Yet another head thread, Need advice |
bbrock |
Nov 11 2017, 06:37 PM
This is related to the AA/HAM head GB but I didn't want to hijack. But that offer means I need to make some decisions sooner than anticipated on my resto. The main question is whether to rework these heads or buy new? My very strong preference is to rework what I have, assuming the castings are good. They have not been cleaned so I was thinking about walnut blasting them myself so I can inspect for cracks before deciding whether to move forward on reworking. Is there any reason I should not blast them myself? Any spots that should be masked or blocked before blasting? Basically, I just want to get to a decision point on whether to rework or buy new. After reading so much about how hard it is getting to find good original castings has me a bit spooked, and if I hit a dead end on reworking, I'd like to do it while the HAM GB is still an option. I also don't know what a basic head rebuild will cost. Anyone have a ballpark estimate? I used to be able to send them out to Cali for a couple hundred bucks, but those days are gone. Here's a short version of the history my engine. It's GA 2.0L engine that I rebuilt the bottom end on in the late 80s, but the project stalled before I got to the heads. My best guess is that the engine had about 110K-120K miles on it when it was split. That's a guess because the odometer quit at about 92K shortly after I bought the car. The engine ran strong when the FI cooperated when it was pulled, so no reason to suspect any major issues. Other than a busted exhaust stud, the heads look good with no broken fins and very little carbon in the combustion chamber. So, overall, I feel these heads are a good candidate for rebuilding but would appreciate any advice or opinions. |
bbrock |
Nov 13 2017, 11:18 AM
(IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/smile.gif)
Even if someone could weigh in on DIY walnut blasting the heads. Would like to clean them up enough to inspect for obvious cracks before shipping them off to a builder. I might work on them this evening unless someone talks me off the ledge. It seems safe enough but... (IMG:style_emoticons/default/confused24.gif) |
mgphoto |
Nov 13 2017, 12:21 PM
"If there is a mistake it will find me" Group: Members Posts: 1,330 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
A few years ago this option was nonexistant.
Only option was the AMC bus head reworked into the 2.0 combustion chamber and plug angle, mucho buckos. So the option of redoing a cracked 2.0 head might have been cost effective. Time to repair is the factor. Rebuilt heads from a quality shop will have all of the parts replaced as will happen with the "new" AA casting. So if the repairs are more expensive than a new AA head, the balance tips to the new. Some heads are in good shape and only need a valve job, but the stress and strain of 40+ years will take its toll. Hey a whole bunch of 914er's are jumping into the 123 dizzy, and rightly so. Performance per dollar... |
McMark |
Nov 13 2017, 01:27 PM
914 Freak! Group: Retired Admin Posts: 20,177 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
No reason not to walnut blast them. Go ahead and see what you've got.
I was using mostly rebuild old heads for most of my engines until the AAPistons heads came out. So reworking your old heads is still just as viable as it always was. Nothing has changed in that respect. The HAM GB is a great opportunity, and new castings are an improvement over old. BUT, if this is a budget/money situation, reworking your old heads will be cheaper and will work well, unless they are cracked. So for my opinion, blast them, check for cracks and that will make your decision for you. |
bbrock |
Nov 13 2017, 03:02 PM
Thanks guys! I very much appreciate this. When I read that some of our best rebuilders were no longer working on used heads, it got me rattled. These heads only ran for 13 years before they got mothballed. Budget is definitely important, but mostly, I hate to replace expensive parts unnecessarily. I'll clean them up and give them my amateur inspection before sending them to a pro.
Another question, I have a set of NOS genuine Porsche valve guides I bought back when the engine was torn down. Any reason not to have those installed with the rebuild? |
mgphoto |
Nov 13 2017, 03:20 PM
Simple way to check for cracks is a propane torch.
Just heat up the suspect places, crack will open and spew oil and smoke. No reason not to use NOS, except if you expect to go bigger. |
bbrock |
Nov 13 2017, 03:39 PM
Simple way to check for cracks is a propane torch. Just heat up the suspect places, crack will open and spew oil and smoke. No reason not to use NOS, except if you expect to go bigger. Awesome! (IMG:style_emoticons/default/smilie_pokal.gif) Keeping it stock except for CAM and Webers. I have the same question about NOS OEM springs and lifters, but I'm trying to track down the specs on the CAM since that seems like those will be important. It was a "Street grind" reground CAM from Automotion before they became Ecklers. Unfortunately, I threw away my old catalogs a few years ago which, I believe, had the specs on the reground CAMS in them. I have a message in to them to see if I can retrieve that info. I'm guessing the springs will be fine, but I'm not sure about the lifters. |
McMark |
Nov 13 2017, 04:04 PM
Guides can be used if they fit the specs of what's needed. Some old head rebuilds need oversize guides.
