Pliers and screw driver names |
cal44 |
Nov 9 2017, 03:27 PM
Member Group: Members Posts: 165 Joined: 8-October 09 From: Encinitas, Ca. Member No.: 10,910 Region Association: Southwest Region |
Can you'all give me a heads up on the name (manufacturer) on the pliers, 10/13 open end wrench and screw driver for the tool kit 1974.
Thank you |
raynekat |
Nov 9 2017, 03:35 PM
Advanced Member Group: Members Posts: 2,153 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Are you talking about 914-6 or 914-4?
Big difference when talking about tools. (IMG:style_emoticons/default/wink.gif) There's a good website for 914-6....someone here will know it. |
TheCabinetmaker |
Nov 9 2017, 03:46 PM
He said a 74, If I read it right.
cal44 |
Nov 9 2017, 05:04 PM
Yep.......1974 four banger. I have reference material but the tool brands are not evident, hence my request.
Thanks |
TJB/914 |
Nov 9 2017, 05:13 PM
Mid-Engn. Group: Members Posts: 4,325 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
Yep.......1974 four banger. I have reference material but the tool brands are not evident, hence my request. Thanks Here's one, they are getting hard to find & expensive. Tom Attached image(s) |
bbrock |
Nov 9 2017, 05:41 PM
This should give you all the info you need about tool kits: http://www.p914.com/p914_tools.htm
raynekat |
Nov 9 2017, 06:36 PM
That's the website I was thinking of. Looks the screwdriver is non descript. |
cal44 |
Nov 10 2017, 07:03 AM
Fellers........thank you so much for the intel and that website.
Appears the screw driver is non descript (nameless). |
bbrock |
Nov 10 2017, 09:25 AM
Fellers........thank you so much for the intel and that website. Appears the screw driver is non descript (nameless). So non descript that when I found one rattling around in the trunk of one of the cars I owned decades ago, I threw it away thinking it was just some cheap Wal-mart crap tool. (IMG:style_emoticons/default/headbang.gif) |
cary |
Nov 10 2017, 10:24 PM
Hazet
TJB/914 |
Nov 12 2017, 10:45 AM
Hazet Cal44 & 914er's I found some misc tool kit parts (screwdrivers-wrenches-spark plug tools) & will post sometime next week after I take photo's. BTW: This stuff is getting expensive and rare to find. I know complete 914-6 tool kits are in the $2k+ to $3k+ area and complete 914-4's are in the $500++ area if you can find them. (IMG:style_emoticons/default/w00t.gif) It only gets more expensive over time for these factory tool kits that got thrown away by everyone. (IMG:style_emoticons/default/popcorn[1].gif) Tom |
Larmo63 |
Nov 12 2017, 11:01 AM
The VW sourced /4 "tool kit" is basic crap. The only part worth anything is the tow eye.
maf914 |
Nov 14 2017, 08:17 AM
What is the function of the U-shaped bent wire tool with hooked ends located next to the tow-eye in the above photo? (IMG:style_emoticons/default/idea.gif)
bdstone914 |
Nov 14 2017, 08:27 AM
bdstone914 Group: Members Posts: 4,507 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
What is the function of the U-shaped bent wire tool with hooked ends located next to the tow-eye in the above photo? (IMG:style_emoticons/default/idea.gif) Early hub cap puller. There are two holes in the edge of the hub cap to use with that tool. The puller look longer than most I have seen. |
maf914 |
Nov 15 2017, 07:10 AM
Thanks, bdstone.
bretth |
Nov 15 2017, 07:50 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
My 75 didn't have any tools with it but my leftover tools from my 68 camper sure look a lot like the 914 tools. I have go dig them out.
Mike Fitton |
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
These tools were also in the VW tool kits and there are plenty available check EBay and the Samba. If described as a Porsche tool $$$ as a VW tool each tool is under $20ea.
mbseto |
Nov 15 2017, 10:39 AM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
That bar goes with the jack also, doesn't it? The jack and the bar is all I have of the kit...
Lo-Fi Version | Time is now: 18th April 2024 - 12:22 PM |
