . Mark had mentioned at one point that it would be nice to have the rear wing adjustable from the cockpit. I have a huge servo for a flap and I am working on just that. I seems as though thru the circuit board I will be able use the flap in 3 positions. Like an adjustable Gurney Flap. I'm going to call those positions 0 None (0°) 1 Some (30°) and 2 A Lot (60°). The difference between a LARGE and small servo. The adjustable flap is just for intimidation. It might even work out to be a good tool for the car. Look, I want this car to be shocking. I want the top time racers to say, if they ever figure out how to drive that car we're all done. |
Shivers |
Jun 28 2022, 10:37 AM
Senior Member Group: Members Posts: 2,780 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Anyway you could use a speed sensor to adjust the wing for you? One less thing
914 Ranch |
Jun 28 2022, 10:43 PM
Hey Paul, so here I go again off on another tangent. Sense we have a computer on board we can probably make the flap computer controlled. So it could be made flat when under hard acceleration. And up full when on the brakes. Just when I thought I was getting ahead I figured that I need to do more things to the car. Active areo WOW. Ok I will talk to Josh and we'll brainstorm it tomorrow.
We have had the fans running but it hasn't been quite correct. It seems that the 80 amp ESC is inadequate and that it might require 2 of them. When I bought the motors they came with ESC's but that meant that I had to run 4 of them and I wanted to just have 1 controller. So now I'm going to work on tying 4 of them together. So I think I am going to put it all inside the box. More later today. |
914 Ranch |
Jul 2 2022, 10:21 AM
Well I guess this is latter. I've taken all the wires and electronics off of the fan box and I am moving fan housings to inside the box. When I was organizing the electronics originally I was trying to use a single RSC but the complicated electronics didn't want to run the 4 motors. So now I'm going to try to make 4 ESCs work together. One of the advantages to having one ESC was that I could put in on the side of the box. Now everything has to go inside the box which means pulling the box for maintenance.
Currently I am rotting 2 of the fan housings to make all the connections on the center of the floor of the box. So just to see I connected all the motors wires up and it looks like I will be able cut down on a lot of the wires to the motors. About this much. |
914 Ranch |
Jul 2 2022, 10:26 AM
914 Ranch |
Jul 5 2022, 03:04 PM
No progress yesterday or today by myself, but Josh is getting the circuit board together. Thanks you brother. Myself I was helping a friend with their boat twice and fell both times. My back is out and today is the third day after fall number one. I'm OK but quite stiff and I don't walk well yet. I have done some small things like straighting up the wiring inside the box.
914 Ranch |
Jul 7 2022, 03:08 PM
OK, here we go again. Sense this is the second attempt at controlling the motors I am using 4 ESC's and the circuit board to provide the correct voltage for the throttle and the rear wing flap servo. I still need to bring 12 volts to the busbar. Power from the regulator through a relay that is made hot by the ignition switch.
Shivers |
Jul 9 2022, 01:53 PM
OK, here we go again. Sense this is the second attempt at controlling the motors I am using 4 ESC's and the circuit board to provide the correct voltage for the throttle and the rear wing flap servo. I still need to bring 12 volts to the busbar. Power from the regulator through a relay that is made hot by the ignition switch. Oh cool, good idea. Everything hot from one spot makes it easier to trouble shoot. Peace |
914 Ranch |
Jul 12 2022, 01:14 PM
Thanks Paul but all the trouble shooting has to happen inside the box now. With the single ESC which was outside the box I had easy access, now I have to pull the box to do it. I still have to make it live before I can do the installation. We'll see where it goes from there.
I really want to see the fan box with the duct work installed. |
914 Ranch |
Jul 13 2022, 05:07 AM
And there goes another thousand, 38,000 viewers.
At my anual physical the other day my Doctor says to me, " Joe how is your heart? Me, " My hart is fine, it hasn't been broken in years." Yesterday I started wiring for Gurney flap on the rear wing. It's going to be a little difficult. Josh has been working on the circuit board and is making good progress. |
914 Ranch |
Jul 15 2022, 11:02 AM
Hiding from the heat today. Working on wires for the motor controls. Trying to get the rear wing apart so I can install the servo and cut in the Gurney flap. If things don't work out, I'll make a new wing built for the Gurney flap and the servo.
Shivers |
Jul 16 2022, 11:59 AM
Pretty cool stuff, Joe
914 Ranch |
Jul 16 2022, 06:22 PM
Thanks Paul, I really think so. If everything works the way it is supposed to I'll be able to see if the scoops for the intake are aiding in airflow and the same goes for the fan box. I can add an air pressure sensor to the bottom of the air box and see if it is really dropping the air pressure under the car. Check the air speed in the plenums and at the exhaust grills behind the oil coolers. I will be able to check air temperature, pressure and velocity anywhere on the car. The readout and controls will be on the dash.
Today I located the Gurney flap servo. This is so COOL. |
914 Ranch |
Jul 18 2022, 06:40 AM
914 Ranch |
Jul 19 2022, 06:35 AM
Shivers |
Jul 19 2022, 01:11 PM
Very cool Joe...Let us know
Lo-Fi Version | Time is now: 23rd November 2024 - 01:28 AM |