But there's nothing wrong with the NOS guides/springs. The lifters and cam make me nervous. There was a period of time where cams were causing some problems. Not to mention the hardness of the cam and the lifters must be matched so one doesn't eat the other. If I were building that motor I would be getting a new WebCam and lifters, instead of risking that combo. It's not a guaranteed failure, so if you're stuck with what you've got then keep moving forward. |
bbrock |
Nov 13 2017, 04:58 PM
The lifters and cam make me nervous. There was a period of time where cams were causing some problems. Not to mention the hardness of the cam and the lifters must be matched so one doesn't eat the other. If I were building that motor I would be getting a new WebCam and lifters, instead of risking that combo. It's not a guaranteed failure, so if you're stuck with what you've got then keep moving forward. Yeah, this has been nagging at me. I'm not stuck with what I've got, but it would open a can of worms. If I started this rebuild today, I'd almost certainly be refurbing the stock FI instead of going to carbs. My plans now are to go ahead and run the carbs to see how I like them, then maybe start working through all my FI bits to eventually go back to that. So, that would wind up being a lot of swapping CAMs. This may betray my ignorance, but since this was a regrind job on a factory CAM, I'm thinking the hardness should match the factory lifters assuming they didn't grind through the hardened layer. Maybe that is wrong thinking. I did get the lifters on the same order with the CAM from Automotion. I'll probably start another thread on the CAM to see if anyone had experience with these Automotion reground CAMs back in the day. Eckler has already responded and is trying to locate specs for me. This is the original numbers matching GA case, so I really don't want to built it with a loose grenade inside. |
McMark |
Nov 13 2017, 05:06 PM
Are there any numbers stamped on the cam? Usually they're stamped where the cam gear bolts on.
If you're that on the fence, I'd recommend: Stock fuel injection WebCam 73 96mm AAPistons Stock heads (back to the crack question) Pretty easy build, great torque, reliable fuel injection. Carbs take some 'babysitting' to keep running right and have no cold-start aid. |
bbrock |
Nov 13 2017, 05:38 PM
Are there any numbers stamped on the cam? Usually they're stamped where the cam gear bolts on. If you're that on the fence, I'd recommend: Stock fuel injection WebCam 73 96mm AAPistons Stock heads (back to the crack question) Pretty easy build, great torque, reliable fuel injection. Carbs take some 'babysitting' to keep running right and have no cold-start aid. I should back up a bit. I rebuilt the bottom end of this engine in 1989 and the case has been buttoned up with CAM inside since then. So I can't access without splitting the case. It already has new (and by now, old stock) 94mm euro spec OEM (Mahle) pistons and jugs. I also bought the Weber 40IDFs back then because my FI was a POS and all the cool kids were going to carbs. Crank and flywheel were machined and engine was balanced, and the bottom end was assembled. Basically, everything was ready to roll except rebuilding the heads. Then the project stalled because life got in the way. Almost 30 years later, I'm picking up where I left off. Obviously, I'd like to avoid splitting the case if I can, but I'd like to avoid blowing up the engine even more. (IMG:style_emoticons/default/beerchug.gif) I'm about half way through a major rustoration but as for the engine, the quickest route to being road-ready would be bolting on rebuilt heads and these carbs and calling it good. My FI was totally unreliable before the tear down so I'd need to spend significant time and $ getting that sorted. Plus, I've spent 30 years dreaming about driving this car with carbs, and would really like to see what they are all about. All that has weighed in to my current plan to continue with the carbed engine and make a decision on FI later after I've spent a winter refurbing parts. But if I really have to split the case and swap a CAM now... that could change things. And I REALLY appreciate you taking the time to offer advice. (IMG:style_emoticons/default/smilie_pokal.gif) |
McMark |
Nov 14 2017, 10:55 AM
Ah, that makes total sense. (IMG:style_emoticons/default/thumb3d.gif)
Get those heads blasted. (IMG:style_emoticons/default/poke.gif) |
bbrock |
Nov 14 2017, 11:53 AM
Didn't get the heads blasted last night but will work on them tonight. (IMG:style_emoticons/default/unsure.gif)
I was reading through the Web Cam catalog last night and saw that OEM lifters are to be used even with their reground cams, but Web Cam lifters must be used with their new cams. So I'm feeling pretty good about the cam/lifter combo I have... if the Automotion regrinds were good. Thanks again for your help. (IMG:style_emoticons/default/beer.gif) |
bbrock |
Nov 28 2017, 09:51 AM
Finally got my heads walnut blasted. They still need a good soak and boil, or whatever they do to make these things look new again, but I think they look good. A total of 3 engine tin screws that need to be extracted, a broken exhaust stud on one head, and one bent fin on the other. But I'm not seeing any cracks and I didn't find any smoke genies when heating with a torch. I think they look pretty good. Wondering if you experts can see anything I'm missing.
