Rear trunk floor temp? |
falcor75 |
Sep 20 2017, 03:08 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
How hot does your rear trunk floor get after a drive? Mine gets pretty hot, around 35-40C even tho the air temperature is only around 15-20 C.
Spoke |
Sep 20 2017, 05:23 AM
Jerry Group: Members Posts: 6,973 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The trunk floor does get warm. Not sure of the absolute temperature though. Do you have the muffler shield attached?
Between the heat coming out from below the engine and the muffler, it does get warm. Not a good idea to put groceries in the rear trunk when shopping. (IMG:style_emoticons/default/smile.gif) |
IronHillRestorations |
Sep 20 2017, 05:27 AM
I always thought with a slight mod, the 914 would make a good pizza delivery car. (IMG:style_emoticons/default/smile.gif)
clapeza |
Sep 20 2017, 07:02 AM
Member Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States |
You put the pizza in the trunk and the beer in the frunk...
It's the automotive equivalent of the McDLT: https://www.youtube.com/watch?v=zL2c6NSVAvA The early Boxster had similar criticism, IIRC. |
falcor75 |
Sep 20 2017, 07:36 AM
Yes I have a non stock heatshield but was still a bit suprised at the temps.
LowBridge |
Sep 20 2017, 09:00 AM
Member Group: Members Posts: 370 Joined: 10-August 15 From: Lunenburg, MA Member No.: 19,045 Region Association: North East States |
You put the pizza in the trunk and the beer in the frunk... It's the automotive equivalent of the McDLT: https://www.youtube.com/watch?v=zL2c6NSVAvA The early Boxster had similar criticism, IIRC. (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) |
PanelBilly |
Sep 20 2017, 09:38 AM
914 Guru Group: Members Posts: 5,797 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
The beer goes in the belly. Mine
worn |
Sep 20 2017, 10:07 AM
can't remember Group: Members Posts: 3,145 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
How hot does your rear trunk floor get after a drive? Mine gets pretty hot, around 35-40C even tho the air temperature is only around 15-20 C. Yeah, the floor gets toasty. I have to remember not to put heat sensitive items back there. Like beer. 20 degrees is OK, but 37 isn't. |
johnhora |
Sep 20 2017, 10:26 AM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
this just the reason the mostly yellow now, usually gone, water adsorbing mat was under the carpet in the rear trunk....to keep your parcels from melting (IMG:style_emoticons/default/biggrin.gif)
maf914 |
Sep 20 2017, 10:35 AM
Yes I have a non stock heatshield but was still a bit suprised at the temps. Do you also have the factory insulation mat under the rear trunk carpet? I don't know how effective it is, but obviously the factory knew heat was a problem. There were a couple of different approaches to this by the factory. My 76 has a black plastic covered foam pad that covers the entire trunk floor under the carpet. |
falcor75 |
Sep 20 2017, 11:55 AM
Yes I have a non stock heatshield but was still a bit suprised at the temps. Do you also have the factory insulation mat under the rear trunk carpet? I don't know how effective it is, but obviously the factory knew heat was a problem. There were a couple of different approaches to this by the factory. My 76 has a black plastic covered foam pad that covers the entire trunk floor under the carpet. I dont have a trunk carpet at all, might have to get one. |
cary |
Sep 20 2017, 01:26 PM
Mats you need the insulation pad more than the carpet.
It's pretty thick. |
eyesright |
Sep 20 2017, 01:47 PM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
I always thought with a slight mod, the 914 would make a good pizza delivery car. (IMG:style_emoticons/default/smile.gif) I'd lose a lot of tips. The pizza would always be stale by the time I showed up. |
aharder |
Sep 20 2017, 02:31 PM
Advanced Member Group: Members Posts: 4,371 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
The beer goes in the belly. Mine (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/beer3.gif) |
Mikey914 |
Sep 20 2017, 08:18 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Matt's, may be able to hook you up in a week or so. Working on molded rear carpet with insulation pad.
Mark |
michael7810 |
Sep 20 2017, 09:00 PM
Senior Member Group: Members Posts: 1,079 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Mikey914 |
Sep 20 2017, 10:00 PM
Yes many do. Actually molded not just cut fabric. We've been working on the material that will be used for the insulation. I have a choice of a few materials, I've eliminated one, and think that we've got it narrowed down.
falcor75 |
Sep 20 2017, 11:49 PM
Matt's, may be able to hook you up in a week or so. Working on molded rear carpet with insulation pad. Mark Yay more shiney new parts.... (IMG:style_emoticons/default/w00t.gif) Edit: does anyone else feel like 914 rubber is their drug dealer....? (IMG:style_emoticons/default/smile.gif) Me: I might need something... Mikey: Psst....I've got what you need... Me: Whoohoo! |
walterolin |
Sep 20 2017, 11:56 PM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
Matt's, may be able to hook you up in a week or so. Working on molded rear carpet with insulation pad. Mark Yay more shiney new parts.... (IMG:style_emoticons/default/w00t.gif) Edit: does anyone else feel like 914 rubber is their drug dealer....? (IMG:style_emoticons/default/smile.gif) Me: I might need something... Mikey: Psst....I've got what you need... Me: Whoohoo! No shit. 914 crack, or 914 porn. Bunch of new stuff lately. |
Mikey914 |
Sep 21 2017, 07:27 AM
And more on the way.
Mark (IMG:style_emoticons/default/biggrin.gif) Did I mention I fly low and fast ? |
Lo-Fi Version | Time is now: 25th April 2024 - 01:55 PM |