Left Head: Right: Questions: - Should that bent fin be straightened? My guess is no, but curious. - New seats? I was planning to have them replaced, but was reading in Tom Wilson's book where he says that factory installed seats rarely drop. I'm guessing as long as the builder knows what they are doing; heats the heads and chills the seats before pressing, it would be the same. But wonder what the experts think. Again, best estimate is these heads have between 100K and 130K miles on them. Probably at the lower end of that estimate. - What is the best way to remove head and exhaust gaskets without damaging the sealing surfaces? All of them are stuck on pretty tight and I was worried about messing something up gettig them off. |
McMark |
Nov 28 2017, 12:15 PM
Dental type picks are a good way to get the gaskets out. The exhaust ones can be pretty challenging and a pick may not be able to apply enough force to grab it.
Don't straighten fins. They may break off instead. And it's not going to affect the cooling. Full rebuild would be new seats, new guides, new springs, new valves, new retainers, new keepers, and flycut the sealing surface to ensure it's flat. If the sealing surface is flycut, then a matching amount of material need to be removed from the face of the heads so they don't hit the cylinder fins. |
bbrock |
Nov 28 2017, 12:51 PM
Dental type picks are a good way to get the gaskets out. The exhaust ones can be pretty challenging and a pick may not be able to apply enough force to grab it. Don't straighten fins. They may break off instead. And it's not going to affect the cooling. Full rebuild would be new seats, new guides, new springs, new valves, new retainers, new keepers, and flycut the sealing surface to ensure it's flat. If the sealing surface is flycut, then a matching amount of material need to be removed from the face of the heads so they don't hit the cylinder fins. Man, not only did you answer all my questions, but also one I was thinking of asking about nditz1's situation to avoid having a similar problem. Now on the valve replacement, does that include exhaust? These are the original sodium-filled valves. Forty years old - yes... but only in service for about 15 of those years. I realize this subject is a can of worms, but I value your opinion. (IMG:style_emoticons/default/stirthepot.gif) |
VaccaRabite |
Nov 28 2017, 01:07 PM
En Garde! Group: Admin Posts: 13,407 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I see something that looks like a crack in the spark plug hole (which is a super common crack site). Use some machinists die and that will tell you quick if there is a crack there or not. Post 14, Second picture, left hand cylinder, 3 o'clock on the spark plug hole. Could be a casting flaw, but it looks like a crack.
Zach |
McMark |
Nov 28 2017, 01:34 PM
You should replace them all. The sodium valve can snap off (probably what happened to nditz1's engine). Dropping a valve or a seat makes a big mess and is one of the more catastrophic failures.
nditiz1 |
Nov 28 2017, 02:13 PM
Senior Member Group: Members Posts: 1,164 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Mark is correct my valve snapped in half.
bbrock |
Nov 28 2017, 05:56 PM
You should replace them all. The sodium valve can snap off (probably what happened to nditz1's engine). Dropping a valve or a seat makes a big mess and is one of the more catastrophic failures. Sadly, I know this first hand. Had the #3 let go in two different engines in a VW bus I once had. Both at highways speed. Schrapnel welded into the head and knocked a hole through the case both times. Would rather avoid a repeat. |
Lo-Fi Version | Time is now: 28th March 2024 - 01:35 PM |
